Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 87
Like Tree100Likes
Thread: Quick help... Sprinter or junoon
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    Default Quick help... Sprinter or junoon
    hey guyz... im v.much troubled between both bikes... i cant take a decision 4 which shud i go.. junoon has looks... sprinter doesnt have looks.... is both cars same tough enough?? is wiring, assemblies etc r of gud quality??? and which is smooth?? no vibration at 80 or above... best road grip also..
    Why drink and drive when you can smoke and fly?
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
  2. #61
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Okay.
    Have to do other wise it will empty my pocket.
    I Am the Feel
    I Am The Yamaha!
  3. #62
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    one thing buddy jets are the most sensitive parts,
    failing to use a proper number of jet may burn ur piston,, e.g hondas manual recomends to go down by 2 number of jets if going on high elevation and then return to previous when not on that elevation,, if standard i 72 on normal elevation (at sea level) then u would use 70 at 1500-2000 m sea elevation.
    though there is a very small number of differnece bewtween the jets but it has pronounced effect on engine,, i would reco,mend properly diagonosing ur carb jets,
  4. #63
    waseem88's Avatar
    Nov 2009
    Faisalabad
    28
    1,172
    18 Post(s)
    Quote Originally Posted by N0m1 View Post
    Okay.
    do this and tell me,fully close the petrol set screw and open 2.25 outwards...
    keep in mind that the turns should be from 12 to 12,mean one complete revolution....open two complete and 1/4 revolution and then check again
    Intelligence without ambition is a bird without wings.....!!!
  5. #64
    alayhassan_zaidi's Avatar
    Nov 2010
    65
    Smile
    THIS IS MY BIKE.2005 MODEL 29000KM DONE.
    fully original.only oil filter,break pad are changer. have defeated many altered 70cc. just removing the silencer it became the nightmare to 125cc bike..
    changer the rear sprocket and did 130km top. and to top it of its still giving me 60~69km per liter max.
    Quick help Sprinter or junoon -314627 Quick help Sprinter or junoon -314628 Quick help Sprinter or junoon -314629 Quick help Sprinter or junoon -314630 Quick help Sprinter or junoon -314631
  6. #65
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Thumbs up
    Quote Originally Posted by waseem88 View Post
    Thanks bro.I have done it.Let see the outcome.I love Yamaha apart its Fuel economy.
    I Am the Feel
    I Am The Yamaha!
  7. #66
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    which size of chains pocket ur using??? and did u altered both or only front?? or only rear??
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
  8. #67
    Nov 2010
    65
    Quote Originally Posted by sd View Post
    i have changed the rear sprocket only original is 37teeth (i think) i used 33teeths. but right after doing so i changed it back to the original.as there was huge power lag in mid range RPM.same goes with the silencer i removed the silencer Raced it and then but the silencer back on.
    rather than using a smaller sprocket i prefer to remove the silencer. acceleration was OWSUM!! it was behaving like a shogun
  9. #68
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    basically the reason i bought sprinter is due to soundless.... i like soundless bike... removing silencer will be alot of headache for me... as hyderabadi silencer made me crazy when i installed in 70....
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
  10. #69
    waseem88's Avatar
    Nov 2009
    Faisalabad
    28
    1,172
    18 Post(s)
    As compared to sprinter,junoon has very less sound and is a very calm bike sound wise.....
  11. #70
    Naveed4speed's Avatar
    Aug 2006
    Sialkot
    26
    6,130
    7
    49 Post(s)
    2 Thread(s)
    yup it,s less sound!
    more grip!
    and calm and comfortable than sprinter!
    FXXB and EJ8 on its way............
  12. #71
    Nov 2010
    65
    what about parts and mechanics?
    in karachi i have seen many sprinter but janoon are hard to bee seen.
    and on time i have took on janoon on a street race he left a large margin because of the acceleration but i cought up to him and then passed him because of top speed.i and
    i think if it was a planed qater mile race janoon would have won it.
    or sprinter bearly have won it by inch or 2.
    its all because of extra weight.
    my sprinter weigh 105 kg alone. (weighted it from kabarhi) :p
  13. #72
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Talking
    Quote Originally Posted by asjdsm View Post
    disastrous average,,,
    did u went for rebuild?
    wish it improve,, else it will leave a big hole in ur pocket,,
    Now No big hole Bro.
    Mene yahi kia or sath oil pump setting bhi kam kr di.Phle full khola hua tha adjuster .K zra runing hojye.
    Ab plug bhi light brown nikla.Pehle dark brown nikal rha tha.
    Or ab Bike ny 100rs k petrol main 40Km kia. Or chlny main bhi fark nhn.Yani pick pehle jesi hi hy.
    I Am the Feel
    I Am The Yamaha!
  14. #73
    waseem88's Avatar
    Nov 2009
    Faisalabad
    28
    1,172
    18 Post(s)
    Quote Originally Posted by alayhassan_zaidi View Post
    junoon has costly parts and body damage can b more than sprinter in case of accident...sprinter has very sound and powerful engine and is a 110 cc bike...so no comparison with 100 cc junoon technically...
  15. #74
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    lolx... yr its doing max 100km\h... bridge utar tey hue 110km\h speed chaley gai thi... cant it be more faster???
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
  16. #75
    apm292's Avatar
    Sep 2011
    104
    2 Post(s)
    why the hell you hate Suzuki??????????
  17. #76
    blackzero_01's Avatar
    Oct 2010
    Dubai
    160
    Thumbs up Congratulations!
    bought suzuki sprinter eco euro 2.... its 109cm3... 110cc yani....
    Congratulations man!
    I have used Sprinter 110cc since Nov 2009 till Oct 2011. I am a heavy man, weigh more than 130kg. Sprinter is very reliable and tough bike. It never let me down whether it were raining cats and dogs, or it were 50 degree c hot summer day, the bike just kept going on and on.
    Its metal is rugged and tough indeed.
    Wish you all the best with your new bike.
    ~~ Four wheels move the body. Two wheels move the soul.. ~~
    [Black Zero]
  18. #77
    Oct 2010
    Dubai
    160
    Even 110km/h is unreal. Its meter is ACL made (as I have mentioned in many past posts as well). ACL made meters show false speed especially above 60kmph.
    Bridge utar tey huay 110 jo show hoti hay, asal main wo 90 k around hoti hay. For confirmation, you can compare your meter with any Honda Civic digital meter. Jab Civic 40 show ker ri ho gi, Sprinter 60 show ker ri ho gi. Same is case with DYL Junoon and other bikes that use ACL meters.
    I don't know if there is a meter calibration service available to public or not, otherwise every motorcycle manufacturer has a Dyno Test Bed where they can (but usually do not) test the Odometer (Speedometer) reading and Brake Horse Power of motorcycles before delivery.
    [Black Zero]
  19. #78
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    well i compared my meter speed wid civic reborn, my bro honda cd70 , n wid cg 125 it was gving correct reading.....
    well for ur info ppl i hve tested suzuki is tough bike... recently on 2nd dec i had an xcidnt my speed was above 100km\h, well didnt had fracture or something, n well because of rickshw it all happend.... and only brusies i got. well im cured nw. n only steering, mudguard got bend, n T.. well it all got repaired gud as new, n nothing broke or got dent.... its tough n awesome.. but clearly road grip isnt gud.... must need gud tyre at rear......
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
  20. #79
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    ALLAH apni hifazat me rakhey... get well soon @ sd bro
    Main tay Honda ee lay saa'n !!!
  21. #80
    talhabinomar's Avatar
    May 2011
    26
    2,470
    38 Post(s)
    Refer to the Tyre which have the Design of Deluxe's Tyre
