Results 1 to 4 of 4
Thread: Competition for big Beamer
    lovebikes's Avatar
    Oct 2008
    Select City
    39
    1,043
    40 Post(s)
    Default Competition for big Beamer
    Have they got what is required to dethrone the present king in big bore adventure touring category.
    Present king.
    BMW R 1200 GS
    Competition for big Beamer - bmw r1200gs adventure 06 1 170
    Specs
    Engine:
    Engine Type Flat Twin
    Cylinders 2
    Engine Stroke 4-Stroke
    Cooling Air / Oil
    Valves 8
    Valves Per Cylinder 4
    Valve Configuration DOHC
    Compression Ratio 12.0:1
    Starter Electric
    Fuel Requirements Premium
    Fuel Type Gas
    Transmission:
    Transmission Type Manual
    Number Of Speeds 6
    Primary Drive (Rear Wheel) Shaft
    Wheels & Tires:
    Front Tire (Full Spec) 110/80 HR19
    Rear Tire (Full Spec) 150/70 HR17
    Brakes:
    Front Brake Type Dual Hydraulic Disc
    Rear Brake Type Hydraulic Disc
    Technical Specifications:
    Wheelbase (in/mm) 59.4 / 1508.8
    Fuel Capacity (gal/l) 8.7 / 33
    Challenger number 1
    Yamaha Super Tenere 1200
    Competition for big Beamer - 2010 yamaha xt1200z super tenere zHfkS 3868
    Specs
    ENGINE
    Type: Liquid-cooled, 4-stroke, DOHC, inline 2-cylinder, 4-valve, fuel injected, twin spark engine
    Displacement: 1199cc
    Bore x stroke: 98 x 79.5 mm
    Compression ratio: 11.0:1
    Firing intervals: 270- and 450-degree points
    Max. Power: 80.9kW (110PS) @7,250rpm
    Max. Torque: 114.1 Nm (11.6kgf・m) @6000 r/min
    Lubrication system: Dry sump, oil tank in crankcase
    Fuel supply system: Fuel injection
    Ignition system: Twin spark
    Starter system: Electric
    Transmission system: Constant mesh, 6-speed
    Throttle system: Yamaha Chip-Controlled Throttle (YCC-T)
    Yamaha D-MODE: 2 modes, Sport (S) and Touring (T)
    Traction control: 3 modes, TCS1, TCS2 and OFF
    Exhaust System: 2-into-1
    Primary Drive: Shaft
    CHASSIS
    Front suspension: Upside-down telescopic fork, 43 mm inner tube, adjustable preload, compression and rebound damping
    Front wheel travel: 190 mm
    Rear suspension: Monoshock, adjustable preload and rebound damping
    Rear wheel travel: 190 mm
    Front brake: Twin 310 mm wave discs, ABS/Unified Brake System
    Rear brake: Single 282 mm wave disc
    Front tyre: 110/80/19
    Rear tyre: 150/70/17
    DIMENSIONS
    Overall length: 2,250 mm
    Overall width: 980 mm
    Overall height: MIN:1,410 mm / MAX:1,440 mm
    Seat height: Adjustable 835-860 mm
    Wheelbase: 1,540 mm
    Min. ground clearance: 205 mm
    Wet weight: 261kg (includes full oil and fuel tank)
    Fuel capacity: 22 litres
    Challenger number 2.
    2010 Ducati Multistrada 1200
    Competition for big Beamer - 2010 Ducati Multistrada 1200 3
    Specs
    Engine
    Type: L-Twin cylinder, 4 valve per cylinder, Desmodromic, liquid cooled
    Displacement: 1198.4cc
    Bore x Stroke: 106x67.9mm
    Compression Ratio: 11.5:1
    Power: 150hp - 110.3kW @ 9250rpm
    Torque: 87.5lb-ft 118.7Nm @7500rpm
    Fuel injection: tsubishi electronic fuel injection system, Mikuni elliptical throttle bodies
    Exhaust: Stainless steel muffler with catalytic converter and 2 lambda probes, alluminium tail pipes
    Transmission
    Gearbox: 6 speed
    Ratio: 1=37/15 2=30/17 3=27/20 4=24/22 5=23/24 6=22/25
    Primary Drive: Straight cut gears, Ratio 1.84:1
    Final Drive: Chain 5.30"; Front sprocket 15; Rear sprocket 40
    Clutch: Light action, wet, multiplate clutch with hydraulic control. Self-servo action on drive, slipper action on over-run.
    Emissions
    Standard: Euro 3
    Chassis
    Frame: Tubular steel Trellis frame
    Wheelbase: 1530mm (60.2in)
    Rake: 25°
    Front Suspension: Marzocchi 50mm fully adjustable usd forks
    Front Wheel Travel: 170mm (6.7in)
    Front Wheel: 10-spoke in light alloy 3.50 x 17
    Front Tyre: 120/70 ZR17
    Rear Suspension: Progressive linkage with fully adjustable Sachs monoshock. Aluminium single-sided swingarm
    Rear Wheel Travel: 170mm (6.7in)
    Rear Wheel: 10-spoke light alloy 6.00 x 17
    Rear Tyre: 190/55 ZR17
    Front Brake: 2 x 320mm semi-floating discs, radially mounted Brembo callipers, 4-piston, 2-pad. ABS optional
    Rear Brake: 245mm disc, 2-piston caliper
    Fuel Tank Capacity: 20l - 5.3gallon (US)
    Dry Weight: 189kg (417lb)
    Instruments: Na
    Warranty: Na
    Body Colour (Frame/Wheel): Red (racing grey / black) - Arctic white (racing grey / black)
    Versions: Dual seat, ABS optional
    Seat Height: 850mm (33.5in)
    These are not the only ones, sensing the demand and popularity many other major players are planning to enter this market segment. Such as Honda with its redesigned and beefed up legendary XRV Africa Twin and Aprilia with 1200 Tuareg.
    Big Beamer has been a deserving leader so far but now with these challengers and more to come it is going to be little tough.
    One more question remains to be answered and that is have the others got what it takes to be up there. May be one of them should start looking for some one like Ewan Mcgregor and Charlie Boorman.
    I work only because it pays for three F's. Food for me, Fuel for my bike and Film for my camera.
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    chusssssssssssssssssss thread.......................
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    I would love the R 1200 GS for long rides.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    sayyedain's Avatar
    Apr 2007
    Multan
    1,345
    nice info
