Results 1 to 19 of 19
Like Tree9Likes
  • 1 Post By Silver_Knife
  • 1 Post By razaksyed
  • 3 Post By silentbiker
  • 2 Post By amjad635
  • 2 Post By BlueHorn
Thread: Strong smell of petrol from bike
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Default Strong smell of petrol from bike
    Salam all brothers on PWs.
    Brothers I have a problem with my cg125 classic 2008 bike. The bike smells very strongly of petrol in the morning. It feels like there is open petrol near by. I checked the floor but there is no spots of petrol. But still smell is too strong. Also the bike has started giving very bad mileage, about 30 km/h. I have got it tuned recently but i dont suspect bad tuning to be the problem (as I am using same mechanic for tuning for over a year now). It seems like petrol is leaking from some where. But I am not able to pin point. I go to office and park bike for 8 hours and after I come there is very strong smell of petrol coming from bike. At home it is parked till morning and in the morning there is very strong petrol smell. Yesterday night I cut off petrol supply by rotating the 'key'. But this morning bike didnt start. I had to open the petrol line again. That means the petrol in the carburetor had gone over night!
    Can someone kindly help me in this regard ??
    nokia3310's Avatar
    Oct 2011
    Rahimyar khan
    20
    i have no idea. may be there is leakage from fuel regulator or carburetor
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    If you cant find the petrol anywhere on ground or bike than there may be some loose nut which is allowing direct evaporation. Check the tank outlet of petrol i suspect may be leakage is from there
    razaksyed's Avatar
    Jun 2004
    Kabul
    47
    1,003
    A leaking gas tank has nothing to do with poor starting. Seems as if the fuel is escaping from your carb - more presicely, you need to inspect needle valve, level float, float chamber and overflow jet. A faulty needle valve and or level float can result in poor starting, leaks etc. Have your carb inspected by a competant mechanic, I am sure your problem will be solved.
    Having said that, one must inspect the fuel line (tank, filters, fuel tap, and pipe) regularly.
    silentbiker's Avatar
    May 2010
    36
    278
    dear when you turn off your bike u must turn off the petrol as well, the smell of petrol came from under your bike bcoz after you stop your bike, its petrol is over , it throws the petrol and petrol evapurates in the air , thats y u didnt find any sign of petrol under your bike, one more thing , checked it from mechanic, its consuming more petrol than rutine, thnx, hope you u get my point..
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    .......+1
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    long and short if u r new to carb then i would suggest u take it to a mechanic and tell him,,
    dont fiddle with float urself,,its very hard to get it correct once u change it,,
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    I think thats cause u park your bike for 8hrs in direct sunlight
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Check the fuel kay, it should keep dry at all times. Also check the pipe linked to the tank it might be leaking from there. Also check for leaks from any joint, thoroughly check the tank from below.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    brothers thankyou all for your replies.
    one thing i would like to add, today i went to my aunts house. when i parked bike there I immediately checked the over flow petrol line and its tip was wet with petrol. How is it that petrol is overflowing when I am riding my bike? my mechanic is off on sundays so I will give him bike next saturday (as I am very busy on weekdays).
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Quote Originally Posted by ha125 View Post
    no brother. at home bike is parked under garage shade and also at my work there is shade under which bike is parked.
    Quote Originally Posted by 7thgear View Post
    i have checked the fuel key. it is dry. the fuel line is also dry. I have not checked the fuel tank for leaks. i will do that today.
    i have filled my tank fully and I will keep the fuel key to off when i park my bike. and i will check this for one week. if doing this solves my problem then it will surely be that carb is overflowing. if this doesnt work then i will start to look for leaks elseswhere.
  12. #12
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    I had my bike washed today and when I came home I saw the right side of engine has some kind of oily deposit. It looks like a leak coming from where the 'race' cable goes into the engine. I am posting some pics. Does this have something to do with the smell of petrol i get from the bike? or is it engine oil leaking?
    Strong smell of petrol from bike -310014
    Strong smell of petrol from bike -310015
    Strong smell of petrol from bike -310017
    Strong smell of petrol from bike -310018
    Strong smell of petrol from bike -310019
    Strong smell of petrol from bike -310020
    Strong smell of petrol from bike -310021
  13. #13
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Quote Originally Posted by BlueHorn View Post
    If sum rookie messes up with the drums(floats) of the carb then this can easily happen.. i guess then u carb is the culprit..
    Get the carb tuned by a real guru! a messed up carb can be a real pain in the bottoms!
  14. #14
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    can anyone comment on the pics i uploaded. is it engine leak or is petrol leaking from race cable??
  15. #15
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    not used this bike,,
    but this seems probably due to right gasket + any seals that are meant to seal sourroundings of the cable,,
    if u washed it today and then this is the aftermath then its extremely serious issue,, check ur engine oil and immediately sort out,,
    uise high tem silicone gasket when replacing gasket,,
  16. #16
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Quote Originally Posted by asjdsm View Post
    yes brother these pics are after about 20 minutes of wash. I rode the bike straight from service station to home. If i had not washed it I would think it was some dirt. But since I washed it and rode it home the whole bike was clean except this area. I will get it checked on Saturday from my mechanic. Do you know if Honda makes these gaskets? I mean are genuine ones available from honda 5s dealers?
  17. #17
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    not sure,, but if honda makes one thenb go for them is the price diff is reasonable to u,, but bre sure to apply high temp silicone .. this will seal it excellant,,
  18. #18
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    and if u open this side u will need to change the oil as well,, if u changed it recently then pour it into a clean bottle/tub and when pouring it make sure no dust/sand has been mixed with it,, however i would suggest u to not re use the old oil,, instead go for temporary fix,, which is to clean the surface ,, and apply curil to the suspected places,, this will stop lean for some time,,, until u r done away with the used oil,, this is less risky as compared to reusing old oil,,curil costs 45-60 rs,, forgot the exact price
  19. #19
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    and this engine oil seepage/leakage wont give u any noticible smell if u just stand by next to ur bike,
