Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 44
Like Tree32Likes
Thread: Self Tuning Your Bike Carb
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Smile Self Tuning Your Bike Carb
    Hi guys..
    Was searching for info about how to tune your bike urself and got accross this article which looks quite comprihensive.
    Thought of sharing it since alot of us are tired of stupid mechanics messing up our bikes again n again...
    Here it goes:
    "Dear Biker,
    • Are you tired of cold starts? Need to raise the throttle everyday to get the cold engine running?
    • Does someone have the same bike as yours and are you tired of losing to him in drag races?
    • Suddenly, the fuel efficiency has reduced after a service?
    • Has the mechanic has screwed up your tuning?
    • Engine gives hiccups when you open the throttle?
    • Or your bike is just missing that smooth acceleration whenever you want?
    • Or your engine overheats even if you did not race too much.
    May be the following will help you in tuning your mean machine for optimal power delivery and best fuel economy. This guide aims at tuning the fuel/air screw to give you an optimal air-fuel mixture. An optimal mixture gets maximum performance from your machine.
    Getting The Basics
    I am assuming that you know driving very well and have completed at least 1000kms on road. If not, then you are too amateur to read this guide.
    Every bike has a engine (motor/mill/muscle) and a carburetor (breathing system/heart) Self Tuning Your Bike Carb - icon wink – Yeah I know that. My point is, I assume that your engine is in perfect condition. That is, there is no oil leaking from it etc etc.. The next assumption is that your engine is not DEAD. You know where your engine is and where your carb is Self Tuning Your Bike Carb - icon wink and you have a screw driver/blunt knife with you. Your machine must have finished at least one service ~500kms or more. Also make sure you do not change the fuel type while tuning i.e. Power, Speed, Extra premium, normal unleaded etc.
    This Guide Applies To
    All the single cylinder bikes, 2 stroke or 4 stroke having a carburetor. Tachometer is very handy and a must for a newbie or the tuning process will be very slow or painful or imperfect.
    Disclaimer: Though whatever I have written here wont do any damage to your machine, finally you must not blame me for whatever happens. I am here to help if anything goes wrong.
    So Lets Get Started
    Warm the engine nicely. Go get a ride around the town. Speed nicely at least upto half the top speed of the bike. Drive at least for 10-15 minutes so the engine system warms up nicely or you’ll get a bad tune. Do not just leave the engine idle and start with process. I mean it. Ride the bike.
    Now that the engine is adequately heated up, you are ready to begin with the process. You can select a place far away from the city or your residential area so that you do not disturb the tired, sick, disgusted, old people or babes (babies) living in your colony. You are likely to be shooed away from them when you are at a critical point. You may choose a place near your girl friend’s house just to impress her! Put the bike in main stand and get hold of your screw driver. That is all you need, together with your eyes, brains and ears.
    Searching the fuel/air screw… The above mentioned screws are responsible to adjust the air-fuel ratio which forms ‘food substance’ for your engine. You can relate it to our human body, where proteins, carbs, fats, water etc all are required in appropriate proportions with respect to each other for good strong body.
    There is another screw which sets the idle speed of the machine. This screw is not related to pickup or mileage. It just sets the engine rpm at ’’idle’’ run. 2stroke machines have an Air screw and 4 stroke machines have a Fuel screw. I hope you note this VERY well. Air screw is located on the carb away from the engine. [ Engine - Carburettor - Air screw]
    Fuel screw is located on the carb but its near the engine. [Engine - Fuel screw - Carburetor]. If the make of your carb is Mikuni (Pulsar, Yamaha, Fiero) the fuel/air screw probably will be of brass (golden colour). If you fully unscrew this screw and take it on your hand, you will see a needle like tip.
    Idle screw is closely linked with the throttle cable. Idle screw can be turned by the hand. Screw driver is not essential for it. Finding these screws are very simple. If you still cannot find the air/fuel screw, ask your mechanic or I can help.
    Ok now what? Apart from the above difference I gave between Air and Fuel screw, there is one more major difference. Fuel screw turned in (clockwise) gives a lean mixture and turned out (anti-clockwise) gives a rich mixture. Air screw turned in gives a rich mixture and turned out (anti-clockwise) gives a lean mixture. Lean means more air, less fuel. Rich means more fuel, less air. This ends the basics.
    Getting Things In Action
    Turn the idle settings screw so that rpm reaches about 3000 rpm. Now tune the air/fuel screw to make the mixture leanest as possible. Please refer to the above whether you must turn the screw clockwise or anti clockwise.
    As you make the mixture leaner, slowly the engine RPM decreases… Go on doing this until you have put the fuel screw to the leanest possible point. At the same time, ensure that the engine does not stall, by turning the idle-screw.
    Tough huh? You’ll get used to it Self Tuning Your Bike Carb - icon wink
    OK the engine is running and the mixture is lean. If you notice from the engine sound OR if you see the tachometer, the engine RPM will not be steady at this point. Now very slowly start turning the fuel screw anti-clockwise, quarter to 1/8th turn at a time. You will notice that the RPM increases slowly and steadily. Again, do this very very slowly. Also count the total number of turns as you wind out the screw.
    You’ll notice that when you have turned it to about 3-4 full revolutions, the engine RPM slowly becomes constant. It is this point that you must stop screwing more. This probably is the optimal setting for your engine.
    Further on, try turning the screw even more and more to 5-7 revolutions and you’ll notice that the engine RPM will slowly decrease. When this happens, you are just putting in a too rich mixture in your engine. At this point the engine loses all the fuel efficiency and the mixture is not optimal. Repeat the process about 2-3 times. Count the revolutions each time and get the setting which you feel is correct.
    OK the engine is humming perfectly, now what? Decrease the idle setting screw to about 1000rpm in the tachometer. When the engine slows down, just twist the throttle. The response should be crisp and quick. It should not give any hiccups! Try shutting off the engine and restarting. The engine MUST start in a single kick or self with out giving throttle. If this happens, the setting is ok. Now get a ride and you’ll notice the difference for good or bad Self Tuning Your Bike Carb - icon smile
    You’ll immediately notice change in the engine sound and the throttle response. Your engine can become more smooth or harsh. Another important point is, Ride and Feel. Always take a ride and get the feel of the bike in each gears, check the response and the engine sound. You’ll quickly come to know once you get the feel of the bike that you want to make the mixture rich or lean.
    It may take a few iterations before you fix a setting as permanent. Try calculating the mileage per liter and tally it with your setting and the feeling you get.
    Troubleshooting
    “Ahwini, I messed up my tuning because of you!”
    Here are some symptoms and their quick solutions:
    • Engine dies while tuning.
      Try the process all over again. This time set the idle screw higher/faster.
    • Engine gives hiccups while driving, specially while in higher gears.
      May be the mixture is too lean. Try again.
    • Engine heats up.
      The mixture is too lean or too rich. Try again.
    • Whenever I race up the engine, the rpm increases fast but very slowly comes down to idle.
      The mixture is not optimal, probably towards leaner side. Try again.
    • Too much low end torque and the engine sound is very beaty/thumpy.
      You’ll face a low mileage surely, when you drive below 40kmphr. You have tuned on the higher/richer side."
    Source: How To Tune Your Motorcycle For Performance and Fuel Efficiency
  2. #21
    msj4u's Avatar
    Jun 2011
    7
    Post
    Nice and informative thread
    But have questions regarding 4 stroke 78 cc engine
    1. Does tightening the rpm/idle screw affects the average mileage ?
    2. If I tightens the mixture screw what exactly is increased or decreased ?
  3. #22
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by msj4u View Post
    Please do make a movie cause I am also a victim of a mechanic and want to learn this art as well
    Thanks in advance;
    i have made a video .. it is 15 minutes i think but hell it is in twi parts 7 minutes each i think but the size is very large ,, always get error during youtube upload,, will make some more videos,,
  4. #23
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Moving the Fuel screw clockwise wud decrease the fuel supply...
    Moving it anti clockwise wud increase it.. as mentioned above.
    Tuning a bike wid bad or irregular current supply is a big problem so better nt screw it up... try tuning it after the current problem is ensured to be Ok.
  5. #24
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Not much difference on milage... Incresing the Rpm too much wud result in a lillte uselessly hot engine, and wud basically spoil ur engine oil before time. otherwise Rpm is a relatively harmless thing to adjust...
    Increase the rpm to the desirable limit where u bike doesnt stalls (turns Off) whle idling...
    the small screw is for fuel adjustment. Bigger is for RPM
  6. #25
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    ^^ wrong bro
  7. #26
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    what? how
  8. #27
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    actually that screw controls air not fuel and by usin air it controls fuel.. in a way u r rite but its again a bit tricky issue
  9. #28
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    According to the article posted above all 4 strokes control fuel, not air!
    Im sure Yamaha royal that i had, used to have an air screw... as its fuel was adjusted thru its drums and needle valve setting... thts probably the reason once mishandled royal always gets over and drips fuel out even when standing turned off....
  10. #29
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Bump!
    For a helpful thread!
  11. #30
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    @ asjdsm R.I.P Video Ustad Ji
    Dream is not that which you see while sleeping it is something that does not let you sleep.
  12. #31
    Badshahsalamut's Avatar
    Dec 2012
    Sialkot
    8
    please brothers i have simple message to all of you please make some efforts in making detailed video of 70cc bikee maintenance especially tuning it will be a great effort and help ful
  13. #32
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by r1 View Post
    please RIP it twice .. due to mo**** f*k*r WAPDA // my hard died twice .. SMD Wapda
  14. #33
    raja27's Avatar
    Jan 2013
    35
    bro honda pridor ka bas aek he screw ha carb pa golden colour ka with a needle attached to it and a small spring and i cant find any other screw any ideas?????????
  15. #34
    raja27's Avatar
    Jan 2013
    35
  16. #35
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by raja27 View Post
    post the pictures of your carb from all sides .. hope there will be something..
  17. #36
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Bro steal it from your friend's mechanic someone i knew did it once :thumbdown:
  18. #37
    TZB
    TZB is offline
    TZB's Avatar
    Sep 2010
    28
    691
    60 Post(s)
    2 Thread(s)
    I also have a Honda CD 100. Its fuel adjustment screw is placed behind the utility box. All you need to do to reveal it for adjustment is: open utility box cover with key, find and remove a rubber washer in the area of utility box which is in-line with carburetor, you will see the fuel adjusemtn screw through the hole in utility box.
    Good luck!
    First deserve, then desire.
  19. #38
    raja27's Avatar
    Jan 2013
    35
    Quote Originally Posted by TZB View Post
    Good luck!
    thaaaaaaaaaaaanx a lot brother helped a lot i not only found it but i adjusted air and petrol supply and result was amazing my uncle has a 125 even he was amazed by the acceleration of pridor after tweaking the carb settings thanks again
  20. #39
    raja27's Avatar
    Jan 2013
    35
    Quote Originally Posted by asjdsm View Post
    found it brother thanks for response
  21. #40
    mansoor_qadir's Avatar
    Sep 2012
    Attock
    1,476
    11 Post(s)
    Still waiting 4 video... @asjdsm
    <..If everything seems under control, U r not going fast enough..>
