Specifications:
Model
Ninja ZX-6
Engine Type
4-stroke, liquid-cooled In-Line Four
Displacement
599 cc.
Bore x Stroke
66 x 43.8 mm.
Compression Ratio
12.8:1
Valve System
DOHC, 16 valves
Carburetion
Mikuni BDSR 36R x 4
Ignition
Digital with K-Tric
Starting
Electric
Transmission
6-speed with Positive Neutral Finder
Frame type
Perimeter, pressed aluminum
Rake / Trail
23.5 degrees / 3.3"
Wheelbase
55.1"
Suspension, Front
46 mm. cartridge fork with adjustable preload, 12-way rebound damping and 10-way compression damping
Suspension, Rear
Bottom-Link Uni-Trak with remote-reservoir, gas-charged shock, adjustable preload, 20-way compression damping and rebound damping
Tire Front
120/65ZR17
Tire Rear
180/55ZR17
Brakes, Front
Dual 300 semi-floating discs with dual six-piston calipers
Brakes, Rear
Disc with single-piston caliper
Seat Height
31.9"
Fuel Capacity
4.8 gallons
