Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Mines Japanese Tuning.
    chauhdarywaqar's Avatar
    Jul 2006
    27
    3,569
    Default Mines Japanese Tuning.
    Mines Japanese Tuning -530734
    MINE'S is an automotive tuning company based in Yokosuka, Japan. MINE'S was started by Michizo Niikura, in 1985. They initially gained their popularity around 1988, by being among the first Japanese companies to sell re-programmed ECU systems for popular Japanese sportscars. Today they sell many products, ranging from Injectors to Complete Engines.
    MINE'S currently makes software upgrades for hundreds of Japanese cars, but they only make hardware upgrades for a select few cars. They tend to concentrate on cars that have high potential, and good platforms to expand from. Their performance upgrades include (among other things) exhaust systems, engine computers, camshafts, suspension parts, brake systems, and lightweight body parts. Their body parts are almost always made of lightweight carbon fiber.
    Mines Nissan Skyline R32
    Mines Japanese Tuning -530735
    In 1997, Rev Speed magazine recorded a laptime of 59.1 seconds, in the MINE'S R32 Skyline GT-R.
    Mines Nissan Skyline R33
    Mines Japanese Tuning -530736
    A few months later they recorded a laptime of 59.8 seconds in the newer MINE'S R33 Skyline GT-R (this GT-R was heavier than the R32)
    Mines Nissan Skyline R34
    Mines Japanese Tuning -530737
    Later in 2002, Best Motoring recorded a laptime of 57.7 seconds in the MINE'S R34 Skyline GT-R demo car. For a comparison, the McLaren F1 does a lap on this track in 14 seconds.
    Mines Mitsubishi Lancer VI CP9A RS
    Mines Japanese Tuning -530738
    Mines Japanese Tuning -530739
    Aside from the Skyline GT-R, MINE'S also develops upgrades for cars such as the Mitsubishi Lancer EVO.
    Using a HKS turbocharger, new ECU, exhaust system and some other parts, Mine's transform in a four door missile. After the successfull modification of the Nissan Skyline R33 and R34 (up to 630 PS), Mine's a best known japanese tuner develop a high performance kit for the Lancer Evolution VI.
    ???? 400ps
    ????? 40.5kgm
    ????????? 1.3kg/cm2
    Circuit Best Time
    ??????? 1'00.432
    Mine's Skyline GT-R V-Spec R34
    Mines Japanese Tuning -530740
    Mines Japanese Tuning -530741
    Of Japan's best tuned Skylines is this Mine's V-Spec N1. It's been tuned, not so much for show, as much as to lap Japan's tracks as fast as possible. It was made famous after an appearance on Best Motoring where 'drift king' Keiichi Tsuchiya and Manabu Orido did some hot laps in the car and where surprised by its raw power and responsive handling.
    Before the test, Michizo Niikura from Mine's compared this Skyline to the subtle tuning they've performed in the past and explained, unlike before, that the engine had been extensively tuned. But despite the huge increase in power - nearly double - Niikura said that the main focus of the car, like earlier ones, was on ''balance and response''.
    In the almost stock looking bay, the engine retains its factory pistons, but uses new high-lift camshafts and two HKS GT2530 Turbos to produce over 600 bhp. Accordingly, the whole intake and exhaust systems are revamped, as is the engine electronics.
    To keep all this power in check a 'Mine's Force' suspension is installed which includes a 3-way adjustable damping system and Mine's anti-roll bar. Braking is by enhanced with larger discs that sit behind Mine's 18 inch magnesium wheels.
    Outwardy the Mine's Skyline is different, with many pieces crafted in carbon fiber such as a rear wing, front diffuser, side skirts and radiator shroud that all make this car distinct.
    During their tests, Tsuchiya and Orido were taken with the performance of this Skyline, and if the rpm gauge was any indication, this is one of the fastest ever made for the road. They said ''it's so fast that even a dead man will scream.''
    Specs.
    In Detail
    engine Water Cooled RB26DETT Inline 6 w/Mines Intake, Exhuast, High-Life Camshafts
    position Front Longitudinal
    aspiration Twin HKS GT2530 Turbos
    valvetrain Belt Driven DOHC 4 valves / cyl
    displacement 2568 cc / 156.7 cu in
    bore 86.0 mm / 3.39 in
    stroke 73.3 mm / 2.89 in
    power 469.8 kw / 630 bhp @ 7200 rpm
    hp per litre 245.33 bhp per litre
    bhp/weight 378.15 bhp per tonne
    torque 587.07 nm / 433 ft lbs @ 5400 rpm
    drive wheels Full Time 4WD
    body / frame Unit Steel
    front brakes Discs w/6-Piston Calipers
    f brake size 355 mm / 14.0 in
    rear brakes Discs w/4-Piston Calipers
    r brake size 330 mm / 13.0 in
    front wheels F 45.7 x 25.9 cm / 18 x 10.2 in
    rear wheels R 45.7 x 25.9 cm / 18 x 10.2 in
    front tire size 265/35R18 Bridgestone Potenza RE-01R
    rear tire size 265/35R18 Bridgestone Potenza RE-01R
    steering Rack & Pinion w/Speed Sensitive Power Assist
    f suspension MacPherson Struts w/Addional Link, Lower A-Arms, Coil Springs, Mine's Dampers & Anti-Roll Bar
    r suspension Mulitlink w/Coil Springs, Mine's Dampers & Anti-Roll Bar
    weight 1666 kg / 3673 lbs
    wheelbase 2665 mm / 104.9 in
    front track 1480 mm / 58.3 in
    rear track 1490 mm / 58.7 in
    length 4600 mm / 181.1 in
    width 1785 mm / 70.3 in
    height 1360 mm / 53.5 in
    transmission Getrag 6-Speed Manual w/Carbon Twin-Plate Clutch
    gear ratios 3.827:1, 2.360:1, 1.685:1, 1.312:1, 1.000:1, 0.793:1
    final drive 3.545:1
    Mines Nissan 350Z Z33
    Mines Japanese Tuning -530742
    Mines Japanese Tuning -530743
    Mines Japanese Tuning -530744
    The Fairlady Z being among the only non-turbocharged vehicles they develop for. While most tuners in Japan turbocharge the Fairlady Z to increase power, the MINE'S Fairlady demo car remains naturally aspirated, and makes 350ps. The demo car runs what Mine's calls their "Stage II" engine, which pushes power to 320 ps at 6,540 rpm and torque to a very impressive 40.9 kgm at 4,500 rpm.
    Mines Lancer Evolution
    Mines Japanese Tuning -530745
    Mines Japanese Tuning -530746
    More Pictures of Mine's Tuned Cars.
    Mines Japanese Tuning -530747
    Mines Japanese Tuning -530748
    Mines Japanese Tuning -530749
    Mines Japanese Tuning -530750
    Mines Japanese Tuning -530751
    Mines Japanese Tuning -530752
    Mines Japanese Tuning -530753
    Mines Japanese Tuning -530754
    Mines Japanese Tuning -530755
    Mines Nissan GTR R35.
    Mines Japanese Tuning -530756
    Mines Japanese Tuning -530757
    Mines Japanese Tuning -530758
    Mines Japanese Tuning -530759
    For more info on Mines Nissan GTR R35. Click Below:
    http://pakwheels.com/forumreply_az_T...umID!1~pw.html
    Over the years MINE'S has competed in many magazine track battles. Japanese magazines such as Option and Rev Speed frequently put demo cars from some of the top tuning companies in Japan against each other in a battle for fastest laptime on a given track. MINE'S tends to perform best on the famous Tsukuba track.
    When modifying a car, MINE'S tries to focus mainly on the performance aspects of the vehicle. They tend to stay away from the styling and decorative side of the tuning industry. MINE'S CEO and founder Michizo Niikura, said in a 2002 Best Motoring interview, "If we try to do too many things, we will lose focus as a company". Although their demo cars are never without a bit of style, they say they want their customers to be able to choose their own style. They would rather let the performance of their cars speak for their company.
    spancolor: #ff0000""Videos
    of Mines work.
    Mines Nissan Skyline R32:
    http://youtube.com/watch?v=uveaS3f6n80
    Mines Nissan Skyline R33:
    http://youtube.com/watch?v=0is9b8QKv3M
    http://youtube.com/watch?v=viuVjAS3WVU
    Mines Nissan Skyline R34:
    http://youtube.com/watch?v=ScJi_7IMIqg
    Mines Japanese Tuning -530760
    Mines Japanese Tuning -530761
    Source: www.mines-wave.com
    It's not who you are to the world, it's who you are to me. It's not how many times I say I love you... it's how much I really do.
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    so what's the point here?
    Jul 2006
    27
    3,569
    ^ The point here is to have Pakwheels members be familiar with Japanese Mines tuning. & if in the future they are looking for performance parts for a vehicle similar to the ones mentioned above they might find it useful to take a look at Mines tuning.
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    oooooooooh. thanks. you know i have to be explained everything.
    Jul 2006
    27
    3,569
    ^ Your welcome. Anytime.
    Born2Race's Avatar
    Jun 2006
    23
    10,107
    5 Post(s)
    Mines Japanese Tuning -795186
    from the above pictures wich waqar posted, it seems dat mines tuning is more into car performance den into exterior mods like bodykits, decals, vinyls etc. etc. dats a gud thing frem tuning companies as most ov the tuning companies more consider on exterior and interior mods den performance mods
    Thy name's 'Fahad'. Powered by D16™​.
    Jul 2006
    27
    3,569
    ^ Now you are getting it. good job born2race.(Y)
    spiderman's Avatar
    Feb 2005
    9,667
    52 Post(s)
    7 Thread(s)
    i love their work its always excellent and its one of my favorite tuning company's and the mines R34 is a 600+bhp monster if you play GT4 you can see their evo and R34 in it too.
    @chauhdarywaqar nice thread do keep the pics coming but the starting pics are very small. and can you also get the 0-60 figures with the specs too? and post each car with alot of its pics then its specs.
    Born2Race's Avatar
    Jun 2006
    23
    10,107
    5 Post(s)
    @waqar: thnx bro.!
    s90
    s90 is offline
    s90's Avatar
    Aug 2006
    26
    2,799
    Hmm interesting....
    Not to be absolutely certain is, I think, one of the essential things in rationality. - Bertrand Russell
    Jul 2006
    27
    3,569
    @spiderman
    Thanks bro. Yes I will try to get up some times for the cars and also more pics.
  12. #12
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    chauhdarywaqar
    Grt idea.. i wonder how much will it cost to send car to Mines from Pk for a tuneup?
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
  13. #13
    freakridemaniac's Avatar
    Feb 2007
    3,571
    Te skyline frm hell!!!
    Petrol head.
  14. #14
    SZK
    SZK is offline
    SZK's Avatar
    Aug 2007
    27
    219
    interesting
  15. #15
    Jul 2006
    27
    3,569
    @levin
    Well if you want Mine's parts they probably ship the parts to you. So why should you worry about getting your car tuned there. Just the parts matter and they are available at any good performance parts shops. & for people like you no need to get a tune up done from Mine's because you already now how to tune a corolla & TRD are the parts you should aim for and mine's does not interefere with corollas.
  16. #16
    Feb 2007
    3,571
    Its not just abt the parts I believe .... its all abt tunning
    Petrol head.
  17. #17
    Jul 2006
    27
    3,569
    Thanks to Anonpak & his friend JapanCarBlog for the pics...
    Mines Japanese Tuning -803611
  18. #18
    Jul 2006
    27
    3,569
    Mines Japanese Tuning -803612
  19. #19
    Jul 2006
    27
    3,569
    Mines Japanese Tuning -803613
  20. #20
    Skyline_Drift_Master's Avatar
    Oct 2004
    Select City
    29
    9,104
    MINES RULESSS!!!
    Thy name is Sumair Thy love Skyline Thy is very interested in DRIFTING Thy has PHD in drifting from the university of Street Racing!!
