Page 3 of 12 FirstFirst 12345 ... LastLast
Results 41 to 60 of 235
Like Tree177Likes
Thread: Project Dhoom YD 70 Upgrade to 110cc
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    Question Project Dhoom YD 70 Upgrade to 110cc
    hi
    as the title suggests.. i have undertaken this small project.. so far i have made my bike partially ready.. here is what i have done so far..
    1:installed a 4 wheeler Cylinder of 107cc capacity
    2: and a corresponding Cylinder head..
    both the things were just bolt on fit.. no new timing chain was needed..
    i also upgraded to an after market china carburettor that comes for qingqi 100cc rickshaw.. did nothing to the jets ..mixture is a bit rich but proper setting is needed.current jets are unlabelled. however from spark plug reading mixture is in acceptable range...
    So far results are quite decent...pick is increased . very much..it reaches speeds of 80 in fairly short time..top speed is 90 but it severely vibrates past or close to speeds at 80. current sprockets are 14/41 default..
    UPDATE [17/06/2012]
    after i added the clutch box and sprocket was changed to 15/41 top speed is 100 and no vibrations..
    the new 110cc head is exactly the same as of the chonda 70 only difference is the size of combustion chamber which is slightly enlarged for the 52.4mm cylinder as opposed to the 48mm chamber of chonda 70.. The intake valve is 23mm and the exhaust valve is 20 mm.same values as of default cylinder head of dhoom 70. silencer is the same old of dhoom 70..
    Now i need suggestions/verifications as to what should i do to make it a bit faster.. in-fact not faster but to make the gears longer as at speeds above 60 (definitely in 4th gear) it seems as if it needs to be shifted to next gear..
    Now, one mechanic suggested me to use the following
    1: qinqgi clutch gear..and he said it costs 800-900 rs in new.. DONE
    2: and also to upgrade to 3 discs/plates clutch boxa...( infer for yourself
    what he meant.) DONE
    3:someone also suggested me to open the ports ( portain khuli kara lain) [To be done]
    4: replace the paper type filter element with a foam type ,, [To be done]
    will make a video about the project on what i have done so far.. in a couple of days. and rearrange this thread..
    also suggest a good mechanic..in pindi islamabad..
    thanks..
    Some pics of the new cylinder head (110cc)
    This is the combustion chamber of 110cc cylinder..
    Project Dhoom YD 70 Upgrade to 110cc -287370
    Following pic show the scale next to the centre line of a 110cc combustion chamber ..my readings using vernier scale were as follows.
    the inner circle is of 40mm dia same as in dhoom 70 chamber
    the outer is of 52mm dia , 4mm bigger then the chamber of dhoom 70
    depth is same for both..at the center line..
    Project Dhoom YD 70 Upgrade to 110cc -287371
    vernier calliper showing the outer dia.
    Project Dhoom YD 70 Upgrade to 110cc -287372
    110cc cylinder installed.. along with a piston. the piston was partially seized but the mechanic who installed it said it is ok.. many mechanics also said so.. however rings were new. of STR.. the rings which i bought were for 150 rs and they were of zero number from united 100cc bike..(that bike in reality is a 110cc)
    Project Dhoom YD 70 Upgrade to 110cc -287373
    Piston at BDC of the cylinder.
    Project Dhoom YD 70 Upgrade to 110cc -287374
    another view of piston at BDC .
    Project Dhoom YD 70 Upgrade to 110cc -287381
    Piston at TDC. not the piston was flat shaped but there was too much compression.. so we tapper cut the piston.. that's why the piston looks pretty old at centre and clean at the edge... this pic was take after this piston did some 20 Km ...
    Project Dhoom YD 70 Upgrade to 110cc -287382
    Another View of Piston at TDC,
    Project Dhoom YD 70 Upgrade to 110cc -287383
    Picture of Exhaust port from cylinder head.. no silencer installed yet..
    Project Dhoom YD 70 Upgrade to 110cc -287384
    another view of the exhaust port of the cylinder , silence isn't installed yet..
    Project Dhoom YD 70 Upgrade to 110cc -287385
    Project Dhoom YD 70 Upgrade to 110cc -287386
  2. #41
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    Thumbs up
    Quote Originally Posted by N0m1 View Post
    sprocket is looking of good quality.Y nt 16 tooth?
    i thought the upgrade should be gradual,, so first trying 15 t then i have 17 tooth lying with me,, i will check a 16t if either one doesn't performs well or if got a slight indication that there is a room for improvement ..
    also most mechanics were suggesting 15 t
  3. #42
    overspeed111's Avatar
    Apr 2010
    1,176
    Quote Originally Posted by asjdsm View Post
    i will check exact mileage using a 100ml method to remove any ambiguity,, and will share it,, may be tomorrow or the next day,, but m using it for quitesome time ,, and it seems that its avg is not different from what it used to be, but will test it,,,
    yar local so called ustaads and mechanics sa bahoth tang hotha houn as they know nothing an then they talk as if moding is a sin,, anyhow as soon as i get away from them i m ok and energized,, i like it ,, i like doing mods
    and ma ciggerate nahi peetha is lia nahi thaktha
    hahahah...good
    well how to measure 100 ml if someone dosent ve flask to measure it .is there some desi method to measure it.i also want to measure the mileage of my bike.
    well good going on the bike and also be thankful to dhoom and local mechanics who made you mechanic...
    in mechanics say to ALLAH TALAH he bachaen .
    bro from where you brought gauge for tappet adjustment?
  4. #43
    daniyalahmad's Avatar
    Jun 2009
    Select City
    8,435
    12 Post(s)
    2 Thread(s)
    another update is that my bike was with friends and they went to murree on it,, though they enjoyed it but the meter needle is now free it just swings,,
    Is it back to normal now?
    I dont know what is wrong with Muree?
    Whenever I go to Muree on bike, as soon as we cross the toll plaza the speedometer needle of my bike goes crazy.
    When we enter Rwp it comes back to normal.
    Dont know is it due to the extra body vibrations or what?
    A close friend took his CG125 to Deosai and he encountered similar problems with the tachometer of his bike.
    One of the most difficult things in the world is to know how to do something, and to watch without comment, somebody else do it incorrectly.
  5. #44
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    ^^hmm,,
    i have just changed the sprockets,,not checked the meter or sprocket response,, i have been to murree quite a few times but never got such issue,,just this time but that's in my opinion just a co incidence,,that it happened in murre,,
    will check it,, so is ur normal now?
    suppose if mine doesn't returns to normal ,what r the solutions?
    tappet gauge can be bought from any hardware shpop,, in raja bazar,and gawal mandi,,, there r 4 tpres of tappet gauges one is just a strip that is i think 1 foot long that gauges up to .05mm and costs 90 rs..
    another is the one that mechanics use which has a bend and two sides measurement of .05mm and .08mm ,i couldn't find it easily,,
    another is multi values that contains 2 inches strips of thickness ranging from .05mm to 1 mm , i ,mm using it don't re,member the cost but its cheap,, and there is another of the same type but the quality is far superior ,, that wont get any rust, u can bend twist and it wont cut,,
    that's a bit hard to come across,,,, just buy either multi valued one,, that's good,,
  6. #45
    Jun 2009
    Select City
    8,435
    12 Post(s)
    2 Thread(s)
    ^ Yes all is good now.
    It could be a co-incidence but this needle thingy always happens to my bike so I felt that something might be wrong with Muree.
    The speedometer can be repaired or replaced.
    Any guy who repairs speedometers can tell you what exactly went wrong with your speedometer.
    Sometimes its the speedometer cable or the hub gear in the front hub that is damaged and causes this vibration.
  7. #46
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    it is working now,,bizarre behaviour,, i haven't done any thing to it,, the gear was ok last time i checked it,,however it was pretty messy as the grease was the default one,, i think i need to really clean and grease it,, what grease should be ok for such purposes? i have one grease that is greenish in colour and its refereed as aalo grease,, really cheapo,, also tell price and brand of good grease that i could use in this motorcycle,,
  8. #47
    Jun 2009
    Select City
    8,435
    12 Post(s)
    2 Thread(s)
    ^ Check the gear for its free movement the next time you open the hub.
    If you feel something is creating problems in its free movement then remove it and clean it then use some good grease for it.
    I might have the old gear lying around with me somewhere, will post its pictures if Im able to find it.
    It was jammed completely and it broke 3 speedometer cables in 4 months.
    I use Caltex Multi purpose lead free grease, works fine for me.
    Project Dhoom YD 70 Upgrade to 110cc -296824
    BTW You should contact Xulfiqar.
    He must know which grease should be used.
  9. #48
    bravo122's Avatar
    May 2010
    Other
    22
    1,730
    21 Post(s)
    bro do u still have the 70cc engineand carbourator??
    r they in working condition??
    i need em for a project??
    from where did u get the 100cc engine and how much did it cost??
    i need these to fit in a bike whoses engine is goner
    :a
  10. #49
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    y i have the carb not for sle.. u can buy from a range of carbs,, get a genuine one that would cost between 1300-1500 buy genuine dyl or honda cd 70,, if uu want to go chinas maal then i have very bad experience with crown lifan carb,, most ppl here recommend future carb,,
    u can get a used genuine carb of cd 70 from auto race at 500 ,, that's near commoittee chowk i think,,
    i would recommend u a genuine...
    i didn't bought the entire engine but just the piston cylinder and head ,, i thin i paid 1800 for cylinder ,, hell expensive,, and 1600 for head i think,, piston was with cylinder,,,
    bought from auto race ,,
  11. #50
    bravo122's Avatar
    May 2010
    Other
    22
    1,730
    21 Post(s)
    ok
    :a
  12. 14-09-2011, 10:38 PM
    Site Banned
  13. 15-09-2011, 09:12 PM
    Site Banned
  14. #51
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    today i completed 500 km run on my newly built engine,, and thought to check its mileage,, from observation i noted that on normal ride involving high speeds its giving me better results,, but a true figure was necessary,,so the mileage comes out to be 90km to 2 litre of petrol that is 45 km/ltr,, and this test involved very mix riding ,, speed was always above 60 ,, mostly at 70-80 km/hr,, some time was with double sawari.. the test icludied a ride to chattar park its very hilly area,, so its very good,, i earlier did calculated avg on this rout that was 40 km/ltr when bike was defaullt,,
    so awesome result so far,,,
  15. #52
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    like it 45kmph
    its great
    legend will revive soon
  16. #53
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    now a test in economy speed is left,, and hope its economy speed will be in 50-60 km/hr range. will do a test involving this speed range,,
  17. #54
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    ahsan bhai wo test kren 100ml fuel wala
    so that exact avg pata chalay
  18. #55
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    inshahlah wo bhi karoun ga,, but i like the test of using reserve ,, that is quite perfect,,
    the 100ml test is needed when u r damn sure that r bike is not giving good avg,, so the best way then is to make it 100 % sure to get the results which company caims,,and they claim ideal results,, or rather to say very precise results,,
    i quoted that i used 2 litre petrol ,, i put two litre petrol because i thought with just one litre precision would not be achgieved,, so went for two litres of petrol..
    i m sure the results compare truly to what ihave nnoticed about its consumption,, at least now it is giving me more power with improved avg,
  19. #56
    Jun 2009
    Select City
    8,435
    12 Post(s)
    2 Thread(s)
    45km/litre is very good at the speed and the area mentioned by you.
  20. #57
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    45 km\l.Great!
    With more power.
    I Am the Feel
    I Am The Yamaha!
  21. #58
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    please need ur suggestions regarding the following issues raised in forst post,, till now no input ,,,c'mon guys
    what he meant.)
    thanks..
  22. #59
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    whats so special in qingqi gear box????????
    n yamaha ma to 4 clutch plates hoti hn 70 ka ni pata
  23. #60
    asjdsm's Avatar
    Apr 2009
    30
    3,479
    57 Post(s)
    3 Thread(s)
    the increased in engine power needs long gears ..
    abhi default gears bahoth chota hain.. 4th gear ma full rpm pa lagtha ha ka 3sra gear laga ha...
