Results 1 to 18 of 18
Like Tree11Likes
  • 1 Post By asjdsm
  • 3 Post By Xulfiqar
  • 2 Post By Xulfiqar
  • 2 Post By Automotorsport_Lover
Thread: When to Clean/Replace Oil Filter Screen on 70cc bikes
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    Default When to Clean/Replace Oil Filter Screen on 70cc bikes
    hi
    when to change/clean the oil filter screen the manual recomends its cleaning every 12k Kms. However when i ask mechanics they seem to have no clue of it ? also when to change ? has any one of u ever changed/cleaned it and why?
    here are some pics from honda cd 70 manual
    When to CleanReplace Oil Filter Screen on 70cc bikes -248476
    When to CleanReplace Oil Filter Screen on 70cc bikes -248477
    When to CleanReplace Oil Filter Screen on 70cc bikes -248478
    When to CleanReplace Oil Filter Screen on 70cc bikes -248479
    update: looked at my other book i found that the clutch cover needs to be opened here is the screen shot
    When to CleanReplace Oil Filter Screen on 70cc bikes -248554
    hammadameen's Avatar
    Jul 2009
    25
    197
    useful info
    MY CAR IS MY ATTITUDE
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    when I did an oil change, I clean out the screen on a CD70 engine, it takes about 2 minutes to remove the magento cover to access the screen.
    The CG125 engine also has a centrifugal oil filter which needs to be cleaned out every 10,000 kms - but to service it you need to open up the clutch cover.
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    i have few questions
    1:yar what is the "petrol ki screen" which i have marked in first picture,,? ya kahan hothi ha?
    2: secondly i have done my bike 22 k kms anbd has never cleaned or replaced it.. mechanics say no need,,so should i now clean the oil filter screen or replace it? how much new costs? if cleaning is required how to clean? what solvent to use?
    3: also the procedure to clean is mentioned in the fourth pic but it needs to remove the crankcase,, is its removal same as that of the magneto side? or does it needs the clutch cover ? to be removed ,, also if it needs to be removed what size of Allen key is needed i need one,,
    thaks,
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    im sorry foe being backwards - but its the clutch cover needing removal not magneto. I beleive CD70 come with 8mm bolts on the engine, no need for an allen key - just a tall 8mm socket, or T handle with 8mm as one piece.
    the filter can be washed in regular petrol and a toothbrush - the idea is to clean out any trapped junk from it.
    The petrol strainer is in the fuel tap - it would be inside the round plastic underneath it, or if you have a very old model 70 - its inside the tank - and you need to completely unscrew the fuel tap from the tank and shake/scrub it clean.
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    thanks dear for the prompt response,,
    so to clean the engine oil screen i dont need to remove the clutch cover?
    oh by the way what size allen key to use to open the clutch cover? i just need to open it
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    When to Clean/Replace Oil Filter Screen on 70cc bikes - 248554
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    as i said you need to remove the clutch cover and you dont need an allen key but a 8mm thin walled tall socket - you can buy a T handle in the tools market with an 8mm socket cast on one end.
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Its a foam piece... must be black n dirty by now... Take it out and wash it with petrol... dry it up and fill it in.. dats it.
    ge9us's Avatar
    Aug 2011
    From where can I get this manual bro????
    plz help as I'm doing my uni project and need the manual as soon as possible....
    Thnx
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Quote Originally Posted by ge9us View Post
    Thnx
    Cant provide owners manual for Honda CD70 but for downlaoding DYL Dhooms go to following link:
    http://www.dyl.com.pk/Images/Downloa...1895730734.pdf
    Most of the things will be the same, but there are major differences too. why do u need it? what info ur looking for?
  12. #12
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    If we open it then we need new gas kit + paste tube as well.
    31.5497 N, 74.3436 E
  13. #13
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by Juste View Post
    ya we need new gasket for the clutch side..
    u will need to drain engine oil... and pore new engine oil..
    also need some curil/silicon .. curil is good as that holds tighter to the surfaces ..
    i did cleaned it and there were some metal shavings ...
    if u can clean it just first time .. then i dont think there will be more shavings ..
    @ge9us
    what project are u doing ..
    btw there is only stroke /carb difference in the engine of honda and chonda.. chondas have long stroke .. and bigger bore carb.. and true cc of honda is 69-70cc and that of chonda is 85-88cc ..
    if u need any help do pm me..
  14. #14
    Newbie Follow
    mianmukhtar786's Avatar
    Nov 2013
    Sialkot
    38
    Post Need Book
    Dear Sir i need this service book. kindly send at my email mianmukhtar@apniisp.com.
    Thanks
    Mian mukhtar
    03018611013
  15. #15
    sualehsmarty's Avatar
    Jun 2013
    52
    2 Post(s)
    ye wali user manual kaha se milti hai ??
  16. #16
    mukhtar.ahmad.965's Avatar
    Jan 2014
    Narowal
    38
    need help
    Bhai kia ap ye book send kar sakty hein.
    When to CleanReplace Oil Filter Screen on 70cc bikes -248554[/QUOTE]
  17. #17
    Jan 2014
    Narowal
    38
    Cool Cd 70 manual book
    Dear plz send me cd 70 service book download link or tell me where i buy it. plz help to buy this book thanks.
    my email id is mukhtar.kts@gmail.com
    My cell No. is 03018611013
    I m very thanks full to you for help me about to get the book.
    Thanks
    Mukhtar
  18. #18
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    bro it is available in the market at 50 rs.
    it is motorcycle usool service our muramath by sheikh ashraf sitaar auto instructor.
    pretty long title..
    go to any good book shop you will find it.
  19. 30-03-2016, 11:51 AM
    Newbie
