Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Like Tree4Likes
Thread: Problem in Gears shifting
    Sajid20's Avatar
    Jun 2011
    26
    1,456
    11 Post(s)
    Default Problem in Gears shifting
    Salam dostun,
    I have been facing problem in gear shifting of my bike since last three days. Dusra aur teesra gear boht atak raha hai, apply karty main bhi or gear nikalte main bhi. Kbhi kbhi bilkul he gear apply nahi hota phr thora zor se press karna parr raha hai or aisa he gear nikalte main bhi horaha hai.
    Before going to mechanic, bike's expert kindly let me know why this problem is occurring? (bike completed only 2500KM as yet) Is it engine problem or something else?
    Thank you for your replys. Jazak Allah
    Same $hit, different day.
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    konsay brand ki bike ha?
    may be gear shift mechanism ois having some issue,,
    or gear dogs may be warped or damaged,, but of its in warranty try ur best to juice it out,,
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Must be prob with your bike's clutch.. Main reason of gears stuck is loose clutch.
    Dream is not that which you see while sleeping it is something that does not let you sleep.
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    get your clutch wire adjusted that's the only issue
    ~ Be a responsible citizen and always drive safely ~
    Sajid20's Avatar
    Jun 2011
    26
    1,456
    11 Post(s)
    @asjdsm: Unique and warranty has been expired three months ago.
    @r1, aantherax: that's what i thought but why there is no problem in shifting 1st and 2nd gears? well, i will visit to mechanic or try to adjust it myself.
    Thanks
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    since its specific t gears it has in my opinion more to do with gear shift mechanism,,first try to check it from a good trusted mechanic ,,for new bikes i dont think clutch will give thiis result if its little bit mis adjusted,,
    Sajid20's Avatar
    Jun 2011
    26
    1,456
    11 Post(s)
    ^^ i didn't touch clutch adjustment as well, and yeah i will visit him inshAllah in coming days and will update this thread accordingly...
    Sajid20's Avatar
    Jun 2011
    26
    1,456
    11 Post(s)
    well go to a random mechanic today he said clutch plate needs to be changed. When i asked him my bike only completed 2300km as yet he said this problem may occur as ur bike is unique UD-70, there must be china clutch plate would be in it as they are cheaper, japanese one cost around 220-240. Is he right?
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    its new to me that such low mileage bikes clutch plates are worn out,,
    regarding chinese cheapo plates being installed i cant say even they would fail so early,,
    also a member FC had great words about chinese clutch plates he said even the cheapest are more or less same,,and at least wont fail so early,,
    now it may be some other problem which made your clutch plates worn out so early,, yes this could be due to clutch plaes being worn out..
    can u tell how the problem started,, did it started suddenly or u felt as huge lack of power from a long time,,?
    whatas bike power like? and op speed?
    does u note lack of power in any gear?
    have u checked ur engine oil color/thickness/roughness?
    Sajid20's Avatar
    Jun 2011
    26
    1,456
    11 Post(s)
    ^^ bro i am not sure if that mechanic is right or wrong as its not the trusted one. I would visit experienced mechanic of town yesterday.
    Yar i am surprised too as the problem started suddenly just two-three days ago, bike easily touches 80km/hr and i didn't observe any lackness of power in gear though, didn't check engine oil as yet.
    Well today i ride it for a short route and bike performance and shifting of gears were just fine. That random mechanic also told me that may be because of heat up your gears were malfunctioning. BTW when i faced this problem, i went to sea view from north karachi then from DHA to north karachi which makes more then 60km...
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    i have been in sakh garmi on my yd70 from islamabad to taxilla and back,, and that day i was like 100km riden,,had no issue,,even my dyl used to heat a lot,,heat can only be the issue if oil is not in requireed quantity,,
    so as u mmentioned the problem stared suddenly,,
    i can safly say clutch plates are ok,,
    may be it was used without clutch to shift gears..and thw speed also makes it safe to say so..
    however check oil and ask a good mechanic,
  12. #12
    Maggi's Avatar
    Mar 2007
    30
    4,014
    5 Post(s)
    may be u have a loose clutch . i have faced a similar problem and set the clutch by myself ...
    Team DEKA
  13. #13
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Sajid bhai itni jaldi preshan na hojaya kro. ye itni jaldi ksi natijay par na pohncha kro wo bhi ek mchanic k kehny par jinhen clutch,chain adjustment nhn ati.
    Adjustment bhi koi chiz hoti hy.Agr adjustment thk na ho phr chahy koi chiz new bhi ho koi fida nhn.
    So try to do it ur self its not rocket science.Even i had changed bike's piston.
    I Am the Feel
    I Am The Yamaha!
  14. #14
    Sajid20's Avatar
    Jun 2011
    26
    1,456
    11 Post(s)
    Quote Originally Posted by Maggi View Post
    hmm alright buddy i will try to do so...
    Quote Originally Posted by N0m1 View Post
    yar pareshan kon hota hai just issue discuss karta hun bhai log tumse aj jana tha experience mechanic k pas par yahan strike hai.
    thek hai bhai main khud adj karunga, i don't touch this type of things coz of fear that i would end messing up the little issue.
  15. #15
    jamfazal's Avatar
    Dec 2011
    Other
    24
    I think better for you change your gear. If you change their chain then problems create within few days better for you change your whole gear system. you can buy part easily from any area of this country. what is your favorite bike brand that you area using.
    [url=http://www.rakca.com/dubai-company.php/]Dubai Company[/url
    [url=http://www.rakca.com/services/offshore/why/]Rakca.com[/url
  16. #16
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    He is as fast as his GHORA in his avatar
  17. #17
    Sajid20's Avatar
    Jun 2011
    26
    1,456
    11 Post(s)
    Quote Originally Posted by jamfazal View Post
    hain kya pora gear system change kar ***? yar not my favorite brand, using unique for the time being.
    Quote Originally Posted by r1 View Post
  18. #18
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    @Sajid,Roger buddy Roger.
    @R1,Hahaha.Oh hell yeah!!!
    I Am the Feel
    I Am The Yamaha!
  19. #19
    Sajid20's Avatar
    Jun 2011
    26
    1,456
    11 Post(s)
    So yes, after clutch adjustment gear shifting mechanism is working fine and smoothly. Jazak Allah to all of you for your help.
  20. #20
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    ^^Next time rolla na payen Kaka
