Results 1 to 17 of 17
Like Tree12Likes
  • 1 Post By talhabinomar
  • 3 Post By loveshakeh
  • 2 Post By enigmatool
  • 2 Post By imranbhatti
  • 1 Post By anwarlord
  • 1 Post By booster
  • 1 Post By adeelxp2003
  • 1 Post By junaidakhtar01
Thread: Suzuki GS150 engine swap
    streetdevil's Avatar
    Aug 2009
    47
    3 Post(s)
    Default Suzuki GS150 engine swap
    Hi people I need some advice
    I own Suzuki GS 150, 2011 and I want to install a little bit bigger motor in it .which engine is appropriate? Can I use Suzuki GN 250, / GN 400 OR Suzuki TU 250CC engine into this 150cc frame? has anyone done this or is it worth doing
    Im also planning to upgrade over all handling with disk breaks, alloy wheels and fat tyres . Any tips on would be great. Thanks in advance
    Aug 2009
    47
    3 Post(s)
    Suzuki GS150 engine swap - cafemotor
    Displacement: 249.00 ccm (15.19 cubic inches)
    Engine type: Single cylinder, four-stroke
    Power: 20.60 HP (15.0 kW)) @ 8000 RPM
    Torque: 19.00 Nm (1.9 kgf-m or 14.0 ft.lbs) @ 5500 RPM
    Valves per cylinder: 4
    Cooling system: Air
    Gearbox: 5-speed
    Transmission type, final drive: Chain
    TheNewBiker's Avatar
    Aug 2011
    121
    yaar why not increase your budget a bit and increase something in its orignal body and tone
    but it seems to me that u have already bought or have this engine...?
    is it?
    I'm The Best And Will Always Be
    talhabinomar's Avatar
    May 2011
    26
    2,471
    38 Post(s)
    Well it look like a Good and unique Project taking the Suzuki GS 150 under consideration. Glad to see this and interested in each and every technical and purchase step. Take it up.
    loveshakeh's Avatar
    Aug 2009
    Hyderabad (Haidarabad)
    29
    3,221
    i will suggest you to first take advise from a person who knows about bigger bikes engine like 250cc 400cc 700cc etc as far as i know every 250cc have different frame size etc so you must take multiple 250cc engines ager 150cc k frame me ajata hai tu gr8
    i used to have chineese bike in heavy bike look u can see in my rides ( garage ) ik he yamaha ki engine us ki frame me aarha tha woh yamaha ka tha per 2stroke is ki wajah se alteration se me bhag rha tha k na ho aur chineese bike thi so kafi log dara b rhy thy
    mujhe itni knowledge hai nhi per jo upper likha hai yahan k he kuch members ki advise thi
    best of luck
    enigmatool's Avatar
    Sep 2009
    39
    236
    @streetdevil
    bro i did this in 2007 with my gs-150, i have installed suzuki gn250cc (kabli engine) in suzuki-150. that bike starts vibrating hilariously, and also creats problem in shifting gears backwards. this happens due to stock sprockets of gs-150 and less wait for a bigger engine like 250cc. i also try to install the 600cc single cylinder kabli engine in ,yamaha yzx250 1992 bike. that goes awsome bcoz the bike is already very heavy in weight,
    my point is that dont go for alteration it kills your time and money plus patiance...
    oper say denter aur mechanic ki bakwaas aur badneeyatii alag bardasht krni parti hay.
    if you really want to install some bigger engine i suggest go for honda road master 200 or go for honda cb125 and install cb189 engine init. its easily available in karachi, some of pakwheelers already done this project. check by your self.
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @Streetdevil
    Issues of installing GN250's engine in GS 150 has been hilighted above by enigmatool. As far as my opnion is concern u shud go for Honda XL 185' engine which is known as CB 180's engine here in Pakistan, its OHC 2 valve/cylinder engine almost same in size & weight as of GS 150 & engine would be able to push ~ 16 BHP.
    Exploring Machines is my Passion...
    anwarlord's Avatar
    Oct 2011
    Rawalpindi
    7
    Default Suzuki gs 150 modification
    StreetDevil and those who have bought suzuki donot get dishearted. I know suzuki gs 150 have speed problem. Some of the bikes does'nt go over 100 and some at 90. You can be easily crossed by honda 125 deluxe euro and even the simple honda 125. Thats why people need extra speed. I was also fed up of that. Firstly i checked my diapharam on corborator that had small holes, that was spotted by a mechanic Safeer in RWP near pori pull suzuki shop. The other thing i replaced was clutch plates. Third thing i done was oil adjustment to maximum and forth and final was tappets adjustment. After that my bike first four gears were good. It easily go to 80~90 but in fifth gear it disappointed me again. I came to point that due to 135 weight and less torque i have to modify my bike with the new engine. So what i did, i saw two engines of same GS model i.e. gs200cc and gs250cc. Check the link
    GS engine (200CC) products, buy GS engine (200CC) products from alibaba.com and
    GS engine (250CC) products, buy GS engine (250CC) products from alibaba.com
    These are two engines which can fit in suzuki gs 150 but i think 200cc is good for the suspension and other aerodynamics kind of stuff. The reason why you should not go for gn250 or like because they are old check wikipedia for gn250 history and top speed, it have hardly 110~120.
    Second thing which inspired me is that there are numerous other bikes of 150cc displacement engine but they have speed upto 200+. Would you believe? I am in search of these engines may be i can found some but for your information check the wiki's link.
    Suzuki RG150 - Wikipedia, the free encyclopedia
    Suzuki FXR150 - Wikipedia, the free encyclopedia
    Suzuki Raider 150 - Wikipedia, the free encyclopedia
    There are others like unicorn by Honda. Please check them out. If you go for the project let me know.
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    If u can manage parts plus a good person who will swap engine plus he should literate enough to balance the bike n other things then go for it.
    I Am the Feel
    I Am The Yamaha!
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    my suggestion is to keep GS150 genuine. save money and get 250cc or bigger sports bike.
    31.5497 N, 74.3436 E
    booster's Avatar
    Mar 2008
    30
    1,183
    9 Post(s)
    anwarlord
    buddi i think ur bike has serious problems.
    i on the other hand am fed up of touching 120 now and then on my 150 and want more :p
    The Rules R Simple ....... U Break Them - U Die
  12. #12
    Elegant_Rao's Avatar
    Oct 2011
    Rawalpindi
    28
    80
    2 Post(s)
    2 Thread(s)
    Quote Originally Posted by booster View Post
    anwarlord
    exakty at booster. meray 150 ki abhe running puri hui hy or me 3sray gear me 100 tk ly jata hy or 4tha and 5va laganey kiliay road e nahe milti. ap esay honda 125 samajh kr pick do gey to ye cheecken e nikaley ga or speed gir jaye ge. pehlay 2 gears ki sirf range puri kro phr 3sray gear sy kamal shuru hota hy.
  13. #13
    adeelxp2003's Avatar
    Jul 2012
    268
    6 Post(s)
    hyrat ki baat hy k baaz logon ki Gs150, 100km se uper nahi ja rahi, mery pass pehly 2009 model tha uss per 118 tk ly gaya tha , aur abhi 2011 model hy wo bhi aaram se 115+pr jati hy bager shor karey.....
  14. #14
    junaidakhtar01's Avatar
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    Quote Originally Posted by adeelxp2003 View Post
    i agree with you 100%
    but shayed yahan sab chahte hen k honda suzuki san apni 500cc 1000cc and more bnana bnd karden
    as 125cc and 150 cc hi itni fast jo hai
  15. #15
    loveshakeh's Avatar
    Aug 2009
    29
    3,221
    per meri soch is baray me kuch aur he hai .. i dont think there is a quality control in our bikes industry kisi ki bike hawai jahaz si bhagti hai tu koi bike same model mari howi milti hai shayad me galat hu per mujhe esa he lagta hai .... aur dosri cheez aap ki bike jab zero hoti hai tab aap ki running n oil change and tuning buht kaam aati hai aur mere hisab se jo initial running hoti hai bike ki woh he bike ko agay ja k boost karti hai
  16. #16
    loveshakeh's Avatar
    Aug 2009
    29
    3,221
    acha hai tu 150 cc gs ka thread per cg125 ki designs me kia mods kar sakta hu :/
  17. #17
    darknightobserver's Avatar
    Jul 2012
    24
    I am really interested in GS 150 it is known to be a good bike but I think spare parts are very expensive as mechnic says. engine swap will be an epic project!
