Results 1 to 15 of 15
Thread: High Performance Plug Wire in bike
    mehawk1's Avatar
    May 2009
    Rahimyar khan
    301
    Default High Performance Plug Wire in bike
    Aslam-O-Alaikum!
    I want to know that does the High performence plug wire actually increase the performence of 125cc bike? if yes then how much it would cost?
    First social network of Pakistan exclusively made to provide a secure way of communication. Join now and invite your friends to www.xplore.pk
    Tabi_hawk's Avatar
    Mar 2010
    Rawalpindi
    477
    use silicon plug wire, can b bought used from a old car spare parts shop, it has a adaptability 4 extreme temperature, bt u need a vxr ignition n iridium plug too 4 achieving a great speed n pick, only changing jst cable ll nt do the trick
    UJ_36's Avatar
    Dec 2009
    Sialkot
    26
    3,211
    8 Post(s)
    2 Thread(s)
    nyce thread.......
    mehawk1's Avatar
    May 2009
    Rahimyar khan
    301
    Quote Originally Posted by Tabi_hawk View Post
    can u explain it a little more (vxr ignition)? i am using platinium plug. Is it necessary to use iridium plug?
    mehawk1's Avatar
    May 2009
    Rahimyar khan
    301
    Quote Originally Posted by UJ_36 View Post
    nyce thread.......
    thanks
    Tabi_hawk's Avatar
    Mar 2010
    Rawalpindi
    477
    I m talking abt suzuki vxr car, its ignition coil s of 12volts, generaly stock 125 contain 6 volts coil, it ll result in increase current which ll reach the plug through plug cable, so cable should b capable of accepting bigger curent, so 4 tht purpose use silicon cable prefrably 0.9mm or 1.0mm whatever u find, nw came the plug, platinum plugs r nt racing plugs. They r generaly use 4 fuel economy, iridium plugs 4 performance, both thngs cant go parallel. Means u cant achieve performance n economy at same time. So use iridium plug bt my own experience tht thre ll b no significant change in economy jst a minimal.
    Bro automobile mod s like a see-saw, one side up thn 2nd must b down, if u fit high flow airfilter, the sound ll b nt gud etc etc, if u go 4 economy thn thre ll less top speed. If u go 4 high speed u ve 2 sacrifice é fuel economy. Got it
    but dont go 4 biger coil thn 12 volts. Because it ll burn ur harnace or cdi. I m using german bosch coil, its more reliable n contains trasistor so its beter as it help maintaining curent at optimum level. Bt its botle shaped so nt easy 2 fit in 125 clasic, as u knw i ve deluxe so it easily fited inside the litle holder
    mehawk1's Avatar
    May 2009
    Rahimyar khan
    301
    Tabi can u plz tell me the price of bosch coil
    Tabi_hawk's Avatar
    Mar 2010
    Rawalpindi
    477
    Buddy it costs me about 1000rs. and man its reliable, no chances of short circuit, u can wash bike without any fear and ofcourse results r superb
    mehawk1's Avatar
    May 2009
    Rahimyar khan
    301
    is there any common name for silicon plug wire or specific company through which local shop keeper can understand it
    Meeteepao's Avatar
    Mar 2005
    29
    178
    Hey Tabi!
    I also have a Deluxe. Did the wiring+spark plug mod improve you're Deluxe's performance? If yes, how? And where can I find all the stuff you have mentioned in Pindi?
    Rollin' on a hundred chromed spokes
    Tabi_hawk's Avatar
    Mar 2010
    Rawalpindi
    477
    @ meeteepao
    if u r in pindi/isd, its better 2 meet sum day. Thn ride my bike n see da difrence if u find. Also u ll luk at da cable, coil n their fiting etc by urself. Coz seeing s believing
  12. #12
    Meeteepao's Avatar
    Mar 2005
    29
    178
    @ meeteepao
    Sure man ... lets meet up. Let me know when you are available and I'll give you the contact details. I'm free these days. Lets meet up at 7th Avenue
  13. #13
    Tabi_hawk's Avatar
    Mar 2010
    Rawalpindi
    477
    Quote Originally Posted by Meeteepao View Post
    PM me ur contact number, i can meet u after 6 in the eve on any day coz of my job but i ll tell u couple of days before
  14. #14
    jawadsadiq's Avatar
    Sep 2009
    26
    57
    Default @ tabi
    thanks for sharing the great info.
    bro can this all stuff done on 70cc bike....????
    if yes then will the procedure be the same as for 125 or not....????
  15. #15
    Tabi_hawk's Avatar
    Mar 2010
    Rawalpindi
    477
    Quote Originally Posted by jawadsadiq View Post
    BRo its almost impossible to find iridium plug for 70 but if u want it would be a great, but do not go for 12volt coil coz it ll burn ur harness and effect ur cdi system, use 6 volt coil
