Results 1 to 3 of 3
Thread: Harley Releases 2010 Sportster Forty-Eight
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Default Harley Releases 2010 Sportster Forty-Eight
    Harley-Davidson introduced the newest member of its Sportster line, the 2010 Forty-Eight, today at the New York IMS. Sportster loyalists will be happy to see the return of the ‘peanut’ tank after The Motor Company discontinued using the iconic tank in 2007. The 2010 Sportster Forty-Eight is the latest in H-D’s Dark Custom line, with bobbed fenders, a blacked-out engine, burly wheels and a 2.1 gallon ‘peanut’ tank.
    “With its classic bulldog shoulders stance, the Forty-Eight strikes a distinctive look and low profile that could only come from Harley-Davidson,” said Ray Drea, Harley-Davidson Senior Director of Styling. “The Forty-Eight model has a collective past life experience and broken-in look that is raw and authentic.”
    The XL Sportster Forty-Eight features a solo seat slung low at 26 inches to go along with lowered rear suspension. The handlebars bend back, not quite café racer but definitely hot rod-style, and the mirrors are under-mounted to complement the styling. The blacked-out treatment extends to the air cleaner and engine covers, chain guard, frame and fenders, so the only real chrome on the bike is the shorty dual exhaust. The meaty 16-inch black, laced steel front wheel looks straight off the Fat Bob and sits in a new fork with wider triple clamps.
    Engine – Air-cooled Evolution
    Displacement – 73.40 cubic-inch, 1200cc
    Valves – Pushrod-operated, overhead valves w/hydraulic, self-adjusting lifters, two valves per cylineder
    Bore/Stroke – 3.5 X 3.81 in.
    Compression Ratio – 9.7:1
    Fueling – Electronic Sequential Port Fuel Injection
    Primary Drive – Chain
    Final Drive – Belt
    Clutch – Multi-plate, wet
    Transmission – 5-speed
    Start – Electric
    Front fork – 39mm, 3.62 in. travel
    Rear Shocks – Coil over, preload dual-adjustable, 1.63 in. travel
    Wheels – Front 16 in. X 3 in., Rear 16 in. X 3 in.
    Tires – Front MT90B16 Rear – 150/80B16
    Brakes – Dual-piston front, single-piston rear
    Length – 88.60 in.
    Overall Width – 32.70 in.
    Overall Height – 42.0 in.
    Seat Height – 26 in.
    Ground Clearance – 3.90 in.
    Rake/Trail – 29.9-degree/4.70 in.
    Fuel Capacity – 2.1 gal.
    Oil Capacity – 2.8 quarts
    Weight – 545 lbs (dry), 567 lbs (running order)
    Price: $10,499
    Harley Releases 2010 Sportster Forty-Eight - 2010 Sportster 48
    Harley Releases 2010 Sportster Forty-Eight - 633997534503435487Sportster Forty e
    Harley Releases 2010 Sportster Forty-Eight - 10 XL1200X AF
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    han1911's Avatar
    Nov 2009
    26
    1,025
    42 Post(s)
    3 Thread(s)
    looks good and classi
    Who are you to judge the life I live? Try to walk in my shoes and you'd fall at the first step. .............. ( han1911 )
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,245
    7
    295 Post(s)
    11 Thread(s)
    9
    1200 CC and air cooled -- wow. look and side view mirrors going below the the handle bar
    I am only responsible for what I say, not for what you understand..
