Results 1 to 11 of 11
Like Tree5Likes
  • 2 Post By HasHo0
  • 1 Post By Silver_Knife
  • 2 Post By talhabinomar
Thread: cg125 rear brake issue
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Default cg125 rear brake issue
    Salam brothers.
    My cg125 rear brake was not very effective. So got its sleeve made from kharadia and installed new original brake shoe. This worked fine for one month. But now when I apply the brake it is not very effective. So i tighten the nut a bit and then brake is ok. But after 2 or 3 days again brake is not good and I have to tighten the nut (I am talking about the nut that is on the right side of the bike next to the silencer). If I tighten the nut too much then the rear wheel starts to get tight as well (zayada tight ho jata hai). So what is the permanent solution to the problem? do i need to replace the nut? Kindly advise.
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    is ur wheel alligned?
    is it axel nut properly fitted anbd tightened..
    is ur chain properly tightened? and adjusted,, do the marks on either side of the chain adjuster on same oint ?
    if they r not ur brake shoe is not making a full surface contact,,its making a partial contact,,
    stand ur bike on double stand and rotate the wheel .. check there should be no sound when no brake is applied,,
    also use a good brake shoe,,
    i also had this issue when i used cheapo brake shoe ,, so now in my 70 i use a 150 rs brake shoe,,
    there is one that costs 250 i will try that but this one is awesome,, lasts longer doesnt needs frequent adjustement,,
    so there can be many issues,,
    btw how much u paid fore all the job?
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Quote Originally Posted by asjdsm View Post
    Thanks for quick reply asjdsm brother.
    I paid rs.150 for th kharadia and rs.250 for brake shoe from honda 5s dealer.
    I recently also changed rims and they are in alignment.
    I never face this problem with my front brake. It always provides best braking and I never need to tighten its nut.
    I have tightened chain during my bike tuning about 10 days ago. So all is well in there.
    Do u think that maybe rear brake nut is loose? what is axel nut?
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Quote Originally Posted by BlueHorn View Post
    Brother if possible try arranging the Honda Deluxe Brake Shoe, After some trimming you may fit it into you bike and the result are owsome.
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Quote Originally Posted by Silver_Knife View Post
    brother what kind of trimming are you talking about? i think there is a considerable size different between Dlx and classic brake shoe.
    HasHo0's Avatar
    Jan 2011
    298
    if you think that rear Break Nut looses , then simple solution is
    to tighten another nut on the back of existing break nut
    Better to understand a little than to misunderstand a lot
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Quote Originally Posted by HasHo0 View Post
    thanks brother. i will try that
    Site Banned Follow
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Ya i think you are right because the drum size of DLX is bigger than classic.
    Tighten the screw that is attached to foot rest which indeed triggers the brake. May be that helps you
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    i will try that brother. thanks for ur reply
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Update:
    Today I had some time so I got the rear brake checked. The mechanic said that the kharadia was supposed to make a 'soft sleeve' but instead he has made a 'hard sleeve'. I do not know what this means. Can some explain? Should I go to kharadia and ask him to make the sleeve soft?
    talhabinomar's Avatar
    May 2011
    26
    2,472
    38 Post(s)
    What about Drum Rubber ?? I think just take one tour of that Kharadia. Tell him that what is told by mechanic. sometimes Kharadia can solve your problem better than a mechanic. First go to any other reliable mechanic and take his sincere advice
