Results 1 to 9 of 9
Like Tree9Likes
  • 4 Post By Juste
  • 2 Post By faisalbiker
  • 2 Post By dulmial_2006
  • 1 Post By BlueHorn
Thread: Ignition switch
    Chaudhary007's Avatar
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Default Ignition switch
    I had my bike washed, it started doing missing so i went to a mechanic.
    He told me that the problem is with the ignition switch as it has become short due to water. When he disconnected the switch (made it direct) and told me to go for a try the bike was doing fine, so obviously the problem is with the switch.
    Now i am a bit concerned that should i now go for only the switch and use the key which will come along with it for starting and use the old key for handle lock and tapas or should i replace the whole system and have one key.
    Advise is needed.
    Bike is: HONDA CD70 2011
    If you ride like there's no tomorrow, there won't be.
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    get new key only for ignition switch. how many times a person open side covers (tappas) ??? place ur both keys in 1 key ring. save your bucks buddy don't waste them.
    31.5497 N, 74.3436 E
    faisalbiker's Avatar
    Jan 2009
    26
    193
    i have same prob.
    connect switch after a day, i have just come frm mechanic and now bike is okey
    next time when u go for service then warp meter with plastic bag (y)
    akhterrasool's Avatar
    Jan 2010
    424
    I think problem is with the switch.
    dulmial_2006's Avatar
    Aug 2007
    Chakwal
    24
    85
    Happend to me also, i just opened ignition switch and changed the inner cuircuit plate with after market one, buddy dont waste money, buy aftermarket switch and replace the plate, no need to change Keys.........
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by dulmial_2006 View Post
    excellent solution..
    what would be the total cost eitherways.?
    Site Banned Follow
    BlueHorn's Avatar
    Apr 2011
    1,717
    99 Post(s)
    5 Thread(s)
    Buy a new switch then go to a locksmith. Give him your key and ask him to adjust the new lock for that key. He will charge you around rs.50 for that and then you can use your existing key for your new ignition lock
    Ad33L's Avatar
    Dec 2011
    Muzaffargarh
    25
    49
    Juste,Dulmial,Bluehorn,Very wise suggestions.
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    good suggestions here but i like dulmial_2006 suggestion the most if its applicable go for it
