Salam,
I am having a Honda CD 70 (Breaker point model)
It came equipped with a 6 Volt wiring system which served well for almost 22 years, But now I think that its time to upgrade it to 12 Volts because of the following reasons
● The non availability of 6volt accessories like bulbs and igination coil etc.
● The Dull Headlight and Dim Indicators.
● I even had to get the brake light switch disconnected as the brake light also caused a decrease in the headlight brightness and affected the charging system.
I was planning to get all this work done by tommorow but then this idea struck my mind that I should better ask for opinion from any one who has done this or have information regarding this.
So my major concerns are :
1 What will be the things that will have to get changed excluding the battery,bulbs?
2 Im in Rawalpindi so what would be the cost of labour and the things needed for the conversion?
3 Will it be usefull or not as I want the light to be as strong as the new CD,s
Waiting for your valueable suggestions :)
Thanks in advance.
