Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By imranbhatti
  • 1 Post By Xulfiqar
Thread: Cd70 front shocks, how to adjust
    ak666666's Avatar
    Jun 2008
    50
    83
    Default Cd70 front shocks, how to adjust
    My 1986 has soft shocks. There is a big nut at top and a small nut at the bottom. How to adjust oil level for more stiffness? What should be oil level below upper nut? What oil to use? What weight? Should oil be changed? Any special shock absorber oil?
    tayyabbaig's Avatar
    Nov 2008
    Oslo
    34
    2,706
    3 Post(s)
    better replace the pair of front shocks.
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @ak666666
    GEt your bike's front Shocks serviced fron some work shop & ask service man to used ATF (automatic Transmission Fluid) or Hydrualic oil. For stifness u may need to replace damping spring which may have become softened with passage of time.
    Exploring Machines is my Passion...
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    I do know about older CG125 shocks with external springs used 100cc of ATF in them, while the internal spring ones used 10W30 engine oil in which you need a dipstick (piece of wire) to measure the oil.
    ak666666's Avatar
    Jun 2008
    50
    83
    Thanks everyone.
    @Xulfiqar
    Yes I use a makeshift dipstick too but I dont know how deep the oil should be.
    ak666666's Avatar
    Jun 2008
    50
    83
    Thanks Imranbhatti
