Results 1 to 2 of 2
Like Tree3Likes
  • 3 Post By 7thgear
Thread: Traction Control Explained
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Post Traction Control Explained
    Came across this very informative stuff, so sharing here.
    If you, by opening the throttle too far, make a torque request that overwhelms the ability of this contact patch to transmit force, the contact patch of the tire will begin to slide relative to the pavement.
    As the tire fails to push back against the cornering load, the motorcycle begins to rotate on its yaw axis. Here you've got three options. You can request the same amount of torque and the motorcycle will continue its rotation, terminating in a low-side crash. You can abruptly chop the throttle and as the contact patch force returns, the yaw rotation will convert to an abrupt roll rotation and a resulting high-side crash. Or you can modulate a delicate and nuanced intermediate throttle position that allows the tire to climb gradually and controllably back to the slip peak.
    Kawasaki, Yamaha, Ducati, Aprilia, BMW and MV Agusta have now introduced motorcycles with factory traction-control algorithms that, when necessary, preempt your imprudent torque request and attempt to keep your tire, not your leathers, in contact with the pavement.
    Dunlop illustrates the change in tire's contact patch at various lean angles:
    Traction Control Explained - Traction Control Contact Patch
    Kawasaki was the first Japanese manufacturer to equip their bikes with traction control:
    Traction Control Explained - Traction Control Kawasaki Ninja ZX 10R
    Now the 2012 R1 also offer six levels of traction control:
    Traction Control Explained - Traction Control Yamaha YZF R1
    Ducati engineers have gone slightly further than the two Japanese manufacturers in their thrust-force pursuit - they've added a single accelerometer, measuring the longitudinal acceleration of the bike.
    Traction Control Explained - 2012 ducati 1199 panigale display 13
    Kawasaki is the simplest of all the systems. Yamaha is slightly more complex than Kawasaki, with a similar sensor package, but adding an electronically-controlled throttle. Ducati's sensor package includes a single inertial sensor but without an electronic throttle (pre-Panigale). Aprilia and BMW deliver the most complexity, each with electronic throttles and four inertial sensors. We should be careful to point out, though, that complexity can only be justified in any system if its costs (more time to develop, more software to support, more parts to purchase, and more failures to tolerate) are offset by increased capability.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    Engine's Avatar
    Nov 2011
    Rawalpindi
    141
    6 Post(s)
    yeh.......... last time in Qatar Casey Stoner loses his position in race when his traction control system gone out in last 2 laps.... and he drops to 3rd position in last lap.... and so Lorenzo (factory Yamaha) win the race...
    best wishes to Stoner for today's qualifying practice....Traction Control Explained -399856
    Zindagi 300 km se age shuru hoti he..........
