Results 1 to 4 of 4
Thread: CD-70 Dying after hard braking
    CrankRaptor's Avatar
    Mar 2012
    26
    Exclamation CD-70 Dying after hard braking
    I have bought a new cd 70, its just 2000 KM driven. i am facing a problem, because the engine is dying frequently on signals and rushed places.
    My problem is that when i put the bike in 1st or 2nd gear then pull the throttle and release the clutch to start moving, then immediately engaging clutch and both the brakes the bike after a small bump ( can only be felt hardly) it dyies, i dont know whats going on with it, i have already tunned it for this reason, but the problem persists, please help
    I have adjusted the clutch freeplay, but it doesnt help. also what is the ideal idling speed of engine.
    Thanks in advance.
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    slightly increase the idle speed..
    ideal idling sped is 1500rpm for 70 but with no rpm meter u cant see where is 1500..
    so just rotate clockwise the idle adjustment screw half a turn if its too lound just reduce the turn..
    or go increasing the idle speed...
    http://assets.pakwheels.com/forums/2...-06-20-375.jpg
    the screw near the black wire is whch controls idle speed..
    hasnain19's Avatar
    Mar 2011
    21
    267
    Yup i also had the same problem after tuning the idle speed was too less by the mechanic just gave it a little turn now its perfectly fine
    Life is beauty, admire it.
    ToxicDevil's Avatar
    Nov 2010
    1,317
    15 Post(s)
    13
    get the free tuning done
Tags for this Thread
