Results 1 to 3 of 3
Thread: 2011 Ninja 10R
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Post 2011 Ninja 10R
    2011 Ninja 10R - 11 kawasaki zx10r 6
    It’s hard to imagine that nearly three decades have passed since the first Kawasaki Ninja sportbike was unleashed on the motorcycling public (1983 GPZ900R). That motorcycle helped usher in the generation of sportbikes we enjoy today. Now Team Green is at it again, evolving the technical aspects of high-performance motorcycles with the release of its 2011 Kawasaki Ninja ZX-10R. With the introduction of this Superbike, Kawi engineers have integrated a number of technologies that make it easier to ride than ever before.
    New design digital meter:
    2011 Ninja 10R - 11 kawasaki zx10r 17
    The Ninja ZX-10R utilizes wheel speed sensors on each wheel to feed information to the traction control and engine management systems:
    2011 Ninja 10R - 11 kawasaki zx10r 15
    Specs
    Engine: Liquid-cooled 998cc Inline-Four, 16-valves
    Bore and Stroke: 76.0 x 55.0mm
    Compression Ratio: 13.0:1
    Fuel Delivery: Fuel-injection
    Clutch: Wet multi-plate slipper clutch; Cable actuation Transmission: Six-speed
    Final Drive: Chain 17F/39R
    Frame: Twin-spar aluminum
    Front Suspension: 43mm inverted Showa BPF; 3-way adjustable for spring preload, compression and rebound damping; 4.7 in. travel
    Rear Suspension: Horizontal back-link Showa gas-charged shock; 4-way adjustable for spring preload, high/low-speed compression and rebound damping; 4.9 in. travel
    Front Brakes: 310mm petal discs with radial-mount Tokico four-piston calipers
    Rear Brake: 220mm disc with single-piston caliper
    Tires: Bridgestone BT-016; 120/70R17, 190/55R17
    Curb Weight: 437 lbs.
    Wheelbase: 56.1 in.
    Seat Height: 32.0 in.
    Fuel Capacity: 4.5 gallon
    MSRP: $13,799; ABS-equipped model $14,799
    Colors: Lime Green; Ebony
    Warranty: 12-month, unlimted mileage
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    I really love to see this new model, the best one of the 10Rs ever produced, I would say.
    mubeenshahid's Avatar
    Mar 2010
    Sargodha
    25
    8,355
    31 Post(s)
    2 Thread(s)
    very nice super bike.wish to buy this one day
    Aunda Fan
