Results 1 to 14 of 14
Thread: 2 Stroker bikes oil to fuel ratio!
    Muddasir's Avatar
    Apr 2004
    29
    25
    Default 2 Stroker bikes oil to fuel ratio!
    Hello Everyone, I recently restored my brothers Kawasaki GTO 110; the issue I am having is how much oil should I pour in with petrol for fuel, the mechanic said that for every Rs. 100 worth of petrol you should pour 5 rupees oil; is it correct. Last night I poured Rs. 50 petrol in the bike but did not poured oil in it. This morning when I rode the bike, the ride was pretty rough like the engine is congested or not running on its full potential; then I re-filled the fuel tank with Rs. 90 petrol and Rs. 10 oil and when I rode the bike; the ride was extremely mindblowing!
    Any input will be highly appreciated!
    2 Stroker bikes oil to fuel ratio! -1510 2 Stroker bikes oil to fuel ratio! -1511 2 Stroker bikes oil to fuel ratio! -1512 2 Stroker bikes oil to fuel ratio! -1513 2 Stroker bikes oil to fuel ratio! -1514
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Mixture %age vearies engine to enigne. Normal recomendation is 2% of Lube oil with petrol. but the best way is to use auto lube system as it precisely mix the lube oil in to fuel.Aslo the lube oil available in loose @ filling stations is not of good quality so that practice shud be avoided
    Use of good 2t oil in will also increase the performance & life of engine.
    Exploring Machines is my Passion...
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Use 10Rs Mobil oil in 100Rs fuel and 5Rs with 50Rs fuel, Thats wht i do with my Yamaha Royal, Remember running on a dry engine could prove a blundur! It can cease ur engine, Its bttr to use more mobiloil than less or no, also too much mixing wud result in white dense smoke frm the exhust pipe... so there shud a balance.
    I dont recommend Rs5 fuel with 100Rs petorl as suggested by ur machenic, u shud atleast go 4 10Rs as mentioned above.
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @mudassir first of all let do the oil pump work..........it is best mixer and a least way of mixing the oil with petrol.when u ride slow the pump mix the oil as per requirment and when u spin the throttle at half/full then it too mix the oil as per requirement so the mixing avg is diffrent and its related to speeds.....
    but if u wanna understand the manual mixing then divide ur fuel tank capasity by oil box capacity.........(approx)
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @mudassir BTW nice restoration
    Muddasir's Avatar
    Apr 2004
    29
    25
    @ RX115: Thanks for the appreciation; my mechanic told me that you should not rely on the oil pump; for if it stops suddenly and you aren't aware then the engine might cease.
    Also can you state the price for shock absorbers (Coil springs etc) of the bike; since I did'nt got them changed and they are not that comfortable
    One other question; can you perform wheelies and stunts on these kawasakis; a friend of mine said that you cannot?
    Thanx
    Muddasir's Avatar
    Apr 2004
    29
    25
    Also the exhaust/silencer of the bike is very loud and people comment that I should get it lowered; a guy told me that I should check a packing thing and see if it can get installed in the exhaust; if not then I have to get the exhaust fixed from a silencer mechanic
    @ RX115 (Faheem bhai) can you please guide me in the aspect?
    enigmatool's Avatar
    Sep 2009
    39
    236
    dear silencer main NAMDA lagta hay jo speakers ki market say easily mil jay ga, us say sound kafi achi ho jati hay, i did this with my yamaha 2 stroke 1993 model.
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @mudassir dear the original shocks r not available in the market(new)
    try to locate in junk shops u can get good one (RANCHORE LINE)if u cudnt get then try to install similer one and u can also put hydrolic shocks(botal wala)
    and the last option is chinese ones r available in the market(quite similer) for 1500/rs (aprox)
    u can also install them.
    u cant perform wheelies on kawasaki,s in high speed only can perform in 2 stroke on YAMAHA RX 115-135. due to energy induction system. which produce much power on even low rpms.....
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @mudassir yes u can low down the noice by packing........
    do u have original baffale in exhaust?
    if not then change it
    Muddasir's Avatar
    Apr 2004
    29
    25
    @ enigmatool: can you tell me what is a NAMDA and what is the cost
    @ RX115: Faheem bhai what will be the cost of Hydrolic Shocks? Also can you state what do you mean by a baffle?
  12. #12
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @muddasir yar r u new to bikes. yar namda is basically a piece of cotton jo voice ko kam kerna ya soft kernay k kam aata hay.apnay cylincer ko peechay se kholo 3 screws hon *** un ko un screw karo phir aik plate utray gi us ko utaro *** to under se 1 mizzile type ki black colour ki cheez niklay gi.......lol
    this is called baffle which actually work as a cylincer of ur bike exhaust ji tarha pitol main voice reduce kernay k liae cylincer laga hota hay.
  13. #13
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @muddasir if ur bikes sound is too hard try to roll a cotton piece on the baffale and u can also use glass wool on it too.
    yar hydrolic shocks ranchore line se 2000/2500 tak mil jain ***.
    btw
    cylincer ki voice problem ka mechanic ko bolo wo khud theek kerday ga
  14. #14
    enigmatool's Avatar
    Sep 2009
    39
    236
    @mudassir
    yar its very cheap may be 40 to 30 Rs per foot. this is mostly available to the persons who repair fridges or u can also get it from some shop from where u get the foam, pillows etc. namda is also use in speakers as well may be its available at new speakers shop .
