Results 1 to 11 of 11
Thread: Aprilia FV2 1200 Concept bike
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
  2. 14-08-2010, 01:59 PM
    PakWheeler
    Reason
    Spam
  3. #2
    DCcoolguy's Avatar
    Feb 2009
    Sialkot
    25
    5,694
    31 Post(s)
    ye chezz!
    <BLACK SMITH>
  4. #3
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    oh mannnnnnnnn
  5. #4
    Faisal_RX8's Avatar
    Sep 2009
    Rawalpindi
    31
    1,098
    Bht Dashy bike hai yaar.
    " Hope for the best & Prepare for the worst. "
  6. #5
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    ... What is the concept?
  7. #6
    wasifali89's Avatar
    Aug 2006
    Dubai
    27
    5,077
    i think this is really weird to ride on
    (1)Austin of England, a35, 1958, 850cc,,, (2) Mercedes benz , w202, C - 180 ,,, (3) 2003 HONDA CITY,,,, (4) Triumph TRW 500cc, 1952,,,,
  8. #7
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Quote Originally Posted by abobobilly View Post
    The beastly looks, if you ask me, because I am unaware of the other specs
  9. #8
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    ^ Beasty Looks? I beg to differ.
    Hayabusa 1300CC look much more Beasty than this
    seriously ....
  10. #9
    aqibracer's Avatar
    Oct 2006
    24
    1,513
    4 Post(s)
    CONCEPT is design testing that is done before production!
    Give me some sunshine! Give me some rain... give me another chance i wanna grow up once again.....
  11. #10
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Quote Originally Posted by aqibracer View Post
    I asked What is THE Concept? Not what is A Concept.
  12. #11
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Ok..Here are the bike specs I searched the net:
    The Aprilia FV2 1200 Concept Bike
    The motor in the FV2 1200 is a 1200 cc, 90° V twin,
    A carbon fibre, load bearing frame with integrated filter box.
    The seat is supported by an aluminium beam and by two carbon fibre struts that extend into the tail and around the rear light cluster.
    It weighs under 160 kg
    The 1200 cc V twin engine is liquid cooled and boast a ride-by-wire control system. Traction control.
    A latest generation ABS
    Technical Specification 1200 Engine
    Engine Aprilia V90
    Four stroke longitudinal 90° V twin (30°-120°). 4 strokes. Liquid cooled. Double overhead camshaft with mixed gear/chain drive. Four valves per cylinder. (DOHC).
    Fuel Unleaded petrol.
    Bore x stroke 106 x 67,8 mm
    Total displacement 1.196,63 cc
    Compression ratio 12,0:1
    Maximum power at the crank 134,5 Cv @ 9.500 rpm.
    Maximum torque at the crank 10,5 Kgm @ 4.000 rpm.
    Fuel system Integrated engine management system.
    Injection with Ride by Wire control of the throttle bodies, Ø 52mm
    Ignition Digital electronic, Stick Coil integrated with the injection
    Starting Electric
    Exhaust Two in one system in 100% stainless steel with three-way catalytic converter and Lambda probe
    Generator 450 W
    Lubrication Wet sump, circuit capacity 3,2 l
    Gearbox 6 speed, transmission ratio:
    1° 14/36 (2,57:1)
    2° 17/32 (1,88:1)
    3° 20/30 (1,50:1)
    4° 22/28 (1,27:1)
    5° 23/26 (1,13:1)
    6° 24/25 (1.04:1)
    Clutch Multi-plate in oil bath, hydraulically operated.
    Primary drive Spur gears, transmission ratio: 40/69 (1.725:1)
    Final drive Chain. Transmission ratio: 16/36 (2.25:1)
    I hope it gives your answer abobility.
