pehley maine khud karne ki koshish ki thi engine polish 600 1000 1500 k regmal use kar ke dekhe they aur main mutmain bhi tha k ye kaam maine khud hi kar liya haipar jhangir (friend) k israr pe isko saan pe bhejaaur jab saan se engine k piece wapas aaye to really mujhe bhi bari khushi hui thisaan is really goodus wqt mujhe ehsaas hua k junaid sahab tum ne kya khak polish ki thi
yar its looking superb its immitating me to spend some thpusands at my bike
^^yama khappay
i already have 2 rivals nd maaf kia yar chilll
After Chrome i apply ICI Auto Shield inside as an anti rustboth mudguard, rear coil spring covers, front kaan, chain cover both pieces,some rusty head light and both new rims
keep this engine p0rn kumming,,
love the pics,,love the work
Going along nicely.
Here comes the heartbeat of enginefirst they were on sand blasting(afterwords i just polish the cornersof each heat sink for a shinny look )like we did in this cb engine but this shiny lookis more visible due to blackhere in Kawasaki this shine is on sandblasted head cylinder
and then for cylinder installation and boring as i told you before that piston was 100 and cylinder have the sleeveso we remove that sleeve and cylinder as welland install the new cylinder (u can say liner)as per size of standard piston ( zero piston )keep in mind that in these pictures piston is installed without ringsweight is also from a slightly used Japanese engine from scrape marketand from that same engine we buy all major parts just drop the head cylinder and engine number piece
Please change the color of Fuel Cork to silver. it will look good.
fuel cork color is of cb250 not mine and it was afterwords sandblastedyou are right it was not good looking in blue color
Honda v khapay !BTW nice thread ,Best of luck for your bike,s Recovery !
great g, liner is looking good, block n head is also looking nice after sand blasting
Amazing work Jedi..
some of my purchasing from the scrape marketrest of purchasing from scrape market u will see in the assembling session
Unfortunately my Kawasaki seat was total lostbut Fortunately i got the Thailand model seat and the best part is,seat base is made of plastic like in new GS150so now no tension of rust under or beneath the seatgeniune rear hub made in Thailand with its original rubber padand rear sporket was also included original SUN got 34 teeth
brother you are working at your best
bhai 34 lagay ga, front sprocket konsi choose ki hy? teeth?
Guruji front 14 hai main rear 34 lene nai gaya thalekin jab rear drum liya aur ye fitted tha to dil aagayisliye shopkeeper ko nikalne bhi diya
bht ala............bday **** k baad aisa jaandaar project dekha hai.....best of luck....and i hope the end product will be lush push
