Page 8 of 10 FirstFirst ... 678910 LastLast
Results 141 to 160 of 200
Like Tree112Likes
Thread: Eagle Firebird DG70 Bike Thread
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Default Eagle Firebird DG70 Bike Thread
    This is Eagle Firebird DG70 Motorbike Thread
    Eagle UPDATED Their Website. You can read the Official Specifications on their website now.
    Official Specs Of Firebird
    ECONOMY OF 70CC PLEASURE LIKE 125CC
    Eagle Firebird DG70 Bike Thread - sl 1 993 550
    Eagle Firebird DG70 Bike Thread - promojpeg
    Eagle Firebird DG70 Bike Thread - black
    Eagle Firebird DG70 Bike Thread - red
    Eagle Firebird DG70 Bike Thread - blue
    Eagle Firebird DG70 Ad:
    Eagle Firebird owners share your sights, reviews, opinions, suggestions, tips, criticisms further your bike photographs. Hence other peoples can get comprehensive information about this recently released motorbike. Mods mark this thread to Sticky. Please don’t post irregular comments and stay on the topic. Everyone is welcome to stake his words.
    I am sharing Eagle Firebird DG70 specifications which I got from my bike manual book. Eagle has not updated their website till yet.
    Specifications Taken From My Bike Manual Book:
    ENGINE
    • Fuel Mileage 85 KM
    • Engine 4 stroke, single cylinder, overhead cam, air cooled
    • Bore and Stroke 47 x 41.4 mm
    • Displacement 78 cm (3)
    • Compression ratio 8.8:1
    • Spark Plug HERO: C7HSA
    • Spark Plug Gap 0.6 – 0.7 mm
    • Valve Clearance IN: 0.05 mm
    • EX: 0.05 mm
    • Ideal Speed 1500 + 100 RPM
    • Transmission 4 speed constant mesh
    • All forward N-1-2-3-4
    • Starting Kick Start
    WEIGHT
    • NET WEIGHT 90 kg
    CHASSIS OR SUSPENSION
    • TRAIL 70 mm
    • Front Tire size 2.25-17-4PR Air pressure 25 PSI lbs/sq in
    • Rear Tire size 2.50-17-4PR Air pressure 28-32 PSI lbs/sq in
    POWER TRANSMISSION
    • Primary Radication 3.722
    • Final Radication 2.928
    • Gear Ratio 1st 3.277
    • 2nd 1.937
    • 3rd 1.350
    • 4th 1.043
    OIL CAPACITY
    • Engine Oil (0.6 liter) – 0.8 liter
    • Recommended Oil SAE20W-4(API-SF/CC)
    • Petrol Tank 9 Liter
    • Petrol Reserve Tank 1.0 Liter
    LENGTH
    • Overall Length 1885 mm
    • Overall Width 760 mm
    • Overall Height 990 mm
    • Wheel base 1210 mm
    ELECTRICAL
    • Ignition System CDI (Capacitor Discharge Ignition)
    • Battery 12V - 2.5 AH
    • Generator AC Generator
    • Fuse 7A
    • Head Light High Beam/Low Beam 12V – 25/25W (with wires)
    • LED Tail/Stop Light LED 12V – 5/18W
    • Turn Signal Light Front/Back LED 12V – 10/10W
    • Neutral Indicator Light 12V – 3.4W
    • Turn Signal Indicator Light 12V – 3.4W
    MISCALLENOUS SPECS
    • Brake Front: Drum brake expending shoe
    • Brake Rear: Drum brake expending shoe
    • Suspension Front: Telescopic Hydraulic Forks, with coil springs
    • Rear: Double acting hydraulic shock absorbers, with coil springs
    Disclaimer:
    I don’t belong to Eagle/Diamond group or any other bike manufacturer. I am not advertising Eagle products on Pakwheels. Above mention specs are taken from my eagle bike manual book. I am not responsible for any claim/errors/mistakes or if you buy this ride and it doesn’t meet your expectations. Thank you!
    31.5497 N, 74.3436 E
  2. #141
    SDF38's Avatar
    Jan 2012
    509
    wow @ 100+ speed... sirf silencer se itna farq? wah bhai
    ..... man i llllllllllove to ride r1
  3. #142
    TheNewBiker's Avatar
    Aug 2011
    121
    hmmmm juste what is the mileage u'r getting from your bike?
    I'm The Best And Will Always Be
  4. #143
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by TheNewBiker View Post
    Bro i will let you know after 1st tuning. Drove 850 km so far.
  5. #144
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    In last week for the very first time I dragged my bike since I bought it. To be honest my speed o meter needle was touching 80KM on main boulevard. I didn't believe my bike was around 80km I am not sure that was magic or something else. I will check my bike topspeed after 1st tunning.
  6. #145
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by Juste View Post
    bro most 88cc (aka 78cc) cHondas does good top speed in long run..
  7. #146
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by asjdsm View Post
    What is your bike top speed ?
  8. #147
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    when it was stock it could do 85 but my friends could do 90 with t.. he was a bit senior in racing deparment and also very tiny weight like 55 kg..whareas me 72kg..
    now after alteration 100 on a bit long patch of road but 80 is achieved instantly.. and pick is awesome now ..
  9. #148
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    raja_aftab_yasingood to see that you are happy with your purchase.....you are lucky that your bike is doing 100+ speed.... the max i have seen on my junoon is 100Km/h.Surprised to read that you rode GTO125, CG125, Yamaha100 and still you liked firebird "drive wise" ??? I have Junoon and one thing i know for sure, i ain't ever going back to 70cc. (My opinion )
  10. 20-06-2012, 12:02 PM
    Site Banned
  11. #149
    Aug 2011
    121
    juste brother it has been 7 days... dont u got ur 1st tuning.......
    we all are waiting bro....
  12. #150
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Bro i am busy these days further my bike is doing good now. I got the missing fault it was fuel problem. I used SHELL Fuel in last days and when ever i use SHELL petrol my bike start giving missing issues. When i switch to PSO fuel my bike never did any kind of missing. SHELL oil in my area is crap.
    Anyhow as i mention i am kinda busy these days, i will try to go for tune up asap. Hot sunny days also change my mood.
    1 thing is for sure my bike at least will give me around 60 to 65km.
  13. #151
    Aug 2011
    121
    hahahaha.... well well well... i am anxiously waiting for ur tuning.....
    well also tell me that from which dealer u have bought this bike.....???
  14. #152
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Why you are so worried about mileage? All 70cc bikes gives at least 55km to 60km.
    When i bought my bike at that time it was available on only 2 showrooms on McLeod road. no idea about current situation.
    If you are serious about buying the bike then you can PM me for details.
  15. #153
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Running period over. Tuning Done. It is the time to check the power of this mini 125 beast Ooo yeah i call it mini 125
    After tuned, muffler sound is now more crisp and i feel better roar too. There was some dust in carburettor too.
    From now i will try to check the top speed of this bike.
    By the way it goes to 70km easily without hesitation.
    Oh ya! guys there is no vibration in complete bike on even at 70km speed Wooohoooo . No vibrations no khar khar sounds like other bikes specially AHL 70 bike
  16. #154
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Installed Fuel lock, now my fuel is safe. I can full the tank with no worries
    but bike need 2 keys to work
    1st key in ignition
    2nd key in fuel lock (without key fuel don't go to engine, in result the engine will stop working)
  17. #155
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Juste: Do post some hot shots of your Eagle....
    Dream is not that which you see while sleeping it is something that does not let you sleep.
  18. #156
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    yeah bro do post some more pics of your eagle
    specially kindly post some outdoor shots
  19. #157
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    I was at mclore rd recently and saw Eagle Firebird first hand. mashallah build quality looks good and sound is somewhat similar to CG125. I didnt get chance to ride it but the bike looked solid.
  20. #158
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by r1 View Post
    bro don't have any camera not even in cell phone.
  21. #159
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by BlueHorn View Post
    I agree with you. Ride it once and you will feel the difference.
  22. #160
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    bro don't have any camera Eagle Firebird DG70 Bike Thread - smiley frown not even in cell phone.
    Eagle Firebird DG70 Bike Thread -433886
