Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Like Tree1Likes
Thread: Boric acids+engine oils Do they work out??? Important!!!!
    syedhasan92110's Avatar
    May 2011
    Rawalpindi
    309
    2 Post(s)
    Exclamation Boric acids+engine oils Do they work out??? Important!!!!
    Hi,
    I saw that thread I wanted to share this with you all..
    I was browsing through another famous automobile forum more oriented towards cars & a guy in that had tested using boric acid + engine oil on his esteem's engine. Later he had tried with Boric acid + petrol, petrol + 2t oil.
    He had mentioned that Using boric acid with oil is the cheapest & most effective way of smoothening the ride & reducing friction drastically.
    Its like this, boric acid (3gms) + 1 litre of oil when mixed & put in the engine, under such high pressure & temperature, Boric acid is transformed as Boric oxide which is tougher than the metal used in engine itself.
    Few points summarised -
    * Its already in the size of 4-15 microns, so passing through oil filter is not an issue. It sticks to the surfaces of metals & reduces grinding of each other.
    * Engine performance improves due to tighter compression as all cavities, crevices are filled by lubricating boron particles which restores original compression.
    * oil changing time can be doubled easily as minute metal parts which makes oil thick is the past thing.
    * Engine oil additives are either sulpher or chlorine or graphites which are very toxic in nature & also when they work in extreme temparature their vapours are very very toxic at exhaust end.
    * Since boron treated metal surface becomes corrosion resistant. Most wear & tear also occurs due to acid formation in combustion process.
    * Boron particles react with water vapour to form boric oxide layers which sticks with metal surfaces making a covalent bond. These layers doesnt allow metal surfaces to contact each other, like in carrom board. They are high temparature, pressure resistant, also they are very hard, infact harder then metal surface beneath it. So metal to metal contact is very much eliminated reducing the friction which is responsible for generating more heat inside combustion chamber. Acidic formation by combustion process is taken care as no metal surface is exposed as earlier.
    Now, my question is, has anyone tried this treatment??
    When this is added, its claimed that it makes engine oil smoother & it sticks to surfaces. In that case, will it make the clutch slippery?
    Is this recommended, because its claimed that its bio degradable & the outcome is non-toxic?
    Suggestions and comments needed in bulk
    You are to ride the machine, machine is not to ride you..
  2. #21
    May 2011
    Rawalpindi
    309
    2 Post(s)
    list??
  3. #22
    destiny's Avatar
    Sep 2004
    Liaoning
    86
    463
    Quote Originally Posted by knowledgeiswisdome View Post
    You better look for new clutch plates and then crank bearing and the list goes on boy
    Aho, clutch wet Honda si
    Bhalle Bhalle!!
  4. #23
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    anyone done it?
  5. #24
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by syedhasan92110 View Post
    1. Things needed - 100Gms boric powder and 100 ml acetone (both available at the local chemist store) & your engine oil
    2. First pour the boric powder into a wide mouth bottle and then pour the acetone into this bottle. Mix them together to form a thick paste.
    3. Pour 200ml of engine oil in this bottle and stir it till it mixes completely with the paste. mix it for around 20 minutes before it could mix completely.
    4. Pour this mixture into the cold engine and take the bike out for a spin. Drive hard or acclerate hard.
    have u personally done it?
    source of this specific mixture,,
    is the aboive potion fo bike or car?
    and what r the specific brand,and pckaging and price of boric acid,and acetone? kahan kahan sa ya chzen mil jaythi hain,,, tell me the shop in pindi,
    if its for bike then 70cc minimum need is of 600ml of engine oil ? so u mean we only pour 200ml ? or fill the rest ? and when? i wana try it,,
  6. #25
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    did any one tried it ? any update ?
