Page 2 of 2 FirstFirst 12
Results 21 to 21 of 21
Like Tree11Likes
Thread: big bore cylinder
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    Default big bore cylinder
    hi
    i got some questions
    first has any one tried the big bore cylinders on their bikes ?
    what was the result . how bigger was the cylinder . what u changed along with the big bored cylinder such as piston. rings .. head porting.. cost as well
    where they a ready avilable units or u bored the cylinder .. how was it bored i mean quality // how was it running and how it went
    y u did this ? as a result of overhaul? seized engine? or performance
    any more info welcome
  2. #21
    knowledgeiswisdome's Avatar
    Aug 2011
    Toronto
    27
    Guys there is kit for CG125 which makes it 166CC. It comes with new cylinder piston rings and a new cam. Its quite expensive and not worth in paki market.
    If you really need more power than get a bigger bike dude. Cause with all the modes you will do to your bike, it will still not be same as being build by a manufacture. Quality will suck for sure and it will be a problem bike.
    I have been working on big machines for last 15 years. For instance Harley 883 can be upgraded to 1200 but with all the Harley factory stuff you still can not get the same feeling of tight engine sound. If you do not care about the quality of engine (engine life) and how it sounds then go for it.
