Results 1 to 11 of 11
Like Tree9Likes
  • 2 Post By n0mi_89
  • 3 Post By n0mi_89
  • 2 Post By asjdsm
  • 1 Post By talhabinomar
  • 1 Post By ToxicDevil
Thread: Urgent help CD70
    ToxicDevil's Avatar
    Nov 2010
    1,318
    15 Post(s)
    13
    Default Urgent help CD70
    I tried to change oil at home but as there are two screws under cd70 i opened the wrong one.
    a spring and a metal rod with holes fell down.
    What is it and how to replace it? I put it back but now the engine is making tick tick sound help me
    ToxicDevil's Avatar
    Nov 2010
    1,318
    15 Post(s)
    13
    bump
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    screw or nut???
    dnt know much about cd70 but can t you put it back ?
    legend will revive soon
    n0mi_89's Avatar
    Apr 2009
    27
    372
    bro drain the oil in a clean pot..and unscrew the second nut and adjust the spring and the rod with the black rubber dot on it tick tick sound will go away *!!
    n0mi_89's Avatar
    Apr 2009
    27
    372
    put rod 1st with the black dot on the upper side
    then spring followed by the nut
    ToxicDevil's Avatar
    Nov 2010
    1,318
    15 Post(s)
    13
    ok i did what you said. I streched the spring and then put it back again but still the noise comes.
    What actually is that thing?
    will it harm the bike?
    asjdsm's Avatar
    Apr 2009
    30
    3,477
    57 Post(s)
    3 Thread(s)
    better go to mechanic,
    talhabinomar's Avatar
    May 2011
    26
    2,472
    38 Post(s)
    Come on man be Practical. I know that you know that how it is done. Best way is to go to Mechanic for Oil Change, keep close observation that which screw was opened by him. then try it yourself after one to two times.
    ToxicDevil's Avatar
    Nov 2010
    1,318
    15 Post(s)
    13
    I am not a noob!!
    I know how oil is changed I have done it myself countless times. I just opened the wrong screw by mistake!
    after I drove for a Km the sound automatically fixed itself!
    n0mi_89's Avatar
    Apr 2009
    27
    372
    it wont harm the bike let the tensioner adjust itself be patient
    n0mi_89's Avatar
    Apr 2009
    27
    372
    Quote Originally Posted by ToxicDevil View Post
    bro it is called timing chain tensioner
