Results 1 to 19 of 19
Thread: CR8E Plugs Required
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Lightbulb CR8E Plugs Required
    The recommended plugs, I came to know, for my bike are NGK CR8E. Then the search started and on a thread on plugs here on PW someone mentioned that CR8E plugs come with Suzuki GS150, which I later got confirmed from our fellow member amjadch from Islamabad.
    I had been to Lahore yesterday, kept on looking for the plugs on several shops but they had no GS150 plug with them. Finally I found a Suzuki 3S centre and asked them for the CR8E plugs as come original with the bike. The person there showed me the original plug which he said comes fitted with the bike from the factory, it was not an NGK plug but some HD something by Denso.
    As I reckoned from the situation the person on the Suzuki centre didn't even know if a plug called CR8E existed, he said that its the Denso plug which was given to us by the dealer and the same plug is used in both 150 and 125 Suzuki bikes. I went to Suzuki centre near Lakshmi chowk, I am not sure what that market is called but there were several bike accessory shops and sale points there.
    Long story short, I have not been able to find the CR8E plugs, still looking for them. Can anyone mention any shop in Lahore or Rawalpindi/Islamabad where I may find this plug??
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    rashed.iq's Avatar
    Nov 2009
    174
    CR8E is copper plug from ngk japan.If you are interested in iridium plug,you can use xtreme sport XS4303 from autolite USA.
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Actually I am looking for the CR8E plug at the moment. Currently I have C7HSA plugs on the bike as is used in CD70, but this plug has a shorter head length, means the combustion is not taking place at the ideal place.
    I am posting a pic of both the plugs below:
    C7HSA Plug:
    CR8E Plugs Required - C7HSA
    CR8E plug:
    CR8E Plugs Required - CR8E
    rashed.iq's Avatar
    Nov 2009
    174
    The picture you have given is not CR8E,it is CR8EIX which is iridium.autolite is exact replacement of both.check autolite.com for information
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    the denso equivalent would have a heat range of 24 - take a look at the plug and see if it matches the CR8E length - if yes - buy them.
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    @Xulfiqa
    The Denso plugs I saw had the bigger head size, same as CR8E plug, but I didn't buy the Denso one thinking that it might have a different heat range. Denso are also produced in Japan but I think the Denso I saw at the Suzuki outlet were Pakistan made, which of course would be no match to the Japanese product.
    It seems that Suzuki has replaced the CR8E plug for Denso one. Just wondering what might be the cause.
    Tabi_hawk's Avatar
    Mar 2010
    Rawalpindi
    477
    @7th gear
    raw1 s rite 7th gear. Copper core plug s gud thn normal bt les durable as iridium or platinum. If u want autolite extreme iridium plug, i ve it 4 u. I can courier. These metals have very
    high melting points and resist
    corrosion and fouling. So they last
    much longer in this very harsh
    environment. As a result the plugs made
    with these metals do not have to be changed very often, and they continue to
    provide an excellent spark for
    ignition.
    Iridium and platinum plugs last a LOT
    longer in service than copper core plugs.
    So spending extra for the iridium plugs will yield you a longer service
    life and you don't have to have
    anything done to your plugs for a
    long, long time. These were the aspects
    of durability. Iridium is the hardest
    element so far discovered, then platinum. Now Talking about
    Performance
    Iridium plugs resulting in less
    misfiring and no spark, the outcome
    being a dramatic improvement in
    combustion. It ll increase pick as well as top speed. I m using Iridium and due to which i was able to reach 120+ on
    deluxe. I m contented and thts y i
    recommended to all fellows. Its the rite plug 4 u. Coper core s far less durable thn iridium. If u r interestd thn u can contact me. Thx...
    https://www.flickr.com/photos/122285329@N03/
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    double check the entire plug number - and ask the parts guy to cross reference it in his parts book. If the plug performs nicely in a single cylinder high compression motorcycle like the GS150 it'll be good for your application too.
    Tabi_hawk's Avatar
    Mar 2010
    Rawalpindi
    477
    @7th gear
    the recomended plug s autolite XS4303. Its cost s 850, if u wish 2 purchase thn pm me
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @7thgear
    Sorry for replying too late. Yep its true that Suzuki Uses CR8E with their GS 125/150 bikes. but couples of years back they were short in market & even Suzuki service center was not having those in stock. After that they change the OEM Plug brand from NGK to some other (may be Denso) So that may be a good replacemnet of NGK CR8E but you need to check specs of both these plugs for 100% compatabilty. But in case if its not 100% identical wid NGK CR8E even than Denso spark plugs used in current Suzuki GS series wud be far far better than of C7HSA.
    Exploring Machines is my Passion...
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    The Service manual for GS 125/150 recomends NGK CR8E or Denso U24ESR-N to be used with these bikes.
    However below Cross refrnce manual says that NGK CR8EH-9 can be replaced with ND (Nippon Denso) U24FER9
    SPARK PLUG CROSS REFERENCE
  12. #12
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Quote Originally Posted by Tabi_hawk View Post
    @7th gear
    ignition.
    Performance
    Thanks for that info. I have been using C7HSA on my bike all this time till I came to know of the recommended CR8E. I don't know much about iridiums but on some site I read they have cons to them as much as pros, so right now I am looking for the proper plug.
  13. #13
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Quote Originally Posted by imranbhatti View Post
    Thanks for the valuable information brother. I am not sure but I think the Denso plug was same as you have mentioned above. Means I'll be going to the same shop again
  14. #14
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    I am also looking for this kind of plug wrench. Where can I find it?
    CR8E Plugs Required - spark plug wrench 1
    CR8E Plugs Required - 70916
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    any tool shop will have this tool
  16. #16
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @7thgear
    If u r seeking this tool to be used for opening spark plugs of ur FZR then i doubt if it can deliver apropriate torque to open & close the plug.
  17. #17
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    @7thgear
    Yes I intend to use it for FZR plugs, the normal shape wrench makes if difficult to open and put back the plugs since the whole place is so congested, the good thing about this wrench shown in pics above is that its grip can tilt to one side and it becomes easy to open the plugs. My mechanic had this plug, made it look so easy. I have been looking for this plug wrench for some time but could not find in my own city nor Sargodha. Now will look for it in Lahore.
  18. #18
    mirzahamza's Avatar
    Sep 2012
    go to bilal gunj at back side of DATA DARBAR there are tool shop there could u find this plug opener
  19. #19
    asad01's Avatar
    Sep 2008
    Abbotabad
    53
    326
    6 Post(s)
    I have a Suzuki GS150 since May/June 2008, it came with DENSO U24ESR-N. I used an NGK CR8E after replacing the perforated carburettor diaphragm. It was not as good as the Denso U24ESR-N. So I bought Denso from Suzuki Showroom and it is much better. I am not saying Denso is better than NGK, its just my observation that in Pakistani markets NGK has multiple levels of quality and fakes, whereas Denso doesn't. You should buy it from Suzuki showrooms only, with SGP logo on the cover.
    Possible spark plugs for NGK CR8E:
    Aprilia 297921
    Aprilia 297920
    Autolite XS4303
    Autolite 4303
    Bosch UR2CC
    Champion RG94C
    Denso 4126
    Denso U24ESRN
    Denso IU24
    Denso U24ESR-N
    Denso stk 4126
    Honda 98059-58816
    Honda 98059-58817-00
    Honda ZH980-004-000
    Honda 98059-58816-H0
    Honda 98059-58916-00
    Kawasaki E92070-1169
    NGK stk 1275
    Splitfire SF430C
    Suzuki 09482-00456
    Tacti V91104126
    Torch B8RC
    Yamaha 94703-00411
    Yamaha 94701 00330
    Yamaha 94700-00411
    Yamaha 94701-00411
    Yamaha 94703-00330
    Yamaha 94700-00330
    Yamaha 94701-00330
    Yamaha 94703-00329
    Edit: Sorry, I didn't check the original post date.
    Asad
