Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Like Tree6Likes
Thread: intake manifold pipe,change direction,need help,pics attached
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    Default intake manifold pipe,change direction,need help,pics attached
    hi
    i want to attach a cd100 carb to 70, but the default lota is very small , trie other alternatives but failed miserably, got this idea need your help , in this setup i m intalling the high flow filter directly to carb and by doing so the length exceeds the available space in bike and the air filter cannot be installed ,, therefore to over come the issue it needs to change the direction of the setup so it is outward ,,
    problamatic setup
    intake manifold pipechange directionneed helppics attached -256689
    possiblle solution
    intake manifold pipechange directionneed helppics attached -256691
    now how to change the direction of the silver pipe? pipe pa jahan carburetor lagtha ha kia uski direction change ho sakthi ha ? yani twist ho saktha ha?
    if yes how?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    honda C 50 system with backwards manifold flange - or a custom hand made manifold.
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    yar ider cd 100 ka mani foldbari mushkal sa mila ha,, thou c 50 ka kaisa mila ga,,
    custom ka pochtha houn but local kharadia,mistry bacharoun ko kuch patha hi nai hotha,,
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    is it possible to twist the above flang,? so that the carb stick ut to the side of bike rather then directly beneath the tanki..
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by asjdsm View Post
    C50 = Honda 50, very easy to find
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    i dont think it will be available as this model is not that much in here ,, moreover its dia is probably 13mm whareas carb is 22mm,,
    second issue would be that there is also lack of space in backwards installation cauz of the safeguard,, and also the carb cable gets a sharp u bend ,, tried that with this flang and a bit lower size flang,,
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @asjdm
    Can u post the pics of beneath the highlighted section? if its identicaly in shape than u may try to fit it 180deg out i mean filter/Carb intake directly facing towards front provided the front fender donot touch the set up.
    intake manifold pipechange directionneed helppics attached -257483
    Exploring Machines is my Passion...
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    ya it can be installed backwards but in backwards direction it is obstructed by the safeguard .. and also the throttle wire gets bent sharply..
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @asjdm bro if only the filter installation is the main problem in this new carb fittings, then why dont u use elbow hose pipe for the filter installation?
    pics r here for referenceintake manifold pipechange directionneed helppics attached -258174
    intake manifold pipechange directionneed helppics attached -258175
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    ya was thinking of using elbow ,, but i could only find them in sanitary shops and these r of hard plastic,, size was a bit bigger but that issue coiuld be addressed ,, i dont know if they would solve the issue ,, but will give it a try,, thanks man
  12. #12
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    ok guys i think this is the thing that i need now i am pretty much sure that i wont find in local market so i will have to make one .. can anyone suggest me where can i make it and who ( ? kharadia or someone else ) makes such things..
    the item is called "12 Way Manifold Adapter" which is nothing but a simple circular disc with holes it it ..
    intake manifold pipechange directionneed helppics attached -258466
    here is the link to this item..
    Classic Honda Z50,XR50, CRF50, CT70, XR70, CRF70 AND XR100 motorcycles and performance parts Takegawa and Kitaco bore kits carb kits racing parts and performance mufflers.
  13. #13
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    hi
    i want the following lota
    intake manifold pipechange directionneed helppics attached -261201
    it is exactly the same as of honda cd 70 but the pipe is bigger its internal diameter is 10mm greater then honda cd 70 lota..
    or if i can find some hose pipe of 38mm like this it would be also be ok..
    intake manifold pipechange directionneed helppics attached -261200
  14. #14
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Another jugar can be, that u cut the Manifold in middle & get it weld (silver Weldinging ) by placing it at required Angle.
  15. #15
    han1911's Avatar
    Nov 2009
    26
    1,025
    42 Post(s)
    3 Thread(s)
    can we install this intake on 125 dlx ?
    Who are you to judge the life I live? Try to walk in my shoes and you'd fall at the first step. .............. ( han1911 )
  16. #16
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Yar kya ap ny CD100 ka carbi purchase kia tha?
    Agr kia tha to us ka kya bna?
    Sell k dia?
    I Am the Feel
    I Am The Yamaha!
  17. #17
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    purchased it,, still lying,, only when i make a good 12 way manifold adapter from kharadia i will use it with the filter shown above,,
    do u need cd100 carb?
  18. #18
    booster's Avatar
    Mar 2008
    30
    1,183
    9 Post(s)
    asjdsm bro put some light on the filter , luks cool , can i install it in my bike ??? wat are the pros and cons??? cost???
    The Rules R Simple ....... U Break Them - U Die
  19. #19
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    what bike r u using?
    it will improve air flow,, and give some boost,, havent tried yet due to the fact mentioned above,, cant mount it,, carb ka peecha itni space nahi ha,,cons are that it wont filter out as bettewr as paper filter,, therefore not goo for engine in dirty environments,,
    it costs 160 in new,,
    when i make the adapter i will definitely use it and tell u ppl how to use it and adjust it,,
    btw what bike r u using
  20. #20
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    No bro i don't need it.
    @booster is using GS 150 i think.
    I Am the Feel
    I Am The Yamaha!
