Results 1 to 4 of 4
Thread: size of the carb venturi in relation to intake size,ideal chosie of carb
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    Question size of the carb venturi in relation to intake size,ideal chosie of carb
    HI
    i got a question.. i have heared that the size of the carb venturi should be exactly of the same size of the intake.. today i measured the intake of my dhoom bike it was 22mm and the carb venturi was 16 or 17 mm .. which is very less .. i checked china carbs for replacement but they were all 17 mm ..
    i also checked the size of honda cd 100 carb it was 22 mm .. i.e. exactly of the same size as the engine intake .. so what are ur words on this issue.. i have heard that to reduce fuel consumption a venturi of smaller size should be used.. and to have an excellant torque a venturi size should be a match to intake..
    so any advice ? any one who have either tried or can try this ? if it works i will purchase a 100 carb.. that one costs 1300 and the shopkeeper said it is genuine.,, and no chaina carb is available in 100 catageroy.. so is it true?
    cause a 125 china carb costs 800 rs and 70 china maal costs 600 rs..
    also what are ur words on a autotec carb for 70cc ? if one buys which one should one go for crown lifan ? future ? autotec ?
    i will be very thankful to u people if someone could get any input..
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    now here is the video where i heard that how much should be the size of the carb venturi in relation to the engine intake ..
    wajoodjam's Avatar
    Sep 2010
    74
    crown lifan is best among all chines carb.
    did check the honda 70 carb?
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    dear i have to say that crown lifan carburetor is the worst ever carburetor .. its float are extremely poor..
    any how i have seen some 70cc bikes having a 100 cc carb by default as an example here is a snap of jialing...size of the carb venturi in relation to intake sizeideal chosie of carb -244509
    size of the carb venturi in relation to intake sizeideal chosie of carb -244510
    size of the carb venturi in relation to intake sizeideal chosie of carb -244511
