Results 1 to 10 of 10
Thread: cd 70 problem
    khawajatehseen's Avatar
    Sep 2010
    27
    7
    Default cd 70 problem
    My bike doesn't start when petrol is on but it starts on reserve petrol even when tank is full. What is the problem
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Check the fuel key, maybe something is blocking the fuel flow when the fuel key is on ON position. If the fuel flow is not blocked, then nothing is wrong with the fuel key and there might be some other problem.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    My Father's Sohrab JS70 has the exact same problem. Its been 4 months, and the bike is been driven more than 4000 kilometers, but even after a couple of tunnings and check-ups, problems remains still.
    I guess there is no way to fix this problem
    umer009's Avatar
    Dec 2009
    29
    702
    there is a way to fix it , there are two jets in fuel key, one for on and one for reserve
    just remove the key from the tank when its empty , its usually done by unscrewing the key from the tank , now inspect them for any blocking and clean the jets of key
    i hope it will solve the problem , there is nothing else wrong
    such problems are usually caused by using a low grade fuel which isnt filtered properly
    daniyalahmad's Avatar
    Jun 2009
    Select City
    8,435
    12 Post(s)
    2 Thread(s)
    Not that much an issue.
    Unscrew the cork and check the upper pipe for any blockage.
    Clean it with compressed air and you are good.
    These problems are quite common because of poor quality fuel.
    One of the most difficult things in the world is to know how to do something, and to watch without comment, somebody else do it incorrectly.
    gr8_paki's Avatar
    Sep 2007
    27
    523
    @ALL Is there any problem in riding bike in reserve mode?? i was thinking to ask this question from many days but don't want to start a new thread just for this small question. I mean is it bad for engine to ride bike in reserve mode ???
    U R not checking papers so stop pointing out sp and gram mistakes.
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Quote Originally Posted by gr8_paki View Post
    Technically NO
    Logically YES ... Its also written in Bike Manual that if you drive on RESERVE then the next time the fuel tank will get empty, Reserve fuel will also be empty, means there wont be any reserve fuel left ... phir kharay rehna nehar walay pul pay petrol ka wait karne
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    gr8_paki
    There is no harm to run the bike while Fuel switch is in reserve mode except you wudnt be warn for low fuel in the tank.
    Exploring Machines is my Passion...
    Jun 2009
    Select City
    8,435
    12 Post(s)
    2 Thread(s)
    No it wont.
    The only problem that you will face is that you wont get any low fuel warning.
    gr8_paki's Avatar
    Sep 2007
    27
    523
    @abobobilly, @imranbhatti ,@daniyalahmad Thankx for the reply.
    @abobobilly ma nehar walay pull pey jata he nahi
