@ daniyal
first of all kawasaki was a very stable bike with less vibrations, its control was far more better than yamaha royale due to more weight +stability at high speed due to disc break
if u talk abt cg , its difficult to control at 80 coz it shakes massively due to less weight/engine ratio
btw i own a ravi piaggio and it has proven to be a very stable bike i, u will nt believe its easy to control it with single hand even at speed of 100km/h no vibrations at all
gross weight of 115 kg
@ CG 125 vibration
That is just a crude guess, it has not much to do with the weight of the bike, but it's mounting on the chasis, engine's technology and also the Silenser that hinders airflow, causing famous high sound of CG & the vibration too.
Absolutely right man.........There is a Massive Vibration in CG 125 at the top speed while Yamaha Royale goes on smooth.....Secondly 125 is a bit heavy as compared to Yamaha Royale, when it goes on the top speed it's difficuilt to grasp it .... while you can capture Yamaha Royale into your knees and make it control anytime........Thanks to the slim smart frame and design on Yamaha Royale ....
@ Why yamaha is used by dudh wala's?
Royale is used by Dudh walas not due to its less vibration but simply due to its 2 stroke engine that delivers very high Tourque at low RPMs, which help overloaded dudh walas move their bikes easily without much high reving... getting a smoother ride.
If it wud have been a CG wid alot od dudh at slow speed or standing still, then they wud hav alot of jerks trying to deliver required power to the wheels, and front end of the bike wud come up making it v. uncom4table 2 control.
- Royale has one of the most durable suspension thts why its popullar in dudh wala's + its v.cheap - costs less than Honda cd70 and power wise its above than Cg125.
