Results 1 to 6 of 6
Thread: Any body tried Electric Supercharger ?
    SIG
    SIG is offline
    SIG's Avatar
    Feb 2008
    40
    105
    3 Post(s)
    Default Any body tried Electric Supercharger ?
    AOA
    Any body tried Electric Supercharger?
    if yes , Available in Pakistan & whats the price ?
    http://www.mimousa.com/home.asp?dir=products&prod=952
    GAINS UP TO 25 HORSEPOWER
    If you need a boost and can't afford a real turbo or supercharger conversion, this product is for you. The Electric Supercharger is an adapter to either your short ram or cold air intake. It will work on absolutely any air intake brand including AEM, Injen, MimoUSA, Weapon R, Fujita etc. Simply remove your current air filter and put the Supercharger as a replacement, it's that simple.
    The supercharger is operated on a 12-volt source. This means you can connect it to your battery to get the power. It uses 2.2 amps from your alternator when turned on and doesn't affect your car performance or battery drain. The Supercharger is connected to a switch inside the car. Whenever you need more power you simply flip the switch and fly away. It produces 250CFM of forced air into your manifold and it very quiet under the hood when turned on. In fact it has a nice aggressive sound, making it seem like you got something bigger then what you actually have under the hood.
    A stock turbo from an Audi 1.8T produces 400CFM. Adding the electric supercharger will produce more then half of the power than a stock Audi 1.8T turbo would. There is need to do any modifications to your engine at all. 250CFM of forced air can also be compared to a 15-25 shot of Nitrous.
    The supercharger is made out of the finest parts and a certified K&N Filter with Lifetime warranty. Installation is very simple, it should not take more then 15 minutes to install.
    * Produces 15 - 25 horsepower increase.
    * Generates 250CFM of forced air.
    * Universal Bolt-on, installs on any short ram or cold air intake.
    * K&N Filter included.
    * Installation instructions and all necessary installation hardware included.
    * Pipes are not included, the car must be equipped either a short ram or cold air intake. (If you do not have an intake we would recommend the Weapon R Secret Weapon)
    * Universal application. (Unit will replace your aftermarket air intake filter, please check to see if there is enough room by your air intake filter to install this unit.)
    Any body tried Electric Supercharger ? -543793
    Cylestyne's Avatar
    Oct 2005
    32
    5,160
    5 Post(s)
    Are you really expecting a 10-15 HP gain from a 'blower' which is basically a PC heatsink fan?
    ProSpeed Imports -- www.prospeedimports.com -- Car parts direct from USA, Japan & Europe to your doorstep! Email us at special.requests@prospeedimports.com. Don't forget to ask about our special car wrapping, change the color of your car without changing the paint ;-)
    okaraboy's Avatar
    Dec 2006
    Okara,
    37
    436
    not a bad idea.
    moak89's Avatar
    Aug 2006
    86
    1,807
    6 Post(s)
    ********...they dont exactly provide boost...meaning they can not provide positive air pressure to the engine.
    all are the same...some just shaped better then others...heres the verdict on em
    http://homemadeturbo.com/tech_projec...wer/index.html
    www.TheTweakShop.pk
    SIG
    SIG is offline
    SIG's Avatar
    Feb 2008
    40
    105
    3 Post(s)
    Thats what website says and its my query with PW members
    The motor is Cobalt brush less that class of motors are very powerfully
    again its my Q to PW guys
    numberonebikesloverr's Avatar
    Aug 2009
    Peshawar
    43
    53
    I guess this video will conclude the discussion (myth busted):
    Electric SuperChargers Mythbusted | Tune.pk
    Naeem
