Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Like Tree4Likes
Thread: slipped carburetor mounting nut
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Default slipped carburetor mounting nut
    hi
    my carburetor nut is sliped ,, the nt which resides in carb ,,through which the inlet pipe to head is attavhed to carb,, i cant find one in all hardware shops currently i have done some temporary setup but need the nut for proper setup,, the one in golden color is slipped,, slipped carburetor mounting nut -245869
    slipped carburetor mounting nut -245870
    the other one is very wide and cannot be inserted .. so i m mounting it externally but that may fall and i wil be left with a hanging carb
    oh it is called DIN 562 Square Thin Nut
    thanks
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Instead of hardware shops, you should be looking for it from a shop known for keeping used nuts and bolts, you can find one in Rawalpindi IMO, in Sadar area.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    yar kisi motorcycle ki shops pa nahi mila,,and samw with hw shops,,
    i will try in saddar as well
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    I lost the fork's axle nut of my FZR when I had got them opened for seal change, found a similar one from a shop containing old nut and bolts in Sargodha, no hardware or parts shop was of any help, thats why I mentioned to look for a similar shop.
    ak666666's Avatar
    Jun 2008
    50
    83
    70 or 125?
    ak666666's Avatar
    Jun 2008
    50
    83
    With a grinder or file, you can reduce the size of the hexa nut so it fits in place.
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    yar it is very fathex,, and it will need to be reduced by half of its width and that will only leave a couple of threads in it and then it will only be a once or twice usable thingy,, the default one is of strong material so even that has few threads but the are strong,,
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    If its same as of CD 70 than must be available at Honda 3S shop.
    Exploring Machines is my Passion...
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    dear it is ditto copy of honda and is ditto same but guess whatr cant find it any where i searched each and every shop in waris khan, murree road where the biggest of honda spare parts are sold,, cant find it any where ,, guess wha they said it is only shiped installed in carb and it doesnt come as a seperate piece,, so they told to go to kharadia and remove the grips on carb for the nut and use any nut ,, in other words butcher the carb,, one shopkeeper showd me his own ,, anyhow,,
    most people told me that they can only be found in lahore and at mc load road ,, nowhere can it be found,, so what to do?
    can anyone in lahore ask for it,,/
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @asjdsm
    I will try to find it out for u in Lhaore but i m very much sure u can find it on 2S or 3S Honda shops. There r many petty things which r not available on big shops who deal in parts but easily available at These shops as the usualy provide complete service & parts solution to customers.
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    i tried2s and 3s shops they also tld me that these nuts only come with new bike carb and then u need to cut the grips for other nuts,, and he said that these are only available on mcload road,, but non wouldorder them,, cauz they work hands in hands with kharadia to increase sale and kharadia services,,
  12. #12
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    I will try to find that for u on my next Visit to Motor bikes parts market @ McLeod road.
  13. #13
    scorpion80's Avatar
    May 2007
    36
    4,320
    11 Post(s)
    visit some shop which has used nut bolts of cars/bikes ... u will get it in a very cheap price ...
  14. #14
    isi0000's Avatar
    Feb 2011
    767
    Quote Originally Posted by asjdsm View Post
    hi
    my carburetor nut is sliped ,, the nt which resides in carb ,,through which the inlet pipe to head is attavhed to carb,, i cant find one in all hardware shops currently i have done some temporary setup but need the nut for proper setup,, the one in golden color is slipped,, slipped carburetor mounting nut - 245869
    slipped carburetor mounting nut - 245870
    thanks
    visit g-7 khadda market there is small shop of old and kabli nuts and bolts u will get ur one from there easily
    "Women - always in trouble with them, but can`t live without them."
    Ayrton Senna
  15. #15
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    today i happened to go there so searched it there couldn't find one,, searched all kabarias and couldn't find one,,bhio if anyone in lahore happens to go to mcload road plz do ask it,,
  16. #16
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    bbbbbbbbbbbbbbbumpppppppppppp
    anyone in lahore done a nuthunt for this purza?
    o bhaio lahore/karachi walo btavo,,,
  17. #17
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    sir try any kharadia system
    dnt knw much but gd luck
    legend will revive soon
  18. #18
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    tried that,, but nai bana,, 2 nuts wasted,,
  19. #19
    massterr100's Avatar
    Mar 2006
    34
    661
    7 Post(s)
    Aoa. I got a nut for u
    sent u a PM.
    IGNITE YOUR LIFE WITH WHEELS.
  20. #20
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    thanks a million dear pm replied
