Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Like Tree5Likes
Thread: Tapit Adjustment in Chonda?
    h3llzang3l's Avatar
    Jan 2011
    Multan
    76
    Exclamation Tapit Adjustment in Chonda?
    Yesterday for the first time i go to the Mechanic for Chonda Tuning and he adjust the Tapit Without using the Strip which used to set the Gape between Cam Tapit and Value .. i ask y u did not use the Strip he said Chonda did not need that coz if i use it the Tick Tick Sound is gona come from ur Head thats y all the Mechanics did not use Strip for This? and right now i just Confused is this true ... Please Help Me
  2. #21
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by h3llzang3l View Post
    W8 i should do with the Clutch ... Loose it or Tight it ...
    freeplay at the end should be 1cm-2cm,, play with ur clutch,, adjust in this range,,
  3. #22
    umarpal7's Avatar
    Mar 2011
    28
    632
    2 Post(s)
    at first i thought he was talking about a honda car. lol
  4. #23
    2468's Avatar
    Apr 2008
    36
    3,508
    7 Post(s)
    3 Thread(s)
    Ye CHONDA CHONDA kya hay, ye CHONDA CHONDA
    Sounds like second word of punjabi gaali
  5. #24
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Bhai G yeh to ab aap ki soch py hy na.
    I Am the Feel
    I Am The Yamaha!
