Results 1 to 11 of 11
Like Tree11Likes
  • 8 Post By Automotorsport_Lover
  • 3 Post By Automotorsport_Lover
Thread: Tips for Buying used motorbike
    Zulfi007's Avatar
    Apr 2012
    12
    Default Tips for Buying used motorbike
    Dear Pakwheelers,
    I am interested in buying used Honda CD-70 or CG-125. I am a bit confused that which one should I choose. Recently I had a very bad experience with Unique -70 brand new as it started malfunctioning after the first tuning and lost me almost 12-13k in resale.
    Therefore I need your valuable suggestion that which above mentioned bikes would be good for me as I live in Karachi and what things should be checked or considered while searching the bike. But personally I like CG-125.
    I shall wait for your response brothers.
    Thanks.
    Zulfi007
    talhabinomar's Avatar
    May 2011
    26
    2,470
    38 Post(s)
    Check the complete documents
    Check the bike;s Engine Especially.
    Start the Bike and give a try.
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Check for the engine..
    • Give it half throttle in neutral and check if the engine gives any sort of smoke from the silencer.
    • Listen closely to the engine for any grinding or unusual sound.
    • Take a drive and take some feel, a good engine should not lag in power, drive would also give you an idea for worn out clutch and pressure plates.
    • Check the spark plug a melted/ over heated spark plug is the worst thing you can find. Plug should have a brownish color.
    • Check for leaking gas kits, engine should not have grease, oil, fumes deposited on it.
    Check the electronics..
    • Everything including turn indicators, head/tail lights, handle switches etc.
    Check the frame, the body..
    • Check if the frame is twisted due to an accident! Check if both the wheels are perfectly aligned.
    • Rims are aligned.
    • Handle is bent.
    • Front fork is bent.
    Check the general health of tires, battery etc.
    If you dont know this all, take a mechanic along and ask him to do it for you. Good luck!
    Zulfi007's Avatar
    Apr 2012
    12
    Thank you very much @talhabinomar and @Automotorsport_Lover.
    @Automotorsport_Lover I need to know few things from your explanation.
    1. Do you mean grinding sound from the silencer when the throttle is turned out? and Does this thing has any effect on bike's performance?
    2. Which area of the plug should I notice for melt on the plug thread one or top one?
    3. Where the gasket is located on the engine if you spot in some photo so I can understand it better?
    4. What are pressure plates and what function do they perform and should I figure it that they are gone or how the bike will react?
    Please also tell if all or some things are defective in the bike so how would I know that bike is not good?
    @talhabinomar
    1.What things should I check in the documents and how can I verify them?
    2. How can I know that the bike is not stolen or used in any crime?
    @Automotorsport_Lover. you can also comment on the above questions.
    and ONE very most important things that how should I know that the engine is sealed and is powerful?
    Again thank you very much for your valuable response.
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Quote Originally Posted by Zulfi007 View Post
    @talhabinomar
    By looking at your questions... i will suggest you to take a mechanic along and leave the job to him. You seem to know very little about vehicles
    Zulfi007's Avatar
    Apr 2012
    12
    Smile
    Dear Pakwheelers,
    I have searched many bikes but one bike I liked very much was Honda 70 1982 model it has a smart tank and looks but I have some reservations regarding it that Does it have CDI ignition system and if not how I can install in it and with other changes I could do to make it atleast look like Honda CD-70 2012 model and what cost I would incur in all changes that I will make?
    Your answer would be highly appreciated.
    Thank you.
    eyeofthetiger's Avatar
    May 2012
    34
    91
    I to like Honda CG 125, if you can bear the cost of running a CG 125, you should buy it. Honda CD 70 will be ecnomical and will have better resale value. Buying a good first hand CG 125 2010 Model will be another option too.
    Honda CD 70 will give to 65~70 KM in one liter where as CG 125 will do 43~48 KM in one liter.
    Eye of the Tiger "Be formless, shapeless like water..."
  8. 06-05-2012, 04:49 PM
    Site Banned
    Reason
    Spam
  9. #8
    Zulfi007's Avatar
    Apr 2012
    12
    Smile
    Thanks @eyeofthetiger I know all the merits of keeping both the CD-70 and CG-125.
    Guys I need some experts response to my queries.
  10. #9
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    great tips shared by "automotosport_lover"
  11. #10
    Zulfi007's Avatar
    Apr 2012
    12
    Red face
    Bumps!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!
  12. #11
    Sonu17's Avatar
    May 2012
    Mumbai
    49
    Selecting the perfect motorbike is not always easy. There are many things to consider before buying bike you have many choices when you buy used car especially regarding its performance for past years months respectively.
