Page 9 of 9 FirstFirst ... 789
Results 161 to 174 of 174
Thread: Just some G's...
    HardTalk's Avatar
    Aug 2007
    Nice / Cannes / Eze
    32
    485
    Default Just some G's...
    This thread is a tribute to one of my favorite jeeps of all time.. the G Wagen / G Class / Gel�ndewagen. Some random facts are: - The G Wagen was built apparently because a Benz shareholder from Iran wanted a military vehicle added to the lineup. - There are only 12 G63's in the world. I'm attaching some pictures I found while surfing the internet right now, hoping you guys can add some more and perhaps share your views about the ride. Just some Gs -544293
    Just some Gs -544294
    Just some Gs -544295
    Just some Gs -544296
    Just some Gs -544297
    Just some Gs -544298
    Just some Gs -544299
    Just some Gs -544300
    Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
  2. #161
    qwertypoiu's Avatar
    Feb 2007
    29,134
    153 Post(s)
    3 Thread(s)
    Models fo G class ever built
    * 200GE - M102E20 2.0 L I4
    * 230G - M115 2.3 L I4, 102 hp (75 kW), ??? ft·lbf (172 N·m/3000 rpm)
    * 230GE - M102E23 2.3 L I4, 125 hp (92 kW), ??? ft·lbf (192 N·m/4000 rpm)
    * 280GE - M110 2.8 L I6, 156 hp (115 kW), ??? ft·lbf (226 N·m/4250 rpm)
    * 240GD - OM616 2.4 L Diesel I4, 72 hp (53 kW), ??? ft·lbf (137 N·m/2400 rpm)
    * 250GD - OM602 2.5 L Diesel I5, 94 hp (69 kW), ??? ft·lbf (??? N·m)
    * G 270 CDI - OM612 2.7 L Diesel I5 (turbocharged), 156 hp (115 kW), 294 ft·lbf (400 N·m)
    * 290GD - OM602D29 2.9 L Diesel I5, 95 hp (71 kW)
    * 290GD TD - OM602DLA29 2.9 L Diesel I5 (turbocharged), 120 hp (89 kW)
    * 300 GD - OM617 3.0 L Diesel I5 - later rebadged G 300
    * 300 GE - M103 3.0 L I6 - later rebadged G 300
    * G 350 DT
    * G 300 DT - OM606 3.0 L Diesel I6(turbocharged), 177 hp (130 kW), 244ft·lbf (330 N·m)
    * G 320 - M104 3.2 L I6, 217 hp (161 kW), 229 ft·lbf (310 N·m)
    * G 320 - M112 3.2 L V6, 215 hp (158 kW), 220 ft·lbf (300 N·m)
    * G 320 CDI - OM642 3.2 L Diesel V6, 224 hp (165 kW), 397 ft·lbf (540 Nm)
    * G 400 CDI - OM628 4.0 L Diesel V8 (turbocharged), 250 hp (184 kW), 411 ft·lbf (560 N·m)
    * 500 GE - M117 5.0 L V8
    * G 500 - M113E50 5.0 L V8, 296 hp (218 kW), 336 ft·lbf (456 Nm)
    * G 55 AMG - M113E55 5.5 L V8 supercharged, 500 hp (350 kW), 514 ft·lbf (700 N·m)
    * G 63 AMG - V12 N/A, 444 hp (326 kW), (620 N·m/4400 rpm) (only 12 ever built)
    RIP
  3. #162
    qwertypoiu's Avatar
    Feb 2007
    29,134
    153 Post(s)
    3 Thread(s)
    Just some Gs -831801
    ART Tuning released the performance kit “A55K” for the G 55 K. After optimizing the supercharger ratio and the engine management system, the engine’s output goes up from 476 bhp to an impressive 580 bhp. The torque increases from 700 to 790 Nm.
    At the same time, A.R.T. also overrides the Vmax limit. As regards the gasoline engines, A.R.T. also takes account of the G 55 (performance boost by means of a supercharger to 440 bhp and 597 Nm) and G 500 (also with a supercharger: 402 bhp; 683 Nm). In terms of the diesels, thanks to A.R.T. DieselPower, the power classes 293 bhp (G 400 CDI, 624 Nm), 261 bhp (G 320 CDI, 600 Nm) and 192 bhp (G 270 CDI, 468 Nm) are possible.
    The G-Model owes its new look to a large extent to the A.R.T. “monoART1” wheel rim in a 10x22 inch design, which is usually fitted as part of complete sets of wheels. This 10-spoke wheel rim is available in a stylish TITANIUM finish. A.R.T. also, however, offers its customers a range of different finishes. The wheel rim is fitted with size 285/35-22 tires.
    Press release after the jump.
    Press release
    For those drivers who cannot get used to the latest GL from Mercedes, it is possible to choose the predecessor, which has been constantly refined over the years from the product range of this Stuttgart-based automaker. For the all-terrain vehicle that is anything but obsolete, A.R.T. is offering a complete tuning suite that goes by the name of “PROGRAM463”. Everything from the exterior to the interior thru to the engine can be customized.
    Absolute power!
    A.R.T. boosts the performance of diesel and gasoline engines significantly. Leading the way is the A.R.T. performance kit “A55K” for the G 55 K. After optimizing the supercharger ratio and the engine management system, the engine’s output goes up from 350 kW (476 bhp) to an impressive 427 kW (580 bhp). The torque increases from 700 to 790 Nm. At the same time, A.R.T. also overrides the Vmax limit. As regards the gasoline engines, A.R.T. also takes account of the G 55 (performance boost by means of a supercharger to 324 kW/ 440 bhp and 597 Nm) and G 500 (also with a supercharger: 296 kW / 402 bhp; 683 Nm).
    In terms of the diesels, thanks to A.R.T. DieselPower, the power classes 215 kW / 293 bhp (G 400 CDI, 624 Nm), 192 kW / 261 bhp (G 320 CDI, 600 Nm) and 141 kW / 192 bhp (G 270 CDI, 468 Nm) are possible.
    The exhilarating sound is produced by the A.R.T. sports exhaust system with four 80 mm diameter tailpipes, which protrude at an angle beneath the running boards. For vehicles up to model year 11/2000, this task is undertaken by a system with two tailpipes.
    Sophisticated and sporty appearance
    A.R.T. adorns the classic angular original shape of this Mercedes classic with a number of components that blend perfectly into the design of this all-terrain vehicle. For instance, A.R.T. fits a front spoiler that incorporates an additional two main-beam headlamps and fog lamps in the form of the A.R.T. dual-integrated xenon lights (upper beam: xenon/fog: halogen; alternatively halogen/halogen). An air inlet in the front spoiler ensures optimized cooling of the oil sump. In addition, it features an underride protection guard made from mirror-finished stainless steel. The “G” cuts an even mightier figure thanks to the A.R.T. fender flares with illuminated running boards, which are particularly useful in poorly lit places such as underground garages and of course at night. Fitting these makes the G-Model 40 mm wider on each side. Designed for installation in the original trim strips are the A.R.T. stainless steel inlays, which lend the vehicle an even more sophisticated look. A.R.T. has also enhanced the lighting technology, which it has achieved with the aid of A.R.T. Premium High bi-xenon lights (from model year 11/2006; earlier A.R.T. Xenon Premium, Xenon clear or DE-Halogen Premium). In addition, A.R.T. installs an automatic headlamp range adjustment system.
    This is by no means all the tuning suite from A.R.T has to offer. Whether we are talking about protective grilles for the front indicators, a cable winch (up to 4100 kg pulling power), a front wind deflector, various trim strips, chrome trimmings for the air intakes, new rear lamps, front and rear bumpers, headlamp protection grilles, a brush guard, a roof spoiler, parking assist, underride protection or a different engine hood, A.R.T. offers an extensive product range for customizing the body.
    22 inch wheels “monoART 1”
    As an alternative, A.R.T. also offers the rim in the sizes 8.5x 18 and 10x20 inch. The brand-new rim design “monoART2” will also be available shortly in a 20 inch version.
    To reinforce the suspension, A.R.T. is offering different shock absorbers, while export customers are offered the refinement of an A.R.T. sports suspension or, alternatively, sports springs.
    Luxurious interior
    Like the exterior, A.R.T. styles the interior of the Mercedes G-Model highly individually. For instance, from the basic leather upholstery and trim through to the complete outfitting of various interior components (such as the center console) with leather, the generous use of fine wood and carbon-fiber trims through to curtain systems and carpets, there is just about everything to make long journeys a pleasant experience. It is also possible to change the color design of the interior. For example, A.R.T. offers components such as handles and fascias in the form of “Blue Eye” wood appointments.
    Sporty flair is produced by the ergonomically shaped A.R.T. sports steering wheel with perforated grips. The steering wheels are available in the combinations leather/fine wood and leather/carbon fiber. Upon request, A.R.T. will also of course install tailor-made multimedia and hi-fi systems. If need be, it is possible to equip all the door openings with blue-illuminated A.R.T. door sill trims. Also available: individual seats for the back plus armrests, a center console and storage console in the center of the rear footwell. There is no shortage of special accessories, either. Blue flashing lights (for high security vehicles), a siren, an auxiliary heater and an intercom system for talking with the windows closed and for listening to the outside sound go to complete the extensive A.R.T. tuning suite.
    Needless to say, the A.R.T. team does not restrict itself to the tuning suite described above. For drivers who wish customize their “G” in their own individual way, the A.R.T. team will gladly cater to any additional requests and, what is more, to the same highly professional standard.
    sources TOPSPEED.com
    RIP
  4. #163
    carbonclass's Avatar
    Dec 2007
    Rawalpindi
    30
    2,484
    Amazing (Y)
    Things will never be as you imagine, so you're better off not seeing them. / Reality can't compete with imagination.
  5. #164
    qwertypoiu's Avatar
    Feb 2007
    29,134
    153 Post(s)
    3 Thread(s)
    RIP
  6. #165
    HardTalk's Avatar
    Aug 2007
    Nice / Cannes / Eze
    32
    485
    The Grand Edition came with a V8 too, and a nice interior.
    Just some Gs -831816
  7. #166
    HardTalk's Avatar
    Aug 2007
    Nice / Cannes / Eze
    32
    485
    The 2009 G Class will come with the following updated specs:
    1. New grill
    2. New COMAND system (with hard disk, similar to what's in new SL-class)
    3. G500 gets new 5.4L V8, will be called G550 in the US
    4. G55 engine tweaked to 507HP
    5. G500 gets new rims, same size
    6. G55 gets new 19" rims
    7. G55 gets new Alcantara headliner standard, option on G500
    8. Improved mobile phone interface, bluetooth, and MP3/iPod support.
    9. TV tuner now supports DVB-H broadcasts in Europe
    10. Harman/Kardon sound system upgraded to Logic7 with number of speakers increased from 10 to 12, power up to 450 watts, DD/DTS 5.1 surround support added, and speed sensitive volume.
    11. Ventilated front seats now an option (badly needed in warm countries)
    12. Slightly different hood badge
    13. New designo leather front seats
    14. Tire pressure monitoring now available on SWB and Cabriolet
  8. #167
    salman_ksa's Avatar
    May 2006
    Ad-Dammam
    27
    9,331
    Nice pics guys seriously i got alot of info about G-Wagen in this thread thanks guys for sharing your views and info (y)
  9. #168
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    Hardtalk
    Great topic bro'! The G-Wagen is one of the last true 4X4s left in the world. I'd like on like this and as dirty as well :p :
    Just some Gs -832982
    As for "true" 4x4s, I have to say that light is might. A Suzuki Samurai, Jeep (the original) and the 2CV 4x4 (admittedly non-original) can give these big beasts a good run for their money on forest tracks. Plus when something gets bent, you won't be ruined financially.
    Comfort is something else of course. You wouldn't want to be in a crash in any one of these. Plus how daft would dignitaries look going around in chicken-feed smelling 2CVs.
    Just some Gs -832983
    As for our Army, they'd be better off getting Hiluxes rather than G-Wagens if they ever decide to dump the Land Rover. Parts are available everywhere, they're a lot cheaper, logistics wouldn't be an issue, and the corner mechanic can fix it without problems.
    Cheers!
    Sami
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
  10. #169
    HardTalk's Avatar
    Aug 2007
    Nice / Cannes / Eze
    32
    485
    Sami, those are some hardcore off road pictures from your end haha.. The suzuki looks rugged as hell, but as you said, comfort and all those things that make up the 'perfect 4x4' arent available.
    The Hilux is a good alternative, you're right. Toyota PK have started manufacturing single cabin Hilux's just recently - and they are widely being used by Govt. authorities in Sindh. Btw, Nissan Ghandara's been making Defenders for so long, but I've yet to see Pak Army Defenders in action. The G Wagen will be alive for a while, Benz says atleast untill 2012. Lets hope they don't revamp it into something weird like the new Defender that someone posted up earlier.
  11. #170
    boyofuk's Avatar
    Sep 2005
    29
    48
    Truly a Tribute from you guys
    Awesome work Bro's
    "Treat Your Car as a Child"
  12. #171
    Sep 2004
    35
    3,701
    8 Post(s)
    Hardtalk
    Word has been around that the GL is a replacement for the G-Wagen. I can't really believe it though. Can you picture military spec GLs? School run mummy "wagens" going to fight a war...
    Maybe it'll continue to be sold in one of the Turbo-diesel guises for the military, who knows (like the H1)? It'd be a shame to see the thing go. It's truly an icon.
    Here's something interesting to read:
    http://www.4x4abc.com/JimRogers/inde...rogers%3C/a%3E
    And MB has the nerve to say that they invented the GLK!
  13. #172
    IKJ
    IKJ is offline
    IKJ's Avatar
    May 2005
    Abbotabad
    48
    803
    Hi all...
    I had a 300GD in early 90’s.
    No doubt about it, It is one of the best 4wds I have ever had.
    I spotted a G55 in Dubai recently and instantly fell in love with it.
    The Sound is spectacular and it’s a beautiful vehicle.
    I am planning to import one to Pakistan but am bit confused as the ones available in Dubai are Left hand drives.
    I am trying to decide between the Range Rover Sports Supercharged or a Left hand drive G55.
    Lets see...................
    Obstacles are those frightful things you see when u take your eyes off your goal.
  14. #173
    HardTalk's Avatar
    Aug 2007
    Nice / Cannes / Eze
    32
    485
    IKJ: Thanks for your input, Sir. I've currently got an HSE, and for me it made more sense to get that, over the Supercharged - specially since we were buying a new car. The Supercharged is an awesome ride as well. Please note, however, that the AMG V8 - I assure you - is much, MUCH better than the Range Rover.
    (I would be so happy if you got that G55, I'm even thinking of which colour you'd get, and about the threads that would come up with people saying "G55 SPOTTED!!!!".. Inshallah )
    sami_voodoo: WHHHYYYYYYY would you say that, the truth hurts so much. Its true. The GL, is actually the replacement, according to so many sources. But I'll never admit it. Never. Thanks for sharing such an informative article.. I appreciate the fact that you always have something useful to share with us.
    For those of you who havent checked out the link Sami's posted, here's a picture which'll make you go check it out
    Just some Gs -833328
    And for our folks who scroll through the posts for pictures, here's another treat:
    Just some Gs -833329
    Peace.
  15. #174
    Konichiwa's Avatar
    Jul 2006
    2,809
    i dunno why.. and i seriously dont know why.. but being and offroad enthusiast as my self.. i can never picture myself in anything other than a G Wagen.. for me it IS.. WAS.. AND ALWAYS WILL BE THE BEST 4X4..dun care about celebrities.. dun care about the quality.. because a G will always be a G.. cant wait to get my hands on one.. time to go make dad crazy ..
    http://i.imgur.com/nMDe1.jpg
