Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 200
Like Tree112Likes
Thread: Eagle Firebird DG70 Bike Thread
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Default Eagle Firebird DG70 Bike Thread
    This is Eagle Firebird DG70 Motorbike Thread
    Eagle UPDATED Their Website. You can read the Official Specifications on their website now.
    Official Specs Of Firebird
    ECONOMY OF 70CC PLEASURE LIKE 125CC
    Eagle Firebird DG70 Bike Thread - sl 1 993 550
    Eagle Firebird DG70 Bike Thread - promojpeg
    Eagle Firebird DG70 Bike Thread - black
    Eagle Firebird DG70 Bike Thread - red
    Eagle Firebird DG70 Bike Thread - blue
    Eagle Firebird DG70 Ad:
    Eagle Firebird owners share your sights, reviews, opinions, suggestions, tips, criticisms further your bike photographs. Hence other peoples can get comprehensive information about this recently released motorbike. Mods mark this thread to Sticky. Please don’t post irregular comments and stay on the topic. Everyone is welcome to stake his words.
    I am sharing Eagle Firebird DG70 specifications which I got from my bike manual book. Eagle has not updated their website till yet.
    Specifications Taken From My Bike Manual Book:
    ENGINE
    • Fuel Mileage 85 KM
    • Engine 4 stroke, single cylinder, overhead cam, air cooled
    • Bore and Stroke 47 x 41.4 mm
    • Displacement 78 cm (3)
    • Compression ratio 8.8:1
    • Spark Plug HERO: C7HSA
    • Spark Plug Gap 0.6 – 0.7 mm
    • Valve Clearance IN: 0.05 mm
    • EX: 0.05 mm
    • Ideal Speed 1500 + 100 RPM
    • Transmission 4 speed constant mesh
    • All forward N-1-2-3-4
    • Starting Kick Start
    WEIGHT
    • NET WEIGHT 90 kg
    CHASSIS OR SUSPENSION
    • TRAIL 70 mm
    • Front Tire size 2.25-17-4PR Air pressure 25 PSI lbs/sq in
    • Rear Tire size 2.50-17-4PR Air pressure 28-32 PSI lbs/sq in
    POWER TRANSMISSION
    • Primary Radication 3.722
    • Final Radication 2.928
    • Gear Ratio 1st 3.277
    • 2nd 1.937
    • 3rd 1.350
    • 4th 1.043
    OIL CAPACITY
    • Engine Oil (0.6 liter) – 0.8 liter
    • Recommended Oil SAE20W-4(API-SF/CC)
    • Petrol Tank 9 Liter
    • Petrol Reserve Tank 1.0 Liter
    LENGTH
    • Overall Length 1885 mm
    • Overall Width 760 mm
    • Overall Height 990 mm
    • Wheel base 1210 mm
    ELECTRICAL
    • Ignition System CDI (Capacitor Discharge Ignition)
    • Battery 12V - 2.5 AH
    • Generator AC Generator
    • Fuse 7A
    • Head Light High Beam/Low Beam 12V – 25/25W (with wires)
    • LED Tail/Stop Light LED 12V – 5/18W
    • Turn Signal Light Front/Back LED 12V – 10/10W
    • Neutral Indicator Light 12V – 3.4W
    • Turn Signal Indicator Light 12V – 3.4W
    MISCALLENOUS SPECS
    • Brake Front: Drum brake expending shoe
    • Brake Rear: Drum brake expending shoe
    • Suspension Front: Telescopic Hydraulic Forks, with coil springs
    • Rear: Double acting hydraulic shock absorbers, with coil springs
    Disclaimer:
    I don’t belong to Eagle/Diamond group or any other bike manufacturer. I am not advertising Eagle products on Pakwheels. Above mention specs are taken from my eagle bike manual book. I am not responsible for any claim/errors/mistakes or if you buy this ride and it doesn’t meet your expectations. Thank you!
    31.5497 N, 74.3436 E
  2. #61
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    @Juste today I met an Eagle bike rider...he told me he id 95km/h on his bike
    what's ur bike's top speed ?
    Main tay Honda ee lay saa'n !!!
  3. #62
    masifmehmood's Avatar
    Dec 2008
    47
    Quote Originally Posted by Juste View Post
    did my first warranty claim. Rear Tyre was not good it was giving bumps and jerks brand was Diamond, just got new Service Tyre off course free!!!
    It means warranty system is efficient.
    masifmehmood@live.com, muhammadasifmehmood@yahoo.com, 03004007480
  4. #63
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by khanthegr8 View Post
    Khan g i am driving under 40kmh my maximum speed was 41 or 42. Though my mechanic told I can take it to 50/60kmh. But i didn't I can tell you about my top speed once i complete running which is 1000km. till yet i have done around 175km total.
    It is very hard to control on throttle when you get a similar roar of CG from your bike exhaust but some how i am controlling my self. wese i don't drive too fast nor too slow i go on medium speed except running.
  5. #64
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by masifmehmood View Post
    Yes no doubt it is working and efficient though i have to visit them 2 to 3 times and you will be surprise if i tell who is dealing with Eagle warranty claim center/dealer Hamza Autos on Mcleod road near Gourmet Bakers, Mr. Hafeez (mechanic) who is dealing with RAVI and PIAGGIO bikes, he is dealing with Eagle warranty claim center
    First they gave me Panther tyre which i almost refused to take, i request them to give me Service tyre which they gave without any hesitation. One thing i notice and felt there Mr. Hafeez didn't wanted that I talk to piaggio owners. Coz i was getting some information from piaggio owners regarding bike and its spare parts. I saw many piaggio riders coming there and asking for spare parts.
    Hows Ravi army quota going? Do Ravi completed their army bikes task?
  6. #65
    Dec 2008
    47
    RAVI refused to provide PIAGGIO bikes to Army
  7. #66
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    oh i see. why ravi denied there offer? we were thinking bcoz of army quota Piaggio is short in market...but now its clear no bikes to army..so then what is the reason of Piaggio shortage in market?
  8. #67
    Naveed4speed's Avatar
    Aug 2006
    Sialkot
    26
    6,130
    7
    49 Post(s)
    2 Thread(s)
    congratulationson ur bike buddy!
    really like the change in bike!
    ALLAH mubarak kre!
    Formula for bike registration in Punjab
    1% of Vehicle price
    Life time token tax = 1200
    Number plate price = 400
    Suppose if bike price is 50 K then formula will be as follows
    1 % of vehicle price = 500
    Total = 2100 total cost......
    Khud line me lag ke jama karao gey to pura 2100 lagay ga
    kisi agent ke through lagwao gey ya showroom wale se to wo apni marzi ke paisey lain gey.... koi b fav number laina ho to ( except auction numbers )1K extra dey kar mil jata hay in small cities.... lahore ka pata nahi kya system.... talha telling 17K for 125 number......
    in okara 1 number sold in just 7500
    sir g bari gal ae k 1 digit number sold out in just 7500 rupees!
    aethe te auction de number 30k tak sale ho rhe ne~!
    aur ab to 2 digit b ino ne auction main kr die hai
    FXXB and EJ8 on its way............
  9. #68
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by Naveed4speed View Post
    ALLAH mubarak kre!
    kher mubarak bro. ameen
  10. #69
    Dec 2008
    47
    they refused because they cant import so they cant supply, reason is shortage of funds for import.
  11. #70
    Dec 2008
    47
    [QUOTE=Juste;3248879]Yes no doubt it is working and efficient though i have to visit them 2 to 3 times and you will be surprise if i tell who is dealing with Eagle warranty claim center/dealer Hamza Autos on Mcleod road near Gourmet Bakers, Mr. Hafeez (mechanic) who is dealing with RAVI and PIAGGIO bikes, he is dealing with Eagle warranty claim center
    IT MEANS EAGLE SUCCEED TO BREAK RAVI DEALERS?
  12. #71
    poppatTURBO's Avatar
    Dec 2004
    Multan
    38
    1,720
    Thumbs up
    juste mubarak ho apko
    mashAllah khoobsorat bike hai, Allah apko mubarak kare iski ride.
    Could u plz do me a favour, can u find & tell me if these LED indicators & headlamp can be installed in Suzuki GS 150 model 2005 ?
    Suzuki GS150 2005...Im Lovin' It :-)
  13. #72
    Aug 2006
    Sialkot
    26
    6,130
    7
    49 Post(s)
    2 Thread(s)
    @poppatTURBO!
    long time no see!
    aaj apki almost 2 saal bad reply dekhi!
    nice to see u on board after a long time
  14. #73
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    My opinion regarding this is: Which company gives more money/commission to dealers, dealers will stay with them. They all are greedy they just need God damn money they have no concern/mean to any company which company deals with them either it is RAVI or AHL or Diamond Group e.g in short "aam khaoo pare nahi gino"
    I my self saw and felt this thing badly in every dealer I am not just talking about Mr.Hafeez. When i was seeking bike and wandering in market, Ravi showroom was exact next the Eagle showroom. Both the owners were abusing each other, I still remember their words.
    Ravi dealer said: oh bhai Eagle is crap just use junk parts 47k amount Eagle don't deserve for their product. Eagle dealer said: bhai jee come on, I know much better then you, I am selling bike since many years and I know what Ravi actually is and what they are selling. cheap material, cheap bla bla e.g.
    I listen to both of them and thought. They just need a customer money they don't give a damn to anything else.
    Felt bit of this thing in Mr.Hafeez as well when i was collecting info regarding piaggio spare parts. His intention was we people just buy piaggio so after warranty period he can earn cash from piaggio owners
    Enough or should i tell you complete story ?
    Dealers are greedy for only money like wandering dogs only need bones. They don't give any damn/value to Company and customers both. They only want to earn cash from both hands that's it. Rest of the world should go in to hell!
    Money FTW!!!
    No Offense to anyone!!!
  15. #74
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    oh i see to kia Ravi will still make Piaggio for public? I wish RAVI keep continuing this product, we have no one against AHL, Pak Suzuki and DYL To be honest mehmood bhai only RAVI seems to me "Underay mein ummeed ki ek choti si kiran".
  16. #75
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by poppatTURBO View Post
    Kher mubarak bhai thanks for your comments ameen!
    bro if you are asking about that black light hood then yes it can be easily installed in GS 150. i saw booster installed hood in his bike. just search his thread you fill find it.
    I have no idea about these led indicators can be installed in your bike or not. I don't have any GS 150 in my area so i could try. personally i think these indicators will suit on gs 150
  17. #76
    Dec 2008
    47
    magar ab yeh kiran bujhti ja rahi hay!
  18. #77
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    nahiiiiiiiiiiiiiii . ap likhne me itni kanjoosi kyun karte han bhai ?
  19. #78
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    so mr juste hows fire bird doing?
    legend will revive soon
  20. #79
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by hidalgo View Post
    Firebird is waiting for her number plates and papers, which still she didn't got and sleeping in the garage under camel color cloth Once in a day she awake eat some fuel as a meal and go on roads as a early morning walk and then goes to sleep again in garage
  21. #80
    Dec 2008
    47
    kia likhwana shahtey hen?
