Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Like Tree35Likes
Thread: Little things can Cause big problem's
    outlaw92's Avatar
    Apr 2009
    24
    220
    Default Little things can Cause big problem's
    Hi everyone.I bought a new hero rf70 abt 3 weeks ago.Bike performs very good compared to other models(has a bit of vibration issue though).So abt 3 day's ago i was checking the oil level of the bike and realized that the lower end of the gauge was missing.I rushed to the mechanic and he said that it's not a big problem it will settle down in some corner and not harm the engine.Today i was going some place and i realized that bike was getting really hot.So i rushed to the mechanic and told him to drain all the oil and open the side.I was surprised to see that the plastic had melted and was blocking the oil flow to the engine.Mechanic told me a few more kilometers like that and engine would have been seized.I hope this thread saves a few engines from seizing
    To personally satisfy my own adrenalin needs, I've been racing Bikes a little bit, which has been fun.
  2. #21
    outlaw92's Avatar
    Apr 2009
    24
    220
    It's a new bike frame cant be cracked yaar
  3. #22
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Copy bikes usualy have Vibration issue specialy in mid & High RPM.
    Exploring Machines is my Passion...
  4. #23
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by outlaw92 View Post
    why not - have you personally seen the quality control.
  5. #24
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    i also faced the vibration issue but the axle in the middle lower portion of thr bike was the culprit, new axle cost me 35 and i replaced that in its initial days/mnths,,, i m not talking of wheels axles ,, the centre one ,,
  6. #25
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    its called swing arm centre bolt and not axle - it should be greased liberally first then tightened with rider weight on the bike so it can settle in its normal position and not be twisted all the time. The greasing helps it rotate and not sieze internally.
    The bike only has two axles each of which holds the wheel from the centre.
  7. #26
    outlaw92's Avatar
    Apr 2009
    24
    220
    @asjdsm
    Thank's brother ur a life saver not only i got rid of the vibration issue but the bike is also a lot stable at high speeds.))))))
  8. #27
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    thanks xulfi .. but this the name a mechanic told me when i was to replace it ...
  9. #28
    mahmood's Avatar
    Mar 2004
    34
    1,998
    2 Post(s)
    me having similar problem of vibration in my CD70 but i couldn't get which bolt we are talking abt here, is it one which mounts engine to backbone the one on which spring for brake lever is attached also or the one which mounts rear forks ( chimta ) to the backbone? or perhaps a pic might be helpful
  10. #29
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by mahmood View Post
    Little things can Cause big problems -255873
    Little things can Cause big problems -255874
    the suspect is highlighted,,it cost me 35 rs a year back,, dont know whats its rate now, got from mohamdi autos pindi ,, janyeen honda
  11. #30
    mahmood's Avatar
    Mar 2004
    34
    1,998
    2 Post(s)
    ^^ thanks bro, it couldn't be any better explained.
  12. #31
    outlaw92's Avatar
    Apr 2009
    24
    220
    Got it for 35 rs frm mohammadi
  13. #32
    mahmood's Avatar
    Mar 2004
    34
    1,998
    2 Post(s)
    not only this but it was janyeen honda , fitted in yamha
