Results 1 to 12 of 12
Like Tree7Likes
  • 1 Post By archon2001
  • 3 Post By AsadGhumman
  • 1 Post By KamranAslam
Thread: CD 200 6 Volt Battery
    azad_200's Avatar
    Feb 2012
    6
    Default CD 200 6 Volt Battery
    I am silent viewer from last few years, finally today i have enrol in the pakwheels, i must say its very informative site for us.
    Dear i have old CD 200, we used very occasionally, now the problem is its battery is not working , i tried several shops but no one have 6 volt , previously 2 year back we replaced it with National battery, so please advise me from where i can get 6 volt battery, one of the electrician told me you simply put 12 volt 8 amp. battery it will work without any problem and modification ( DIL NAHYEE MANTAA its work without modification) so please advise me..shall i put 12 volt or search for 6 Volt....
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    try cooperative market saddar where they sell batteries for emergency lights etc u will surely found 6v battery for yr cd200. it will be maintenance free battery and normally they work for couple of years before they die, price will be around 550 to 800 rupees depends upon yr bargaining skills.
    Help others so that u can be Helped
    azad_200's Avatar
    Feb 2012
    6
    Thanks archon2001... are you sure these emergancy lights battery will work?
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Quote Originally Posted by azad_200 View Post
    they will work just fine i got them installed in my 2 gs150 / 1 in kawasaki gto 125 off course 12volt versions of them, also they used to be installed in my 185 twin when i converted her into 12v cdi version.
    in fact u will be tension free for many years as they don't required maintenance.
    azad_200's Avatar
    Feb 2012
    6
    Dear archon2001..as a experienced person can you comments on below query..
    "one of the electrician told me you simply put 12 volt 8 amp. battery it will work without any problem and modification nothing else require to change except bulb... "
    as i feel its also require to change coil, condenser...etc ..
    bravo122's Avatar
    May 2010
    Other
    22
    1,730
    21 Post(s)
    try 6v emergency light battery!!!
    easily available
    :a
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    u r correct abt the changing of coil , condenser etc as i don't believe that 12v battery will do any good for the 6v default setup of the bike.
    i was told the same thing by 1 of the electrician when i ran out of the spare of 6v , but then i changed to 12v cdi setup and got rid of 6v setup once for all.
    go for the 6v battery as told before and u will be more than pleased with their performance.
    kind regards
    AsadGhumman's Avatar
    Jan 2009
    32
    2,377
    28 Post(s)
    19 Thread(s)
    This is why I love Pakwheels
    ~~~ "Some complain that roses have thorns, others rejoice that thorns have roses" ~~~ "Nine-tenths of wisdom is being wise on time....Theodore Roosevelt" ~~~
    silentbiker's Avatar
    May 2010
    36
    278
    i also got cd-200, i have just installed dry battery having 7 amp. its going well with stock 6 volt coil wiring. but only for my satisfaction i havr changed the total wiring from 6v to 12v. its going well so far, battery casts me 2200 brand new dry...
    call me for any query. 0321-3339211
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Quote Originally Posted by silentbiker View Post
    u got the battery way to expensive , its easily available for 1250 to 1300 rps only.
    btw the way did u get the starting coil winding changed too, if u did u already have killed the coil of yr bike.
    kind regards
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,249
    7
    295 Post(s)
    11 Thread(s)
    9
    @Archon: a very well advice, @Azad: Good Luck for your plan.
    I my self will be visiting the place as instructed by @archon, will be installing a dry charge 12volt in my 115.
    I am only responsible for what I say, not for what you understand..
  12. #12
    May 2010
    36
    278
    @archon
    lahore main dry battery ki yahi price hay.
