Results 1 to 12 of 12
Thread: Can i have some info????
    ibadaslam872's Avatar
    Feb 2009
    18
    6,103
    5
    49 Post(s)
    Default Can i have some info????
    hey PW's,
    sorry it might be embarracing posting this but i need to ask what is this and where is it availible and specs.....thnx:
    Can i have some info???? -614750
    Under the Coconut tree
    panicslayer's Avatar
    Nov 2008
    35
    10,044
    10 Post(s)
    It is motorcycle rickshaw. It is not available ready made but there are specialized mechanic who make it (custom made). usually used for industrial transportation and goods distribution. Mostly breads distributors use this
    Suggestions required
    Feb 2009
    18
    6,103
    5
    49 Post(s)
    ^^^are u sure..........
    shaheen69's Avatar
    Apr 2009
    Peshawar
    26
    871
    do he need to show a CERTIFICATE for oll this?
    M ASFANDYAR SHAHEEN
    Nov 2008
    35
    10,044
    10 Post(s)
    Quote Originally Posted by LIANARULES
    No im joking
    rozzzzz's Avatar
    Oct 2005
    21,923
    12
    140 Post(s)
    5 Thread(s)
    Quote Originally Posted by shaheen69
    yes any 1 using for commercial purpose will need permit if required by authorities for any commercial activity
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
    Feb 2009
    18
    6,103
    5
    49 Post(s)
    @all
    where can it be made in lhr
    generallee's Avatar
    Jun 2008
    970
    6 Post(s)
    man it is available readymade from QingQi
    http://www.qingqi.com.pk/MillenniumPlus.php
    here are the specs
    SPECIFICATION OF 100cc 4-STROKE 3-WHEELER (Millennium Plus Model)
    Max. Loading Capacity
    450Kg
    Total Length 2710mm
    Total Width 1220mm
    Total Height
    1970mm
    Front Tyre Size 2.50-17-4PR
    Rear Tyre Size 4.00-08—6PR
    Structure 4-Stroke,air cold
    Bore 50mm
    Stroke 49.5mm
    Compression Ratio 9.81
    Max.Power 6.8Kw (8500 rpm)
    Maximum Torque 8.0Nm (500 rpm)
    Starting Method Kick Starter
    Carburetor PZ22
    Ignition Type CDI
    Ignition Timing 21BTDC @ 1500 rpm to 35 BTDC 3500rpm
    Spark Plug C7HS
    Battery 12 v-2.5 AH
    Jumpshare.com - Share and view over 250 file formats online (A venture from Pakistan)
    generallee's Avatar
    Jun 2008
    970
    6 Post(s)
    and for the loader cabin as asked by poster
    http://www.qingqi.com.pk/loaderCabin.php
    SPECIFICATION OF 100CC 4-STROKE (Standard Cabin) 3-WHEELER
    450Kg
    Total Length 2762mm
    Total Width 1220mm
    Total Height
    1970mm
    Bore 50mm
    Stroke 49.5mm
    Carburetor PZ22
    Ignition Type CDI
    Spark Plug C7HS
    Battery 12 v-2.5 AH
    Feb 2009
    18
    6,103
    5
    49 Post(s)
    zuhair@thanks alot.....but whr can we buy it from in lahore
    loveshakeh's Avatar
    Aug 2009
    Hyderabad (Haidarabad)
    29
    3,221
    can i tell you the simple way go to the hero pakistan website and click on the contact us and see there phone numbers and ask them
    hero pakistan is also making
  12. #12
    generallee's Avatar
    Jun 2008
    970
    6 Post(s)
    PLUM QINGQI MOTORS LIMITED
    43-KM, Multan Road,
    Manga Mandi,Lahore
    Ph: 042-5383801-3, 5384516-7
    Email: shahalam@qingqi.com.pk
    Email: abid@qingqi.com.pk
    URL : http://www.qingqi.com.pk
    84-Mcload Road, Lahore
    Ph: 042-7231271, 7239596
    94-Lyton Road, Lahore
    Ph: 042-7320566
