Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By razaksyed
  • 1 Post By junaidakhtar01
Thread: doing rejetting but cant seperate main jet from needle jet,so need a new needle jet,
    asjdsm's Avatar
    Apr 2009
    30
    3,468
    57 Post(s)
    3 Thread(s)
    Default doing rejetting but cant seperate main jet from needle jet,so need a new needle jet,
    hi i want to do re jetting,, as when i go to murree my bike loses all its power , i checked its spark plug it was very oily, so it was an indication of running very rich,, to lean it i tried the needle clip but that didn't worked,, i would need a new jets of smaller size to lean the mixture ,, so i bought 2 main jets of size 68 and 75 ,, currently it is 78, and hondas 70 have 72,, mine is dhoom and it has 78,, but the problem is that i cannot take out the main jet out ,, it seems that mine main jet and needle jet { jis ma main jet fix /screw in ho jatha ha] are a single unit,, i,e they cant be separated. so i need that needle jet so i can place a different sized main jet in it,, i cannot find in islamabad , so any PINDI brother who has to pass through waris khan can please check for its availability, i will go there to purchase it myself,, kionka pahla confirm ho jaya ka available ha tho ma khareedna chala javo ga,, else mera waha jana nai hotha,, tell me where is it available and how much itcosts, i badly needs one,,
    extremely thankful to u,
    doing rejetting but cant seperate main jet from needle jetso need a new needle jet -233550
    as u can see it,, jitna part mera nakhun tak ha wo main jet ha,baqi ko needle jet boltha hain,jis ma main jet fix hotha ha, ,, needle jet ko i think desi vocabulory ma petrol jet ka tube b kahtrha hain,, bqi carbs ma dono alag ho jatha hain,, but mera nai ho raha,, mujha ab ya tube chaia taka ma different size ka main jets iss ma laga sakoun,
    doing rejetting but cant seperate main jet from needle jetso need a new needle jet -233551
    doing rejetting but cant seperate main jet from needle jetso need a new needle jet -233552
    doing rejetting but cant seperate main jet from needle jetso need a new needle jet -233553doing rejetting but cant seperate main jet from needle jetso need a new needle jet -233557
    this is what a needle jet loooks like,
    razaksyed's Avatar
    Jun 2004
    Kabul
    47
    1,003
    Well this is supposed to be a unit jet and must be replaced with the one offered by the manufacturer. Improper jetting can potentially lead to engine heatup issues. Go to the nearest authorized spare parts dealer and pull out the parts list to check stock configuration. Woud be a good idea to change all the jets, try sourcing a carb repairing kit. DO NOT tamper the jet by passing a copper thread, it will surely lean the mixture but adversly impact air fuel ratio.
    junaidakhtar01's Avatar
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    bhaijan aik cheez aati hai CARB CLEANER bike ki market mein nai car spare part walon k han mil jaye ga
    aainda kabhi koi grbr ho to carb kholne se phle
    use that carb kholne ki zaroorat nai paregi inshaAllah
    How to Clean a Carburetor | Motorward
    PakWheels Forums - dada8819's Album: SUzuki GS750 - Picture
    warna petrol filter use kijiye
    aur agr zada mutmain hona ho to fuel tank mein isi dal do lining aur carb sab bhtr hojayga
    Toolmonger Blog Archive Cutting Through The BS: Fuel Additives
    asjdsm's Avatar
    Apr 2009
    30
    3,468
    57 Post(s)
    3 Thread(s)
    thanks dears i got the needle jet but its bleed holes were different the the stock one and bike wasnt running good,, so tried my best and soaked it in wd40 and then it opened easily,, so now i can easily rejet it,, by the way earlier it had 78 keihin jet an wasnt able to tame the engine at other jet sizes of 72,75,80 so had to revert to 78,, it may help at places of higher elevatioin to install a small jet ,, when iu do it i will inform u ppl,
