Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Like Tree6Likes
Thread: intake manifold pipe,change direction,need help,pics attached
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Default intake manifold pipe,change direction,need help,pics attached
    hi
    i want to attach a cd100 carb to 70, but the default lota is very small , trie other alternatives but failed miserably, got this idea need your help , in this setup i m intalling the high flow filter directly to carb and by doing so the length exceeds the available space in bike and the air filter cannot be installed ,, therefore to over come the issue it needs to change the direction of the setup so it is outward ,,
    problamatic setup
    intake manifold pipechange directionneed helppics attached -256689
    possiblle solution
    intake manifold pipechange directionneed helppics attached -256691
    now how to change the direction of the silver pipe? pipe pa jahan carburetor lagtha ha kia uski direction change ho sakthi ha ? yani twist ho saktha ha?
    if yes how?
  2. #21
    farhan_scorpion's Avatar
    Sep 2011
    26
    7
    Imran form where u purchase that filter... i need it please let me knw the place/ shop in lhr...
  3. #22
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    crown lifan shop...
    desi shopkeepers call it power filters or some other desi name which i dont remember... but explain to them or show them pics ..
  4. #23
    malikjee1's Avatar
    Dec 2009
    28
    29
    can i attack power filter with cg honda 125 kindly tell me trick
  5. #24
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    tabi_hawk can explain it better,, he has been using it in his 125
  6. #25
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    free bump .. where can i make that 12 way manifold ?
