Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Please Help!!!!!!
    gr8_paki's Avatar
    Sep 2007
    27
    523
    Unhappy Please Help!!!!!!
    A.O.A
    My GS 150's self is suddenly stop working, when i press the button it sounds like "Tik... Tik" and that is all no response from engine, i am using dry cell battery 12v-7amp self was working fine earlier on same battery. Can anyone tell me what is the possible fault??
    And tell me if you know any expert electrician who can fix this self prob in Karachi.
    U R not checking papers so stop pointing out sp and gram mistakes.
    YamahaYB100's Avatar
    Sep 2010
    28
    1,165
    16 Post(s)
    Quote Originally Posted by gr8_paki View Post
    A.O.A
    1st check motor connections are they tight? then battery voltage with multimetere then check carbon brushes in self motor or check button is there carbon in button points and self sproket are chain drive which is use for twist the crank. in main se koi problems ho sakti hai.
    gr8_paki's Avatar
    Sep 2007
    27
    523
    battery voltage is ok, carbon brushes in self motor are new installed genuine recently,
    now can you please elaborate these points " motor connections" , "check button is there carbon in button points and self sproket are chain drive which is use for twist the crank". lots of thankx for your kind reply.
    gr8_paki's Avatar
    Sep 2007
    27
    523
    @ALL
    That tick tick sound is comming from under the seat. WHAT could be the possible fault???
    Sep 2010
    28
    1,165
    16 Post(s)
    motor connections means self wires positive and negative ,button point mean self button also check it and self sproket is used to rotate the magneto. and under the seat i cant say any thing.
    asjdsm's Avatar
    Apr 2009
    30
    3,466
    57 Post(s)
    3 Thread(s)
    cdi unit may be loose,, i also face same kar kar problem whenever i hit any bumps on road,,, jis din time mila seat utar ka cdi unit ko dobara laga don ga,, its just loose,,
    gr8_paki's Avatar
    Sep 2007
    27
    523
    @asjdsm if cdi is loose bike will start normally or will not start by kick??
    asjdsm's Avatar
    Apr 2009
    30
    3,466
    57 Post(s)
    3 Thread(s)
    dear as far as my bike is concerned it stars on first kick,, actually the connections to the unit are ok ,, but the rubber strap that holds the unit onto the place is worn out so its just jumping in the small place where it is placed and obviously with time the connections may go loose and break some conductors resulting in weak spark or no start altogether,, ,, just chek there may be the air filter casing underneath seat to make surew that that is ok..
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    A.O.A
    Does the self go properly, i.e. does it sound as usual? Does it start ok on kick? If not, then make sure that current is passing onto the engine.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Also make sure that the cables on the battery ends are not loose.
    umer009's Avatar
    Dec 2009
    29
    702
    the "tick tick" sound heard under the seat comes from the "relay" which operates the self , relay switches the self wenever u press the start button , the sound always come but normally u dont hear as the bike starts instantly after pressing the self
    coming sound indicates the relay is operating correctly ,but there might be a chance it is not receiving proper voltage due to lose connections at battery side
    1.try replacing the battery with some other one
    2.if problem persists check ur self for weak carbon brushes
    but according to me ur battery might be culprit
  12. #12
    gr8_paki's Avatar
    Sep 2007
    27
    523
    sounds as usual, Bike starts in one kick.
    changed the clips to new one but still only tick tick.
    1-will do it and check
    2- Recently installed new genuine carbon brushes hardly used self 20 times after
    installing new carbon.
    @ALL thankx everyone for your quick replies
  13. #13
    gr8_paki's Avatar
    Sep 2007
    27
    523
    @ALL one more thing to ask does the battery charger of my bike can cause this prob too???? by not charging battery properly causing low voltage ???
  14. #14
    gr8_paki's Avatar
    Sep 2007
    27
    523
    @ALL I showed my bike to an electrician near my house and he said my gs's self is jam he used his own battery to check.Now what does that mean 'self is jam'.
  15. #15
    asjdsm's Avatar
    Apr 2009
    30
    3,466
    57 Post(s)
    3 Thread(s)
    dear i think u should search for shop manuals and repair manuals of suzuki gs bikes,, and that will be very handy in daignisin the issue,, try youtube and try searching in variouas other forums
  16. #16
    umer009's Avatar
    Dec 2009
    29
    702
    well simple thing , u installed recently new carbon brushes , so the mechanic who installed them knows wat he did while fitting
    maybe the bush is jam inside or it may be the improper fitting of brushes causing the problem
  17. #17
    gr8_paki's Avatar
    Sep 2007
    27
    523
    @asjdsm bro i tried to search any manual abt these things but couldn't find, also you didn't update your thread abt manuals.
    @umer009 You were right bro, brushes were not fit properly and got stuck i got this prob solved by another electrician and now he told me that "self ka armature tarha hoo gaya ha" can you or anyone tell me will it get fix or i have to buy a new self???
    thankx a lot everyone for bearing my soooo many questions and replying them quickly.
  18. #18
    Sep 2010
    28
    1,165
    16 Post(s)
    [QUOTE=gr8_paki;2681982] i got this prob solved by another electrician and now he told me that "self ka armature tarha hoo gaya ha" can you or anyone tell me will it get fix or i have to buy a new self???
    QUOTE]
    dear agat armature means rotor tairha ho jaye to ye rotat nahin kare ga agar rotor ghoom raha hai to dont tense its ok and wo banda bas tumhari pocket halki karna chahta hai lolx
  19. #19
    elden's Avatar
    Feb 2011
    Houston
    64
    I think people should always think....His Features and best selling model in the market.
  20. #20
    gr8_paki's Avatar
    Sep 2007
    27
    523
    @ALL today i checked with the battery of coure bike start in half self, so i think that the prob is with 12v-7amp battery , now i will go for 12v-12amp battery hope this will solve the issue.
    @YamahaYB100 Bro thank you v.much for the reply and the no. so kind of you.
    @elden Sir one gs 150 2006 model is performing very well with my frnd as it was bought new and the owner(my frnd) always take care of it's regular maintenance and it's everything is still just like new. The one i'm discussing above is bought by me few months back used 2006 model and only i know how rudely the previous owner of my bike used it that is why my bike is having some small issues nothing big, these issues are nothing as compare to the way my bike being treated but i got it dirt cheap.In short it's the best bike available in the market right now.
