Results 1 to 3 of 3
Thread: Cd200 Roadmaster problem!
    faizanrao's Avatar
    May 2011
    116
    Default Cd200 Roadmaster problem!
    Assalam u alaiqum!
    Recently my bike has started giving smoke from engine hole which is above the engine head and the level of smoke is sufficient to be noticed easily when its on standing position.
    I am talking about a small outlet or sort of a circular 1cm outlet which is above the engine and below the curburetor (just to give you the idea about the place of it).It used to throw air in normal condition but now its throwing out a lot of white smoke and along with there is some oil also.
    My reliable mechanic has not seen it but on phone call he said it is a ring piston problem.
    I need a expert advise on it.I too think that my pocket is in grave danger
    so is this a Piston ring problem or could be a small issue?
    could it be a air filter?Curburetor problem?
    LAst month curburetor was having some issues with the float level ans also i havent changed air filter since ages i guess
    Cd200 Roadmaster problem! -337411
    faizanrao's Avatar
    May 2011
    116
    Bump!!!
    EXPERT ADVISE NEEDED
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    yes its a ring piston issue,,
    eason how
    when the piston moves up compressing all the gair and fuel mixture idealy there should be no way for the gases to come back all the gasses has to be pushed up by piston,,however if rings are not making proper seal with cylinder wal ,,as the piston moves up it will furthwer compress te micture and that mixture will escape past the leaky rings,, and into crankcase where it would escape through any hole that it finds,,
    do it at the earlies,, as doing this will only result in just either rehoning (razmaal sa jo aik cross hatch surface banatha hain cy;linder ka inner surface pa) and new rings and u may be lucky to reuse piston,,however luck hits very few times,,
    so anothere probability is that u may need to rebore the cylinder,new piston and new rings,,,
    hopefully ur cylinder head is ok,,
