Assalamoalaikum .... My bikes headlight is too dim when its idling even sometimes it seems that the headlight is switched off although its turned on ... sometimes the headlight shows some reasonable light when idling but at rare moments but its not that much bright because i matched it to my friend's one and we both bought the bike at the same time though he has 8k kms on his odo and i have around 3.5k kms ..... has it something to do with battery or something else because i bought my bike around 10 months ago and since then i never poured distilled water in it because everytime i checked its level i found it to be at right level but around 1 week back when i checked it the water level in 1 of the cell was low however i immediately poured water in it and now the level is fine or i would say it was somewhat more than the level because i accidentally poured more water
Dear, issue is with your bikes battery. What about Horn & other lights. Secondly, does neutral green light on panel light up when you change the switch to ON position. Better you replace the battery with a Maintenance free dry battery (No tension of acid check).
Yes the green light turns on when i gear it to neutral... the LED indicators are running fine and backlight too but there's some strange problem with the horn ...the horn sounds perfectly alright when the bike is not running but when i rev it or its running the horn sounds like a dying or sick woman
wiring problem ho sakthi ha,, check for ground faults .. better check it from an electrician..
and battery has nothing to do with the brightness of headlamp whatsoever..
