Results 1 to 11 of 11
Thread: can i clean the carburettor of my GS150 using Carburettor Cleaning Spray???
    mohsin_ahmed's Avatar
    Sep 2009
    Multan
    28
    29
    Default can i clean the carburettor of my GS150 using Carburettor Cleaning Spray???
    salamz! somebody plz tell me that how can i clean the carburettor of my suzuki GS 150 without opening it? can i use the carburettor cleaning sprays used for cars??? if so, then what is the procedure???
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Yes u can do it, cleaning procedure is usualy mentioned on Carb cleaner bottle.
    Steps are as below,
    1. Remove Air filter.
    2. Start the engine & warm up.
    3. Rev up engine ~6K Rpm & puff Carb cleaner direct into the air intake duct from air filter housing while remaining same throttle.( When u will puff cleaner in to intake engine RPM will goes down but keep remain on same throttle position & keep spraying with intervals & dont let the engine stop).
    4. After 7 ~10 puffs of cleaner let the engine rev on same throttle for 5~10 sec & then release the throtle.
    5. Stop the engine.
    6. Get the Fuel Cork on off position & open the drain screw & let the fuel flush in some container.
    7. When all fuel drains from Carb turn the Fuel cork in On position & let some more fuel to be drain through & then stop it.
    8. Put the Drain screw back.
    9. Put the Air Filter Back.
    Now the bike is ready to perform.
    Exploring Machines is my Passion...
    enigmatool's Avatar
    Sep 2009
    39
    236
    Bhatti sb can i do the same procedure with my yamaha 4-stroke carb?(open the drain screw) whats that?
    yamaha135's Avatar
    Mar 2009
    34
    403
    Carb cleaners are just a waste of money and time in my opinion. if the float bowl is clogged with dirt/debris where do you expect it to go apart from inside the engine itself? there is no magic wand to do that for you other than doing it manually. and carbs are a piece of cake to disassemble and assemble back, regardless of how factory sealed you expect the carb to be it will need to be disassembled to be cleaned today or tomm.
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @enigmetool
    Yes the procedure is same for all Carby machines including Car Motorcylce etc. The drain Screw is placed on bottom of Carburator on lowest position & can be trace easily.
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    i was just 2 check toppic n refer him 2 u bhatti sahab
    For Riding Jackets & Gloves, Armors, Saddle Bags, Knee & Elbow Guards etc: https://www.facebook.com/PbcMotorSport?fref=ts
    Sep 2009
    Multan
    28
    29
    @imranbhatti. Thanx alot 4 ur guidance sir
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    About two years ago I posted the same question on an American motorcycle forum and got the reply DON'T DO IT. The reason given were that carbourator spray works in a strong way and may damage some parts of the carbs along with cleaning the dust/carbon. So a better way is to open up the cabs and clean with petrol. Even using the WD40 spray is not advisable.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    yamaha135's Avatar
    Mar 2009
    34
    403
    Quote Originally Posted by 7thgear View Post
    The Rubber parts in particular can easily be damaged, be it choke plunger seals, throttle valve seals, butterfly seals, intake manifolds etc. but apparently nowadays people don't believe in advice of common consensus and rather feel their problems will be relieved by some magic wand in a blink of a second.
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @7thgear
    Thanks for the info
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^You're welcome.
