Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 128
Like Tree71Likes
Thread: CD 70. Rate It
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    Default CD 70. Rate It
    I hv a 84 model CD 70, hv totally restore from its engine. Hv done following alterations
    1)replaced 72cm cylinder to 78cm cylinder and putted a bigger glass
    2)put a new STAR head and done sum alteration in Walls
    3)Suzuki SD110 Piston
    4)then change its Quesion gherari to 20/65 size as it will make sum performance in long run
    5)Weight Of Star wd sum alteration
    6)then cnvrtd Point into CDI kara of 125, 125 plug coil and 125 CDI unit
    7)125 Carb.
    8)38/15 spocket to hv a gud shoot in the intro. gears
    Rate this ride !
    CD 70  Rate It -591347
    CD 70  Rate It -591348
    CD 70  Rate It -591349
    CD 70  Rate It -591350
    CD 70  Rate It -591351
    My Vehicle is an ALL MOTOR. Seriously, Who needs a turbo when u have a Stupidly Quick Naturally Aspirated Motor???? Real Motors don't need Forced Induction. EG for life
  2. #61
    qureshi498's Avatar
    Mar 2009
    30
    2,180
    5 Post(s)
    FULLL ALTERRRRR!!!!lol
    Livin'Loud---->>>Solo-Baric L7 08S12L72!!!!
  3. #62
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    Aaay aya mera hawai jahaz !
    CD 70  Rate It -310556
    CD 70  Rate It -310557
    CD 70  Rate It -310558
    CD 70  Rate It -310559
    CD 70  Rate It -310560
    CD 70  Rate It -310561
    CD 70  Rate It -310562
    CD 70  Rate It -310563
    CD 70  Rate It -310564
    CD 70  Rate It -310565
  4. #63
    booster's Avatar
    Mar 2008
    30
    1,183
    9 Post(s)
    sorry to say but whenever i c such a thing on road , i feel pity for the person and sorrow for his parents.theres no point in rating it coz its already close-to-death rated.sorri buddi but thats my view.be safe bro.invest in something meaningful. a brotherly adv
    The Rules R Simple ....... U Break Them - U Die
  5. #64
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by FC View Post
    CD 70.  Rate It - 310560
    CD 70.  Rate It - 310561
    CD 70.  Rate It - 310562
    excellant mods..
    share its specs here as well,, also the peices,,and the results,,
    where u got the parts from,,
    did u changed the studds for installing new cylinder and head?
    where did u get the pipe that connects carb to the head?
    how is this silncer? is it noisy?
    a videpo will be much better,,
    no filter is installed,, y .. ?
    what pipe is used between silencer and head? is it the default bikes pipe ?
  6. #65
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    *70 engine no. piece and 124 oil pump piece
    *124 Head (Put Hard Valve Springs with Valve Washers on genuine Valve)
    *140cm Cylinder (Piston Running 150cc Semi Dome top)
    *124 Weight with 8mm high 16pin Rod stroke
    *100 Clutch Box
    *100 Gear Ghucha
    *Fabricated Steel struts as this cylinder length is bigger than 78cm and 125cm cylinder
    *Carburetor Guess karo tum log by seeing its pics..
    *Genuine CG-125 Current System includes CDI unit, Plug coil, Coil Kara, Coil plate + Pulsar
    *Sprocket matching is also a Hidden Truth
    @asjdm
    Carburetor Band pipe is genuine from this 124 head. but it can fit in E22 or 107 head.. if u want it then i can send it to u it costs only 300rs here for the new pipe
    SILENCER
    Yar basically the bend pipe of this silencer is from genuine 70 silencer and then welded the tip of VolksWaqon Foxy silencer... Yup its noisy but gives a very wonderfull noise just like foxy... the seeti tht foxy gives on removing the foot from accelerator.. if u want it then tell me complete cost on fabricating + chroming is only 700rs..
  7. #66
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    ^^excellant but no air filter is attached any particular reason..
    can u share the costs of items.
    i shared them.. to let others know about availabilty and cost..
  8. #67
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    air filter lag nahein sakta na bhai we r using this formula MORE AIR MORE FUEL BIGGER SPARK
    agr koi air filter lagao *** to woh utni air nahein day paay ga jitni hamein chahyay...
    Head 4300
    124 piece 3000
    cylinder 2200
    piston 1950rs
    Weight 3500rs
    Clutch box new CD-100 Genuine Atlas Honda 7000
    Gear ghucha CD-100 New Genuine Atlas Honda 4500
    Current System 4000
    Carburetor 2000
    Sprocket made on orders 900
    Leth wala Expenditure 2500 in which he face the piece, done the bore, piece kay mun bara kiya, struts fabricate kiya, oil pump nozzle set kara, Weight set kiya, Gear Bearings ki jaga banai, Clutch cover jaga banai..
    Total expenditure incurred = 36000 and Purchased a new bike for Rs 40000 wd Registration and insurance
    Total cost of this project
    Engine Parts 36000
    Oil seals, Packings, Gaskit 500
    Brakes, Suspension 4000
    Denters Work in Chassis 1200
    Lite Weight body 450
    New Bike 40000
    Other Miscellaneous Expenses 4000
    Rs.86450
    Firstly when this setup was made it dont work till my expectation so the fault was of weight engine opened and fabricated again
  9. #68
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    huge effort has been but into it,,excellent combos,
  10. #69
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    air filter ka lia aik spacer banavo,, and then attach a free flow air filter,, that way u will not only save ur engine fro,m extremly earlier damag but also allow u to have a sufficient power ,,
  11. #70
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @asjdm
    can u give me sum sample pic. i cant get u
    Acceleration is hell fast
    1st Gear 50km\h
    2nd Gear 80km\h
    3rd gear 132km\h
    4th gear 170km\h
    Chckd on GPS
    U cant even compare a CG or a GX to it.. Its the King in 124cc full Alter Category
    70 can go upto 250cc.. Sample pics are attached
    Not a single gear is getting fix bike baray par baray ja rahi hai...
    CD 70  Rate It -311692
  12. #71
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    sfr the spacer.adapter called 12 way manifold adapter look at the following thread especily at post 12,
    https://www.pakwheels.com/forums/bik...-pics-attached
    the carbs of 125 and cd100 has thew air side ID of 38mm i think and the cone type filters opening is also of the same size,, the cost 200 rs in new here in pindi from lifan,,
    these are discussed in the following thread,, they r very much free flow,,
    https://www.pakwheels.com/forums/bik...ter-adv-disadv
    the adapter thingy is pretty simple hope local kjharadias can make it ,, with that u will be able to rotate the carb air box side opening from he body this way u will be given more space and attach a filter,
  13. #72
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @asjdm
    any advantage of hvng air filter in bikes performance ?? for the past so many years i m using no filter in my alter bikes ....
  14. #73
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    having no air filter easily damages the engine and the intake of air is also not optimum due to the intake shape of the carb intake side,,
    also the dust particles in air not only cause an improper combustion of the gases but also reduces engine life,,
    the cone type filters has more area in the path of air so that help in drawing more air,,and that will be clean as well ,,
    if u want to really go filter free then install velocity stacks ,, i dont know if u will find them ready made but u will have to make them,,
    for more info
    https://www.google.com/search?hl=en&...0l0l0l0l0ll0l0
  15. #74
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @asjdm
    the air filter that u posted in the pic is yar OIL BREATHER or is it dual purpose.. yar i hvnt faced any problem till yet no Piston rings wastage or No Leak Valve Seals till yet... Any main Advantage of using air filter ??? yar basically my bike is not a daily driven its just for fun yar
  16. #75
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    well i explained y air filter is needed..
    if ur bike is not being used as commuter as well and u havent faced any issue then sure go the way it is.. filter less... but applying filter will save it from premature damage.. thats for sure..
    however install velocity stack then u will get some more performance... well i havent tired but most ppl say so...
  17. #76
    daniyalahmad's Avatar
    Jun 2009
    Select City
    8,435
    12 Post(s)
    2 Thread(s)
    Nice mods!
    BTW I pray ke Allah tumhe hidayat de.
    Ameen!
    One of the most difficult things in the world is to know how to do something, and to watch without comment, somebody else do it incorrectly.
  18. #77
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @Danu
    Yar fun bike hai... Not for race purposes yar ... m a seedha sadha insaan bas shauq thoray ultay hain
  19. #78
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    (Y)
    Nice mods.
    Kuch log mods ko gunah smjhty hain.
    Zruri nhn k bnda *****
    I Am the Feel
    I Am The Yamaha!
  20. #79
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @nom1
    Thanks koi to meri BHAWNAO ki qadar karta hai yar shauq hai bas bikes modify karnay ka
    @Danu
    ALLAH tumhein bhi hidayat day... 70 say upar to barho mera bhai 200 lo ya CG 80s model Genuine lo... Meri aik deal chal ri hai dkho kya banta hai 1985 Honda CG 125 in red color on Genuine Paint + Sealed Engine + Meters Working + Tyres Tube bhi abhi tak wohi hain jo company nay laga kar diyay thy 3400km used uptill now only Chroming was done 5-6 Times FUll CHAM CHAM bike.....The guy demanding 175k for this beauty dekho kya hota hai
  21. #80
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    log cars mein Engine Swaps karty hain hum bikes mein karty hain... TOTALLY NATURALLY ASPIRATED ENGINES
    @Danu
    waisy for ur info i m working on Turbo and NOS in these bikes.... koi acha Experiment nahein gaya for turbo end result Engine Head or Chamber piece broken NOS ka kamyab gaya in CG-125 and ruing like jahaz fauran fauran gear khattam kar deti hain in no time 140 par hoti hai
