Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By imranbhatti
Thread: Are 5 gear transmission available for 70cc??
    h3llzang3l's Avatar
    Jan 2011
    Multan
    76
    Question Are 5 gear transmission available for 70cc??
    Someone told me that in Karachi 5 gear transmission available for 70cc bikes with some change clutch box (I think he told me about QINGQI 100cc clutch box).. Is it true.. Any one knows about where I can find …
    h3llzang3l's Avatar
    Jan 2011
    Multan
    76
    39 views but no replies
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Cylinder/head & weight of some 100 cc cubengines can be fitted in 70CC block with minute changes so may be the 5 speed gear if exists in 100CC engine wud be able to fit too.
    First find such engine & than phisicaly inspect from outer side if its seems identical if yes than next task is to be done by some expert mechanic but still i dont think it wud be easy or bolt on type job.
    Exploring Machines is my Passion...
    h3llzang3l's Avatar
    Jan 2011
    Multan
    76
    is there any way key Gear Girrari change hoo sakti hoon... tak key acceleration barh jayee... without changing the Piston size...
