Results 1 to 11 of 11
Thread: Fluctuating speedometer
    Site Banned Follow
    Ashfaq87's Avatar
    Aug 2010
    29
    756
    Default Fluctuating speedometer
    AOA. I have a cg125 and its speedometer fluctuates by 10km/h at speed or over 70km/h. The speedometer needle is constant if i travel at around 50km/h or 60km/h. or sometimes when i see an empty road i take the bike to 80km/h and the needle is stable. but when i go constantly at high speed then speedometer starts jumping, like if i am maintaining speed of 70km/h the meter needle would keep dancing from 60km/h to 70km/h. i discovered this problem when i was going to gunjranwala this morning from GT road. can anyone guide me as to what the problem is?
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    The very same problem occurs with my CG-125's RPM Meter. It starts to fluctuate after 8k RPM ... jumps between 8-9 ... eventhough that happens occasionally, doesn't bother me. But i am only curious to know the root of this problem.
    However, Speedometer remains stable even @ 120
    I also discovered this problem on Long Route. I was going to Mananwala from Lahore. Was going @ 110-120 when discovered this problem. After a bit of observing, i noticed that needle only dances whenever i go over bumps on road. While at Stable Drive (on Clean Road with no bumps), no such thing happens.
    Site Banned Follow
    Ashfaq87's Avatar
    Aug 2010
    29
    756
    you seem to have the same problem as me, maybe one of the experts at pw can help clear this out for us.
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Quote Originally Posted by Ashfaq87 View Post
    Nope Not the same my friend. You said your SPEEDOMETER is at fault. While my problem is related to RPM meter.
    2c
    2c is offline
    2c's Avatar
    Aug 2007
    Sialkot
    12,284
    9 Post(s)
    my friend also has the same problem and i use to make so many funny comments about that.
    umer009's Avatar
    Dec 2009
    29
    702
    whether its a rpm or speedometer , both of them uses same type of mechanism the wire to rotate,
    by time the cable developes a fair amount of play(looseness) due to which needle fluctuates , solution is to replace the meter cable with a new one ,
    if problem persists also get ur meter serviced
    tayyabbaig's Avatar
    Nov 2008
    Oslo
    34
    2,706
    3 Post(s)
    Quote Originally Posted by umer009 View Post
    +1
    Site Banned Follow
    Ashfaq87's Avatar
    Aug 2010
    29
    756
    do u know where they do meter servicing in lahore? someone told me shah noor, but i was there today and hey dont have any meter guy there.
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    There are many speedo meter walas sitting in any bike repair market, get a new cable, it wud fix the problem..
    umer009's Avatar
    Dec 2009
    29
    702
    pay a visit to mcleod road there are many there
    Site Banned Follow
    Ashfaq87's Avatar
    Aug 2010
    29
    756
    thanks for the info
