Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
Thread: LMAO:::: Paksuzuki Quality Control....... :)
    lotus's Avatar
    Jun 2006
    3,040
    Default LMAO:::: Paksuzuki Quality Control....... :)
    was surfing the paksuzuki website and found this after reading all the stuff i just wondered how come there remains so many quality issues in suzuki vehicles.. please read it yourself and tell me
    http://72.9.157.104/~suzuki/pak_suzuki.html
    THE MANUFACTURER
    Pak Suzuki takes pride in the fact that it produces a wide range of vehicles that serve the widest spectrum of customer needs in the country. Each of the Pak Suzuki products enjoys a unique position of its own and the exceptional success of these vehicles underscores their progressive performance abilities.
    What differentiates Pak Suzuki Motor Company from other automobile assemblers is its PRESS SHOP, PSMC is the only automobile manufacturer which owns this facility. It is the major source of delivering low cost vehicles to the customer.
    Before quality product rolls out from the Pak Suzuki Plant, it goes through state-of –the art manufacturing processes under strict quality control measures.
    PRESS SHOP
    The press shop consists of the most modern stamping facilities equipped with a Tandem Press Line with more than 1,000 stamping dies. The facility of Tandem Press Line available in Pak Suzuki Motor Company renders it the status of the only car manufacturing company in Pakistan.
    WELDING SHOP
    The Welding Shop caters for welding of 7 models of Suzuki vehicles. The process consists of welding of panel parts to complete body shell through technically advanced spot welding and CO2 welding processes.
    PAINT SHOP
    The Paint Shop has the most modern conveyorised painting facility including state-of-the art Cathodic Electro-Deposition System. All transfers are automatic and spray final coat is carried out in very sophisticated temperature controlled booths and ovens. Painting of bumpers in solid and metallic colors is carried out in modern paint booths.
    VEHICLE FINAL ASSEMBLY
    The Vehicle Final Assembly comprises of 3 separate lines for trim and assembly; Car Line for Mehran, Alto, Cultus and Liana Cars/ Commercial Vehicles Line for Ravi Pickup and Bolan Van and 4x4 Vehicles Line for Potohar.
    VEHICLE INSPECTION LINE
    The Vehicle Inspection Line comprises of :
    • Toe in Tester for wheel alignment
    • Side Slip Tester to verify wheel alignment
    Drum Tester for checking any abnormal noise / engine performance and vibration.
    • Brake Tester to check braking force
    • Headlight Tester for head lamp aiming
    • Turning Radius Tester to verify turning angle
    Shower Tester for checking water leakage
    TEST COURSE
    Test Course comprises of various type of tracks for checking vehicle performance and abnormal noise on different terrains in actual conditions.
    if tc=p then hc=m where tc is equal to toyota corolla and p is equal to paindu, and hc is equal to honda civic and m is equal to moron
  2. #41
    Retrograde's Avatar
    Dec 2004
    40
    2,439
    regarding the QC tests, what ever Suzuki has mentioned just add a prefix "NO"
    Hail to the King Baeeeebay!!!!
  3. #42
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    hummmm..well its not that bad...currently own a khyber...i m very good with that
    and bought a new cutus...and ts perfect as well
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
  4. #43
    adl01's Avatar
    May 2008
    31
    903
    its time they should put serious concentration on QC otherwise they will soon be thrown out of competition
